Question about Samsung HL-S5088W 50" HDTV
What is the "Smart Debug" setting and the "EER Count" setting
This is in the service setup menu
Tip
ERROR CODE AND SERVICE MODE
Service tool modeHow to access
1. Select [SRV-TOOL] in Service Mode.
2. Press [OK] button on the remote control.
Display of SOS History
SOS History (Number of LED blinking) indication. From left side; Last SOS, before Last, three occurrence before, 2nd occurrence after shipment, 1st occurrence after shipment.
This indication except 2nd and 1st occurrence after shipment will be cleared by [Self-check indication and forced to factory shipment setting].POWER ON TIME/COUNT
Note : To display TIME/COUNT menu, highlight position, then press MUTE for (3sec).
Time : Cumulative power on time, indicated hour : minute by decimal
Count : Number of ON times by decimal
Note : This indication will not be cleared by either of the self-checks or any other command.Exit
1. Disconnect the AC cord from wall outlet.
Hotel mode
1. Purpose
Restrict a function for hotels.
2. Access command to the Hotel mode setup menu In order to display the Hotel mode setup menu, please enter the following command(within 2 second).
[TV] : Vol. [Down] + [REMOTE] : INPUT (3 times)
Then, the Hotel mode setup menu is displayed.
3. To exit the Hotel mode setup menu Disconnect AC power cord from wall outlet.
Troubleshooting Guide
Use the self-check function to test the unit.
1. Checking the IIC bus lines
2. Power LED Blinking timingCheck of the IIC bus linesHow to access
Self-check indication only:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [OK] button on the remote control for more than 3 seconds.
Self-check indication and forced to factory shipment setting:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for more than 3 seconds.
Exit
Power LED Blinking timing chart
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
FOR MODE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE DROP DOWN MENU
on Jun 30, 2015 | Panasonic Tc-50ps14 Tv Power Supply Board...
How do I reset the maintence kit counter for an Infoprint 1532?
This is a lexmark based machine with IBM logo's
1 of the 2 options should get you squared away
---- Option 1 ----
To enter the Diagnostic Mode:
1. Turn the printer off.
2. Press and hold the Go and Return buttons.
3. Turn the printer on.
4. Release the buttons when "Performing Self Test" displays on
the operator panel.
This counter is reset by the servicer after a "80 Scheduled
Maintenance" message displays (300K copies) and a maintenance
kit is installed.
To view the Maintenance Page Count:
1. Select Maintenance Count Value from the diagnostic menu.
2. Press Return to go to the previous menu.
To reset the Maintenance Page Count to zero:
1. Select Reset Maintenance Count. Pressing Select causes the
maintenance page counter to reset to zero.
- Reset Maintenance Count Saved displays momentarily.
When the reset operation is complete, the menu returns to
the Printer Setup Reset Maintenance Count screen.
---- Option 2 ----
Maintenance page count
This counter is reset by the servicer after a 80 Scheduled Maintenance message displays
(300K copies) and a maintenance kit is installed.
To view the maintenance page count:
1. Select Maintenance Count Value from the Configuration menu.
To reset the maintenance page count to zero:
1. Select Reset Maintenance Count from the Configuration menu.
2. Pressing Select resets the maintenance page counter to zero.
Reset Maintenance Count Saved displays momentarily. When the reset operation is complete,
the menu returns to the Printer Setup Reset Maintenance Count screen.
Oct 19, 2010 | IBM Infoprint 1532 Laser Printer
Unlock lg rumor
Call your service provider ...
Apr 28, 2010 | LG RUMOR Cellular Phone
How do i reset the maintenance count?
1. Select Reset Maintenance Count Configuration menu.
Mar 30, 2010 | IBM Infoprint 1532 Laser Printer
Reset maint counter
Page 3-17 of IBM's service guide
Mar 25, 2010 | IBM Infoprint 1352 Laser Printer
Samsung printer error ssg_thnk-32 diag error
try to set your printers factory default settings
10. Maintenance > Of clear Of setting > Of all Of setting [OK]
In the service menu (TECH MODE):
MENU> Of data Of setup > Of clear of count > Of clear Of all CNT
Nov 24, 2009 | Samsung SCX-4300 Monochrome Laser...
Samsung CLP-300, Replace transferbelt messagge on smart panel. Did replace with new,still same message. prints counts did not reset (60002)
you press menu until setup is displayed, right arrow until maint. is displayed. right arrow until check others is displayed. right arrow until transfer belt is displayed, press enter and it will ask count? or reset? choose reset, press enter. press stop to return to main menu...should be done!
Sep 15, 2009 | Samsung CLP 300 Laser Printer
Setting print count on Lexmark T644
I'm assuming you mean the maintaince counters... Turn off the printer. Press and hold the check and right arrow buttons on the front of the printer
Turn on the printer. Release the buttons when Performing Self Test displays. The message CONFIG MENU displays on the top line of the operator panel. Select Reset Maintenance Count from the Configuration menu. The message Reset Maint Cnt=Reset displays momentarily. Press Check to reset. When the reset operation is complete, the menu returns to the Printer Setup Reset Maintenance Count Screen. Scroll down to the Exit Configuration Menu and Press Select to Return to Ready status.
Dec 17, 2008 | Lexmark T644dtn Printer
Debug menu
Try unplugging the set from the AC mains for at least one minute. This may get the set to dump out of the service menu.
If this does not work, call the Philips tech support.
Jerry G.
Apr 12, 2008 | Sylvania 6419 Combo
Samsung HL-S5088W 50" HDTV Logo
98 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
