Question about Thermador Freezers
Turn off demo mode
I have a thermador T30IF that is stuck in demo mode - how to I get it back to running mode?
How do I turn the Demo mode off of my GE Upright freezer so my food will freeze
Lisa, you may have to contact the store where you bought it or contact GE. I looked all through the manual a couple time and nothing found on Demo mode. Check the attached links to contact GE for info., last link is USA. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Home GE Appliances
Contact Information
http://products.geappliances.com/appliance/gea-literature-search?Ntt=FUF20DURWW&x=10&y=9
Apr 12, 2016 | General Electric Upright Freezer...
Demo icon is on and some food wind stay frozen
if the machine has been put into 'Demo Mode' the cooling stops working. It is a special setting for when the unit is on the sales floor.... What is the model number and brand?
For Kitchen Aid the way to end DEMO is to hold the 'max cool' and 'cooling on/off' for several seconds until the control beeps...
Apr 12, 2016 | Freezers
How do i get my Kenmore Elite freezer out of demo mode
Which model freezer do you have?
A few possible resets: press and hold the Set and + keys for 5+ seconds. On some models, that will get the freezer out of demo mode. On other models, it's the Set and Down arrow. For a few models, it's the Options and Up arrow. In all cases, it's press and hold both buttons until the unit responds.
I hope you will add a comment with the model of your freezer so that I can determine which set of instructions will work for your unit.
Sep 29, 2015 | Kenmore Freezers
Take PFE29PS out of demo mode
Hold the lock and precise fill buttons for several seconds and a prompt will appear to disable it.
Sep 17, 2014 | GE PFE29PSDSS 29 cu. ft. French Door...
How to put refrigerator into demo mode?
Hello friend, that's a great question!
In order to put your Frigidaire refrigerator FGHB2866PF into demo mode you would need to push and hold the "up arrow" on your freezer and the "down arrow" on your refrigerator for five seconds. Once your appliance has went into demo mode both the refrigerator and freezer display should read 77. Hope this information helps. -Matt
Jul 21, 2014 | Frigidaire Gallery Series FGHB2866PF 27.8...
Freezer and frig not coo0ling. Blinking red lite in freezer. Sounds like fan or motor running. We had a storm come thru yesterday. we have electricity on the appliance.
It sounds like you have one of two issues there. Maybe you need to turn it off and wait for 10 minutes for it to reset (compressor has "vapor-locked" and the freon is not able to circulate through the compressor). The other option to try is that the refrigerator has entered into "demo" mode. This is the mode that it is usually put into in stores so that the compressor is not running, but all other things work for demonstration on a showroom floor. A voltage spike might have shocked it into the demo mode and will work in all ways except for a blinking light indicating the demo mode as well as no compressor activity to cool anything... Look in your operator manual to see if they mention the demo mode and how to enter and exit it.
Hope that helps.. I have seen both of these situations though.
May 29, 2014 | Kenmore 26.5 cu. ft. Side-by-Side...
How can i stop the water from running without shuting off the water
The water valve in the freezer is stuck open. It could be the valve or the control.
May 23, 2014 | Thermador Freezer FREEDOM® T24ID80PLS
Freezer reads off on display
Not sure if its the same for all Kenmore freezer models but this may indicate it is in demo mode. To remove this press the up or down arrow three times as fast as possible (within 2 seconds). This will start the compressor, I hope this helps.
Dec 22, 2013 | Kenmore 14.8 cu. ft. / 419 liter Chest...
I have " E
E1 - Control board problem
Notes: C, E
C:
Disables clean mode in Thermador device, allows cook and microwave
E:
1. Turn the clock selector knob to OFF
2. "Tweak" the oven control by turning the clock selector knob slightly to the left
(counter clockwise).
This may stop the flashing message/beeping and clear the display window.
Hope helps.
Jul 24, 2011 | Thermador T18BF70FSE Freezer
Freezers Logo
85 people viewed this question
Top Thermador Freezers Experts
AJMAL KHAN
marlin siecinski
Roderick Scott
Roderick Scott
Are you a Thermador Freezer Expert? Answer questions, earn points and help others
