No sound on channels WYCC and WPWR only antenna tv
No sound on two channels antenna tv only
3 Suggested Answers
  • 105 Answers
SOURCE: Digital channel 25 has no sound.
First make sure SAP or nothing similar is turned on.
After you triple check that just Contact ILO if it continues for more than 1month. This is a software error.
What state are you in?
What channel is this?NBC, ABC
Have you check this at different times of day?
What TV does your son have?
Posted on Jun 24, 2009
  • 43983 Answers
SOURCE: Why is there no sound on one channel?
This could be a problem at the transmitting end.
Posted on Mar 14, 2016
Sharp TV model LC-20AV1U - I need to reset it so I can get it to recognize my over air antenna after cutting cable TV
Hi Loretta,
The reason you aren't getting any channels to work on this TV is because it has an analog tuner. Now a days most channels are being broadcast in digital format and the TV needs to have a digital tuner.
In order to get the antenna to work on this TV, you will need to have an OTA converter that will receive the digital channels and send the signal in analog format to your LC_20AV1U.
Let me know if you require further assistance..
Feb 23, 2017 | Sharp Televison & Video
Mar 14, 2016 | Televison & Video
Cant tune channels
It sounds like you need to do a complete installation as if TV were new.
This is done from installation menu
Feb 14, 2014 | RCA Televison & Video
I just got a new 26" Westinghouse TV, and the screen says "No Channels in List" and when I search for channels, it is not finding any.
What type of antenna are you using? Or what is your source for accessing channels? (i.e. - are you connecting to a cable tv service box or are you using a receiver ect.) Make sure that your source is connected to the input method that you are currently using on the tv.
There are many input methods to choose from in the settings of the tv. They are generally called antenna 1, antenna 2, cable, aux, hdmi - and a few other names. There should be a button on your remote to change them. The function is usually called "source" or "input". Press that button to change the input method until you get a picture on the tv or pick up some sort of reception. when you have the tv set on the same method of input that your antenna source is connected to, you will get channel reception or some sort of picture. Thats when you use the menu functions to auto find channels for you and let it go through its checking scan to report how many it has picked up.
If its running the scan for channels and not locating any stations, and the picture is either scrambled with the white noise sound tv's make when off channel or if its just single color screen without any sound - then you know the antenna input method you have chosen on the back of the tv is not the current method set in the settings under the menu key.
Most of the time the inputs are labeled on the back. If you look under the cable antenna connection, it should say "cable" somewhere in small print - or "antenna 1 input", antenna 2 ect. Look on the back of the tv. If you are using RCA jacks that are labeled right and left for sound and a third connector for video ect, look for the name of the input method of those three connections on the back of the tv. It should be marked as input - aux 1 ect. Then just change the source chosen in the tv to match it and have it auto program your channels.
Jul 06, 2011 | Televison & Video
We can't get any channels to tune in with the over the air antenna.
I solved this problem by purchasing an external indoor HD TV antenna. Once I plugged it into the TV, I received approx 20 channels, picture and sound are fine. The antenna that comes with the TV appears to work only when you are located quite close to the source of the TV signals.
Nov 28, 2010 | Sharper Image TSILCD7PTSD TV
Can we record with our sanyo drw 500 and a digital tv? If so, how do we do this?
If cable/SAT box, hook-up that box video/sound output to DVD video/sound input. If no cable/SAT box, hook-up cable from wall into antenna/cable in on DVD and tune DVD to channel wished, and hook-up DVD TV antenna out to TV antenna in. If DVD has no antenna/cable in, TV must have video/sound output. Hook to DVD video/sound input. Hope this helps.
Apr 18, 2010 | Sanyo DRW-500 DVD Recorder
Sony KDL-32S2010-Chicago area..channel 50.1 (WPWR) is now showing up on 51.3.(found it by accident). 50.1 showing spanish shows. Reinitiated auto tune erased all channels without antenna, then auto tune...
Do a factory reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Mar 27, 2017 | Sony BRAVIA KDL-32S2010 32 in. LCD...
Tv suddenly shows no audio and no video for digital channles only yet all digital channles are detected durring the channel search
Sounds like you have a bad signal from the antenna or the cable. Unlike analog TV if the signal level drops below a certain level you loose the picture and sound completely. The fact that digital channels are detected during channel search does not mean they have a good signal. Try moving the antenna about.
Nov 29, 2009 | Olevia 237T 37 in. LCD TV
No sound on 2 Digital channels 20.1, or 20.2
I left the set completely turned off (unplugged) all day. When I turned the set on in the evening,
both channels had sound. So other than resetting the circuits the problem seems to have been eliminated for now. If it recurs, I'll contact you folks. This is sort of flaky, just last month I had a similar problem with Channel 26 digital in Chicago but that seems to have been resolved. Since I have 2 other Sony TVs in my house and they are NOT experiencing the same problems.
I'm not so sure my next set will be a Sony. Although I do not tune into WYCC digital in Chicago
all that much, I like to know that my set is working properly and that I'm able to look at any channel
20.1 & 20.2 included, without loosing the audio.
Apr 01, 2009 | Sony Televison & Video
I am trying to connect the vcr to the tv with a cable box
There are two ways to connect your equipment.
1) Connect the cable box antenna output (may be labeled "out to TV", "antenna out", "catv out" or even something else, but the key is it will say "out") to the VCR's antenna input. From the VCR's antenna output (out to tv, etc.) you connect to the TV's antenna input. For these connections you use RF cables, the kind with something called F-connectors on the ends. (These cables are available with screw-on or push-on type plugs. Use the screw-on type which makes a more reliable connection.) Set your VCR and TV both on the cable box output channel. This will be either 3 or 4, depending on how the box is set up. With this setup you can record whatever program is coming from the box by having the VCR record on the box output channel. Unfortunately, you can't record shows that are on different cable channels unless you'll be there to change channels on the box. (There are some VCRs that can control a cable box to switch channels, but I don't believe your model does.) You also can't watch one channel while recording a different one.
2) (This won't work if your TV doesn't have a video input available.) Connect the cable box to the VCR and the VCR to the TV with audio/video cables. These are the ones with RCA plugs, color-coded red and white for right and left channel sound and yellow for video. Set the VCR to line input and the TV to the input you have the VCR connected to. This connection setup gives a better picture and sound quality that the RF connection described above. You still have the same restrictions on recording, though.
Sounds a little confusing, I know. Just remember that inputs connect to outputs and you'll be set up in no time.
Mar 30, 2009 | Hitachi Televison & Video
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
