Question about Gucci Clothing Accessories
1008 51n 5514
HP photosmart 5514 won't print black?
Just experienced this on my Photosmart 5514. The problem turned out to be the ink pump inside which primes the nozzles, there is a hose for the colour head and one for the black. The black side was clogged with old semi-dry ink. After removing the hose from the pump, and soaking it in hot water for about 15 minutes I was able to squeeze out the old ink, now it works like new.
Mar 24, 2013 | HP Office Equipment & Supplies
My hp photosmart 5514 won't print. I put in new ink-black and color- and it goes through the motions, but the page is empty
I just had this exact problem on my HP 5514. Black won't print after running out of black ink. New cartridge no good.
I tried everything-no good. I suspected the pinholes in the printhead were clogged with dried ink because I didn't change cartridge in time.
The fix that worked perfectly was when I hacksaw top off old black cartridge & removed all foam wicks so now I had a funnel(can see clear thru). I installed the cartridge & filled it with alcohol, printed page & did head clean; then printed few more pages. Problem cleared almost immediately. I then soaked up extra alcohol inside cartridge with paper towel. Removed modified cartridge & installed good one. I guess this could be done for colors as well. I don't know if this is a proper procedure, but it sure worked well for me.
Oct 05, 2012 | HP Photosmart 5514 e-All-in-One -...
Tryin to make question mark work
If the ? mark is not working you will have to gently pry up the key and see if the snap in hinge forthe key button is broken or just plain dirty inside there
Dec 26, 2010 | Apevia Acer Aspire AS6530-5514 Laptop
Why wont my computer turn on the battery is fully charged
Your motherboard may be fried. Contact your vendor for repair.
Jan 10, 2010 | Apevia Acer Aspire AS6530-5514 Laptop
My acer laptop mouse is locked and i dont know how to unlock it
Try to enable the touchpad by holding down Fn and hit the F7 key.
Post back for anymore help.
Good luck.
Nov 13, 2009 | Apevia Acer Aspire AS6530-5514 Laptop
Clothing Accessories Logo
Top Gucci Clothing Accessories Experts
Da Doc
Andrew Taylor
Andrew Taylor
arisb
Level 1 Expert
Are you a Gucci Clothing Accessory Expert? Answer questions, earn points and help others
