V zon lcddvd3250
2 menu boxes stay on the screen at all times
I have an RCA projection TV, model D52W19B. The TV powers on ok, stays on, and audio is normal. I don't get a picture. If I press the menu button, the menu will appear on the screen normally.
my guess is you either have a satellite or cable box try unplugging the system cable or satellite and set for 5 minutes and then plug them back and and restart the unit up and see if it comes back the gemstar module would some times lock up causing this problem . and please let me know if that get's you working or if there is more trouble shooting to be done
Nov 03, 2014 | RCA Televison & Video
V zon
try to go to the Menu, AND reset to the factory defaulty. Read your owner manual section troubleshooting for fix it. Download from www.fitness.manualsonline.com or www. retrevo.com
God bless you
Nov 20, 2013 | Coby Electronics Corporation Coby...
No audio input from TV on DVD Home Theatre
U have audio signal incompatibility. If the audio output is digital it may not work with an analog input, etc.
May 08, 2017 | Audio Players & Recorders
I GOT A V.ZON TV AND WANTS TO PROGRAM D REMOTE WITH TIME WARNER ,WHAT IS D CODE FOR THE TV
I have a V-Zon 26" Flat screen TV with terrible sound. I'm told that you can use external computer speakers. There is a phono jcak on the rear of the TV. Does anyone know how to activate that jack to use the speakers?
Dec 09, 2010 | Televison & Video
Coby v.zon tv remote universal code?
10030 v zon remote code for comcast
Oct 09, 2010 | Televison & Video
My coby v-zon dvd player is less than a year old & when I turn it on the picture comes on clean, then becomes distorted to where I cannot view my disc. is there any technique available to fix this...
I had a similar problem with my portable V Zon player. It would sometimes come on with the V Zon blue screen and work fine, then sometimes have no picture but have sound. I knew the DVD drive was working so I removed the back of the screen. The white cover has two small screws in the bottom and then the white cover just pops off (carefully pry it around the edges.) I traced the problem to the plug that supplies power to the screen ( a white plug with about 10 small red wires attached.) the plug itself was weak and I had to remove it from the socket, clean the connections and carefully pry it back into the socket. It is working fine now but I know where the problem lies if it starts acting up again. You may want to add some dielectric grease to the plug and socket, available at electronic supply stores and auto parts stores.
Jan 15, 2010 | Coby TF-DVD7307 Portable DVD Player
My monitor menu settings box keeps coming on right in the middle of the screen. Sometimes it will go off when I push the ''exit'' botton. But it goes on and off all the time. It makes it hard to do...
Sounds as if the "menu" button is making intermittent contact. Try spraying it with an electronic solvent (available from most Electrical/Electronic outlets. e.g. RS Components) and press it many times (Power off!). This may rid the button of any gunk in there.
Aug 07, 2009 | Computers & Internet
BLACK BOX PROBLEMS: Insignia TV/DVD combo
The black box is caused by the Closed Caption option of the tv. Go into the menu and turn it off.
Jul 18, 2008 | Insignia IS-LCDTV32 32 in. Television
No backlight
A couple things to try:
1st check the backlight settings
Turn on Backlighting and Control Brightness To use your device in dark environments, enable the automatic backlighting feature:
  1. From the Jump screen, press MENU t02003-15.gif then select Settings > Battery & Display.
  2. In the second group box, select the Turn on backlight when using device check box.
  3. Highlight, then select the Brightness slider to open it for editing. Roll the TRACKBALL right to increase brightness; roll the TRACKBALL left to decrease brightness. After you've made the adjustment, press the TRACKBALL to exit edit mode. t02007-55.jpg
  4. Select the length of time you want backlighting to stay on from the Turn off after pop-up menu.
  5. To use the device's light meter while the backlight is on, select the Use ambient light sensor check box.
  6. Press JUMP t02003-14.gif to return to the Jump screen and save your setting.
Now, when you press any button or key, or flip open the screen, backlighting will turn on for the set amount of time. Note that as long as you press a key or button before the set time elapses, the backlight will stay on.
Tips:
  • Even if you have not selected automatic backlighting, you can turn on backlighting at any time by pressing MENU t02003-15.gif + JUMP t02003-14.gif . The backlight will remain on for the time specified in the Backlight Turn off after pop-up menu.
  • When in key guard mode, you can turn on the backlight by pressing the RIGHT SHOULDER t02003-66.gif button.
If it still does not work, then you can try resetting the flex cable to the lcd.
Reseat the SidekickFlex cable
If that doesn't fix it then a new lcd assy will take care of the issue. they run about 45 dollars on ebay.
Sidekick LCD screens
Apr 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
