Question about Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator
The water line in my refrigerator continues to pump water into the freezer even when it is unplugged.
  • 199 Answers
The unit can not "pump" any thing w/o power. You are experiencing siphon effect or gravitational feed.
Install a shut-off valve in the line.
Posted on Jun 16, 2009
Bad fan blower smell and bad smelling and tasting ice cubes from ice cube maker
If unit has a water dispenser, how does water taste? I've run across bell peppers that will emit a bad smell. Keep in mind 95% of all refrigerators circulate air from freezer to refrigerator side and then back. It continues to circulate air so bad produce from refrigerator side will get into freezer side and ice will absorb smell. First, dump all ice. Then line shelves in refrigerator side with newspaper, that absorb smells. You can even try kitty litter in small cups in refrigerator side. Bell peppers gives off that metallic smell and can take some time to get out of unit. Highly unlikely a motor is bad and you've already changed outside water line.
Aug 07, 2015 | Maytag Refrigerators
Icemaker isn't working. Hot water pouring out
Most ice makers do have a defrost element below the ice maker. The problem you described is strange. I would like the model of the refrigerator and brand name. Unplug refrigerator and remove ice maker from freezer compartment now. If water continues to flow you may need the service line that feeds refrigerator turned off until I get your model number. Thanks, Sea Breeze
Feb 15, 2010 | Refrigerators
I recently replaced the water dispenser filter. The original style was no longer available, so I installed the recommended replacement part #MWF. A couple days later the water dispensor stops working. I...
The water supply line going up thru the freezer door has frozen. Quick way to test is to disconnect incoming line at bottom of freezer door and close door and activate switch to see if water getting to the door at least. If it is then you will have to defrost the line in the door with a hair dryer. The area that freezes is near the switches. Slow process but will work. or unplug for 24 hours which is real inconvenient.
Feb 01, 2010 | GE GSS25LGM Side by Side Refrigerator
Water drips slowy into the ice maker causing it to freeze as it comes out of the water line, and then when the ice maker ask for water, it can't fill due to frozen ice at the input hose. How do I make it...
repair or, replace the the electromagnetic solenoid water valve that supplies the icemaker located on the back right corner of the refrigerator where the clear plastic supply tube enters the machine from the house water line
Sep 14, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Exactly the same.
The hose that carries the water from the top coil to the evaporator pan is plugged with ice. You need to leave your unit unplugged for a long time so the ice in the drain hose can melt. If you restart it too soon the problem will not be solved.
Jun 15, 2009 | Gladiator Freezerator Top Freezer...
Icetube leaking water inside freezer and outside back of freezer
Your refrigerator needs a new water valve and possibly some new water tubing. You can find the correct part by going to sears.com and entering the refrigerator's model number in the parts search field. When you have the valve, shut off the water to the refrigerator. If you're not sure how to do that, just shut off water to the entire house. Be sure to run the kitchen sink after you shut the water off to relieve any presure and double check that the water is completely shut off.
Be sure to unplug the refrigerator before you start this project...water and electricity aren't friends! Using a 1/4" nut driver or socket, remove the cardboard or metal cover off the back of the refrigerator. Follow the water line to the water valve, unscrew the nut going to the valve, and remove the water line. There are 2 screws holding the water valve to the refrigerator cabinet; remove the screws and gently pull the valve out. Unplug the electrical connectors and remove the water lines. Take the new valve, connect the water lines and electrical plugs, screw the valve back into place, attach the water line and turn the water back to to test for leaks.
Since the valve has been leaking inside your freezer it would be a great idea to clean out your freezer and let the water tube and lines thaw. Find a place for your frozen food, unplug the unit and let it sit overnight with the doors open. Don't forget to remove the ice bin, as these make quite the mess when the ice melts. Once it's thawed, plug it back in, make sure the water is on and not leaking and enjoy!
Jun 03, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker leaks with or with out power on the far right side
The water valve (or solenoid) that only lets the water through from the water supply line when the ice maker calls for it is leaking you have to replace it.
May 02, 2009 | Thetford Norcold RV Cooler/Freezer
REFRIGERATOR MOTOR CONTINUES TO RUN AND WATER IS LEAKING.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
u
Mar 22, 2009 | Whirlpool ET8CHEXSQ Dryer
Water leaking onto floor
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Feb 23, 2008 | Kenmore 71279 Bottom Freezer Refrigerator
Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator Logo
52 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
