Question about Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D
White smoke coming out of carb. its a model # 130905-368-01 rear engine toro riding mower.
  • 76 Answers
You are either running to rich or your timing is off and your valves are opening before your spark hits you may have bent valves also and they are not seating properly you should be able to check this and change your valves if need be you have to seat them just like a car if you need more help let me know i can walk you through this but i will need motor h.p. and model and serial #s on the motor
Posted on Jun 29, 2009
Why when I couldn't start my toro 6.5 gts lawn mower with tecumsuh engine,I sprayed carb cleaner into carb and it started but smoked and knocked. what caused this problem?
bob if you spray carb cleaner in and it started that is a sign of not getting fuel. but if it is smoking and knocking you have a bad outlook for that engine. did you hit anything with the blades while mowing that caused it to stop suddenly? did you tip it on its side as the oil may have run in the carburetor. that can cause the smoking. does it have to much oil in it?
Apr 28, 2016 | Toro Garden
White smoke coming out of front of Husqvarna riding mower
it might not have been over filled with oil i have seen many needle valves not seating in the carb the gas over fills the carb and drains into the crank case thinning out the oil and if not caught in time i scores the cylinder wall
Jun 02, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Husqvarna riding mower blowing white smoke out front
check the oil does it smell like gas the needle valve is not seating and gas over flows the carb and dumps it into the crank case
Apr 28, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
I have a toro z master that has white smoke and oil coming out of muffler. the compression is fine. what can be causing this?
check the oil and see if it smells like gas and over full the needle vavle in the carbs leak then the carb overflows into the engine change the needle and seat then change the oil a couple time then add a shut off valve in line on the fuel line and if the oil doesn't smell like gas and overfull then the head gasket might be blown
Apr 24, 2012 | kawasaki Garden
I have a Toro Zmaster mower The engine is a FH580V KAI19. It was running fine. Parked the mower last night, tried to start it today and oil is coming out of the OHV cover and blowing by through the...
you could have a broken piston ring. check the oil level. if it is ok or low and still smokes or hard to start then you may have to overhaul the engine. let me know what you find.
Mar 13, 2011 | kawasaki Garden
Put some oil in Toro Z400 mower, engine smokes a lot (white
yes sounds like it, take your sparkplug out and clean or replace it and crank engine over a few times to blow out any oil in the cylinder
May 19, 2010 | Garden
White smoke and blade won't engage
Sounds like a low compression problem. The piston rings have most likely failed and oil is seeping past them and burning, thus the white smoke. An engine needs three things to run...Spark, Compression, and Fuel. Just take the mower back as it is still probably under warranty. Mike. Rate 100% please.
Jul 01, 2009 | Toro Lawn Mower With Toro Power Tools
Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D Logo
782 people viewed this question
Top Briggs & Stratton Hammering Experts
rlev_7
Level 1 Expert
JOHN LAPIER
Matt Olenzek
Matt Olenzek
Are you a Briggs & Stratton Hammering Expert? Answer questions, earn points and help others
