Question about Texas Instruments TI-15 Explorer Calculator
My calculator is on op2 and it wont come off
I want it on op1
What choke tubes will interchange with Charles daly o/u .Thanks Steve
Charles Daly Current Production O/U Interchanges with Winchester style threads
https://op1.ec.tc/pdf/opplanet-choke-tube-interchange-guide-2014.pdf
Charles Daly: : interchanges with Trulock's Beretta/Benelli style
Jul 24, 2017 | Firearms
Where can i get a new card for my fax machine make philips
That will need to come from one of Panasonics parts suppliers or more likely directly from Panasonic. Contact Panasonic customer support for any further questions.
Jun 20, 2016 | Philips Office Equipment & Supplies
What does the OP2 code mean
OP means sensor is open OP2 would mean sensor number 2 is open
Sep 10, 2013 | Sanyo SRR49FD
I need know; what is the componnet OP1 (R3B 303)? thanks,,,
Look for numbers on the chip... It appears that in other gear that I can get schematics for Focusrite likes the NE5532 and the NE 5534 chips for op amp service.
Jul 15, 2011 | Focusrite Twintrak Pro
Z1275 produces horizontal lines through images. Flash, auto, program....doesn't matter what mode.
Hi
If your Z1275 has horizontal lines going through the images you should call Kodak Technical service
the number is 18002356325 op1 op12 op2
thanks
hope this help
Byron
Sep 16, 2009 | Kodak EasyShare Z1275 Digital Camera
Camera wont start
For this problem do the ff:
  • this is a Health and Safety issue which kodak advice the users to call the tech to help them with this
  • the tech number is 1800 235 6325 op12 op2
Hope this help
Thanks
Byron
Sep 01, 2009 | Kodak Easyshare M893 Digital Camera
My z612 won't recognize the memory card, and now I can't get it to go to the menu.
For this problem try doing the ff:
  • remove the battery and the memory card
  • Try using the camera w/o the memory card
  • If problem still persist
Call Kodak Tech through this number 1800 235 6325 op12 op2
Hope this will help
Thanks
Byron
Aug 30, 2009 | Kodak Cameras
Multiples
You can still that on the TI 15 explorer (look for constant calculations page 57 in your user manual or maybe the teacher's guide that you can download from education.ti.com)
1. First you define the operation you want to perform, using the OP1 key as follows
[OP1] [+] [6] [OP1] this sequence stores the operation you intend tu use repeatedly.
2. Since you want multiples you must start the sequence with 0
You do that by keying in the number 0
3. Press [OP1] repeatedly.
Each time you press [OP1] a counter shown on the lower left corner of the screen increases its value by 1, and the result (on the lower right corner) shows you the next multiple.
If you just want to add the same number repeatedly starting from some chosen number, in step 2 above use any number but zero.
[OP1] [+] [6] [OP1]
[OP1] [OP1] [OP1 etc.
will generate the numbers 2+6=8, 14, 20 etc.
Hope it helps
Aug 19, 2008 | Texas Instruments TI-15 Explorer...
AV channel on magnavox tv
This worked for my 20" Philips Magnavox 20MT4405/17 TV, it might work for you as well. DISCLAIMER: This is just a solution that I pieced together information from various internet sources, as I could not find a free copy of the service manual to verify this. Furthermore, I am not a technician of any sort.
Enter your TV's service menu by pressing this sequence of buttons on your remote while the TV is on:
062596 Menu
Use the arrows on your remote to scroll down to "Options", push the right arrow to enter options.
Change the 7 options parameters in order to (write down the original values in case this does not solve):
OP1: 065
OP2: 215
OP3: 065
OP4: 162
OP5: 204
OP6: 201
OP7: 000
You need to enter all 3 digits for every number, even if there are zeroes. You use the numbers on the remote to do this.
Turn the TV off with the built in power button.
Unplug the TV for 10 seconds.
Plug the TV back in, turn it back on.
If this does not solve your problem, reset the values of the options in the service menu to the values you wrote down earlier because you have a different problem than what this fix works for.
Nov 05, 2007 | Philips Magnavox 13MT143S 13" TV
Cannot get the "fix" to go off.
How do I clear off fix (rounding) mode on the TI-10 and TI-15?
In order to clear Fix off the calculator just press the following keys
- First press the [Fix] key
- Next press the [.] decimal key
Oct 01, 2007 | Texas Instruments TI-15 Explorer...
Texas Instruments TI-15 Explorer Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
