Question about Andis AGC2 Hair Trimmer
Blade latch has been closed accidentally and is locked how do i release it to get blade back on thanks
Blade latch stuck
  • 193 Answers
Put a flat bladed screwdriver under the part of the hinge with two ridges on and pull it up.
Posted on Aug 14, 2014
How do I put the blade on my Ostis PowerMax clippers? I have tried with it on and off with no success. Thank you.
The blade release should be under the heel of the blade, just below where the blade tongue hinges. You normally only need to press it when removing the blade, when snapping the blade shut it is mostly not necessary to push it. They are a bit like a door latch that self lock when closing.
Feb 17, 2015 | Oster PowerMax 2-Speed Clipper Kit
My 2000 olds bravada glove box door is stuck open the latch won't let me close it. Even though there is no way to lock it it seems locked! Do I need new latch or can I fix this one?
Your latch might be in the closed position before you even close the door, try using a small screwdriver on the latch while pressing the release button, if it's stuck closed then this will open it to the right position so it will lock closed when you close the door. If this does not work, sometimes the problem is in the striker (the little tab that the lock hits when the door is closed, this usually has 2 small screws holding it in place, you should be able to loosen both screws & adjust the striker forward or backward so the latch will make better contact with it.
Jan 06, 2015 | Cars & Trucks
I have a flat top fridgedare stove.I accidentally hit the clean button and opened the door but the latch had locked now I cant close door and oven wont come on and it just keeps flashing loccked.It doesnt...
The latch is solenoid operated. remove power from the stove (unplug or breaker). That should release the lock. Close the door and power back on. Hopefully all will be reset.
Aug 03, 2014 | Kitchen Ranges
What do I need to do to get my door to stay closed and locked?
Possible stuck latch mechanism might need to replace. Send me a picture of the door latch. The one in the door
Jun 09, 2017 | 2005 Toyota 4-Runner SR5
Rear lift gate lock stuck in the closed position
use a round bar under the lock tongue and pull it back as you press the button to open the latch
Jan 06, 2014 | 2008 Chevrolet Uplander
OVEN DOOR LATCH BLOCKS THE OVEN DOOR FROM CLOSING ALL THE WAY. I CANNOT GET THE DOOR LATCH TO RETRACT.
Hi
There could be couple things. First, try pushing the door closed as you turn the handle. The latch may have dropped into the strike hole completely, binding the latch. Or you may try lifting the door as you try and open it. Friction is the one thing that most often happens causing a latch not to retract.
Another possibility is that the latch may have become detached from the knob set. If this is the case, you will have to remove the lock from the door, and from there you can open the door with a flat blade screwdriver. I recommend replacing the latch as well. If you remove the lock from the inside of the door, using a flat blade screwdriver you can pull the little 'T' that sticks out from the latch on the inside of the hole. This pulls the latch back away from the strike, allowing you to open the door.
There are different configurations of latches, and they activate like way. You could run into a long latch the lock runs through. You can use a large flat blade to activate that. If you have the type with the half moon, use the outside of the lock body, stick it into the half moon, and turn the whole thing to retract the latch.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 07, 2011 | KitchenAid KEHC309JSS Electric Double Oven
I accidentally pulled the interior trunk release of 2008 volkswag
Try a screw driver,and release the trunk release at the same time and unsnap the latch,the latch thinks it is closed,because the latch never opened back up to allow the striker to go in it and trigger the latch to close,the latch is in closed mode,you will have to manually unlatch the latch sort of speak.
Apr 21, 2010 | 2008 Volkswagen Jetta
1995 Chev Suburban rear door latch stuck in locked position
sounds like you lached the door
use a screw driver or some such tool
lift the outer handle and slip your tool in the middle of the lock hole in the door flip the lach open wile holding handle up
Dec 31, 2009 | 1999 Dodge Ram
Our Bosch SHY66C05 door latch is stuck in locked position
you have to pull back the spring or replace the lock. the repair is pretty easy.let me know what happen.
Nov 07, 2009 | Bosch 24 in. SHY66C05 Stainless Steel...
Andis AGC2 Hair Trimmer Logo
96 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
