Question about York / Cam-stat Compressor Cycle Timer 2cp04700124
York timer roblem
We can't figure out how to set our York timer. It seems simple enough. Put light screw on time to start. Dark on time when to stop Maybe its setting the correct time which is weird. Its at the bottom. Help.Richar
    President:
  • 1,723 Answers
Grasp the timer dial with your fingers and pull out on it to turn. Set the time of day with arrow at bottom and release. That's it!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 02, 2009
Setting time on/off york timer ss721z
The manual for the Tork SS721Z will walk you through the process.
Here is where you can find a copy of it in case you have lost yours:
http://www.generalfiles.biz/go/166153972200
Nov 26, 2013 | York Hardware & Accessories
Photo cell timer only stays on for a few minutes
Try it on another outlet, like in a dark bedroom without GFCI.
Buy another outdoor dawn-dusk timer.
Timers can be damaged by simple power outage, when power resumes there is a surge.
Timers stop working because the photo eye goes bad, or tiny 555 chip goes bad, etc.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 20, 2011 | Hardware & Accessories
Where on line is there a wiring diagram for the Leviton GLW-1463? I could'nt seem to find it on there web-site. Thank you. :)
Leviton GLW-1463 appears to be ordinary lighted 3-way toggle switch.
This switch is used in a hallway application where more than 1 switch controls a light.
The green screw is for bare ground wire.
There are two brass colored screws for traveler wires, and 1 dark screw for common wire.
If you are replacing another 3-way switch, then note color of each screw on old switch.
Put wire from old dark screw to new dark screw.
The travelers wires can go onto either brass screw.
Open following link for drawing of ordinary 3-way and 4-way circuits
http://waterheatertimer.org/ST01C-program.html#3-way
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 03, 2011 | Leviton 3W Lighted Toggle Switch -...
Compressor UP6 25 125, runs all the time but is only under load for a short time, should it shut down between loads?
This unit will shut down if unloaded for a set period of time. Usually 5 to 10 minutes. This time could be longer if some one has changed it from the factory setting. There is a timer in the control box that starts counting down when the unit unloads. If it stays unloaded long enough for the timer to count down the unit will stop until the air pressure drops to the low set point on the pressure switch. It will then start up. If the unit loads before the counter counts down the timer starts from the beginning when it unloads again. This cycle continues until you manually shut it down or you stop using air long enough for the timer to reach Zero and shut down.
Apr 22, 2011 | Ingersoll Rand UP6-25-125 120 Gallon...
Explain in plain english how this works. Set time on face rotating dial clockwise.. push in pins to on and off positions. It seems to screwy unless timer runs counterclockwise, Set time at 5:30 AM amd go...
For starters, disregard which way the timer runs. Push in the pins for when you want it to power your lights. Turn the dial to set the time of day that it is now. That should be it.
Dec 04, 2010 | Woods 2C 24 Hour Indoor Mechanical Timer...
Can't seem to figure it out. Directions are not specific enough. We set "the time now", but the white/AM, dark/PM is weird. Please help w/ directions. We need the light for chicken house. Light on 5:00 AM...
What kind of Woods timer do you have?
Is the dial turning? The dial is the clock. And the clock needs electricity to work, just like alarm clock. If dial is not turning, the wiring is not right.
Does the manual override turn on the lights? Maybe the slider switch set to OFF? Set slider to "Timer" for timer functions to work.
Wall timer:
If you have 59017 wall timer, it has dark PM white AM. You rotate dial until correct time lines up with little triangle located on right side of center knob.
There are 48 plastic pins on dial ... when pins are moved out, the lights are off. For timer functions, set slide switch to 'Timer'
Correct wiring is needed for timer to work:
Timer black attaches to Hot wire from breaker box
Timer red attaches to wire going to Load (lights)
Timer white must attach to white Neutral (or if your box has no neutral, connect white to bare ground)
Timer green connects to bare ground
If wiring seems right but dial on front of timer is still not rotating, then reverse Timer red and Timer black and see if that sorts out problem.
If this is wrong Woods timer, please re-post question.
Oct 02, 2010 | Woods Hardware & Accessories
Need to find parts for a york timmer model 1103
i have lost the screws that go on the timer wheel to start and stop the timer.
Nov 10, 2009 | York / Cam-stat Compressor Cycle Timer...
I need instructions on how to recalculate the timer. The yard and driveway lights come on during the day instead of the evening. I didn't put the system in....new owner....can't figure out the timer...Help
The RED tripper is for on. The black tripper is for 'off' and the dark colored section of the dial is for P.M., the light colored section is for A.M. Move to desired run times.
Jul 04, 2009 | Malibu Hardware & Accessories
Repair of 1939 Toastmaster Toaster Model 1b6
remove bottom plate.....remove 10 screws holding the bottom brown plastic base...loosen screw under push down lever....romove light, dark knob small center hex screw....cover will now lift off....gently....watch #20 toast "wires"
May 04, 2009 | Kitchen Appliances - Others
Missing screw
The screw is A common machine screw, which you should be aboe to match at an automotive parts store. The clips can be found at any elecvtricial supply house that sells that brand of timer switch.
Apr 20, 2009 | York / Cam-stat Compressor Cycle Timer...
York / Cam-stat Compressor Cycle Timer 2cp04700124 Logo
655 people viewed this question
Top York Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a York Hardware and Accessory Expert? Answer questions, earn points and help others
