Question about Fujitsu fi-6230 Flatbed Scanner
Scanner will not form feed
The scanner will not scan when papers are placed in the chute
    New Friend:
  • 25 Answers
There is an option in the dialog box where you select the paper source either ADF (chute) or flatbed. The options differs depending whether you are using twain interface for scanning or isis.
You need to select the proper source. If the paper source is correct then, probably, the paper sensor in the chute unit is not operating properly.
Posted on Apr 21, 2014
2 Suggested Answers
  • 59 Answers
SOURCE: My Scansnap S510 has been working fine till now. I fed the paper like always and pushed the scan button and nothing happened...it did not feed the paper through...What do I do
Did the light start blinking? Unplug the USB cable from the scanner, and replug.
Posted on Oct 28, 2012
Paper Feed Problem
Try changing the exchange rollers (Feed, pickup, and retard rollers)
Mar 27, 2014 | Canon DR-7580
Fujitsu fi-5650C Error U1
Hello Ismail,
Error U1 referes to Frequent paper jam in Fujitsu fi-5650c scanner. In order to troubleshoot your scanner issue, you are advised to follow the steps provided below:
1. Do the documents satisfy the paper specification?
2. Have the documents been prepared properly?
- Align the edge of documents for stable paper feeding.
- Remove documents with creases or dog-ear corners.
- Scanning different widths documents may cause skew and result in paper jam.
3. Is the imprinter EXT cable connected to the scanner properly? (only when the imprinter is installed)
4. Clean the Pick roller, the Separation roller, the Brake roller and the Chute roller and see if the error is resolved.
5. Clean the Feed rollers and the Plastic rollers and see if the error is resolved.
6. Replace the Pick roller, the Brake roller and the Chute roller, and see if the error is resolved.
- Check the consumable counter in the software operation panel. When the counter exceeds the values, replace the Pick roller or the Brake roller.
If the above steps do not help, then yuo are recommended to contact the nearest Fujitsu service center for assistance.
Thanks & regads,
ScanCare
Dec 16, 2013 | Fujitsu fi-5750C Flatbed Scanner
Fi-6130z fujitsu scanner jamming repeatedly
Hello Meg,
To troubleshoot your scanner issue, yuo are advised to perform the steps provided below:
1.Remove all documents from the ADF paper chute.
2.Open the ADF while pressing down the ADF open lever. If your has the imprinter option attached, please open the imprinter and then open the ADF.
3.Remove the jammed papers from the ADF.
4.Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, then please check the followings:
1. Do the documents satisfy paper specification?
2. Have the documents been jogged?
• Align the edge of documents for stable paper feeding.
• Remove documents with crease or dog-ear.
• Scanning different width of documents may cause skew and result in paper jam.
3. Are Chuter Unit (ADF paper chute),Guide P ASSY (Sheet guide), Feed roller cover (plate guide) and Brake roller cover installed correctly?
4. Clean the Feed rollers, Eject rollers,Plastic rollers, glass surface and paper feeding surface, and see if the error is resolved.
5. Check the consumable counter from the TWAIN driver screen. When the counter exceeds the values, replace Pick roller or Brake roller see if the error is resolved.
6. If the issue still persists, then you are recommended to contact the nearest Fujitsu service center for further assistance.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Nov 26, 2013 | Fujitsu Fi6130z Sheetfed Scanner
My fi-5220C says No paper on ADF paper chute or Hopper. (Code: Ds32003)
"No papers on the Chute unit" error occurs when the Hopper empty sensor detects no paper loaded on the Chute unit at the receipt of a Feed command.To recover this, Load documents on the Chute unit.
1. Does the same symptom occur after turning OFF and ON the scanner? Press power button of the scanner for more than 2 seconds to turn it OFF, and after more than 2 seconds elapse, press the power button to turn the scanner ON.
2. Is there a slip of paper left near Hopper empty sensor? Open the ADF and check inside visually.
3. Check the performance of Hopper empty sensor. Conduct Maintenance mode to see if the sensor works properly.
If the error still occurs, confirm that the cable is correctly connected then replace the sensor EM.
Thanks & regards,
ScanCare
Oct 02, 2013 | Fujitsu Office Equipment & Supplies
Error J1
Hello Sharon,
When a document jam occurs, "J" and "1" will display alternately on the function number display panel of the scanner.Please perform the following:
  1. Remove all documents from the ADF paper chute.
  2. Open the ADF while pressing down the ADF open lever. If you are using fi-6130 with the imprinter option attached, please open the imprinter and then open the ADF.
  3. Remove the jammed papers from the ADF.
  4. Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, please check the followings:
resolved.
5. Replace Pick roller or Brake roller, and see if the error is resolved.Check the consumable counter from the TWAIN driver screen or from the built-in Maintenance mode. When the counter exceeds the values, replace Pick roller or Brake roller.
Thanks & regards,
ScanCare
May 03, 2013 | Fujitsu Office Equipment & Supplies
Documate error 8
Hello.
I am a Support Engineer with Xerox Scanners.
E8 is a Paper Jam error that could be caused by:
- paper crumpling during scan.
- paper is multi-feeding all at once instead of feeding separate.
- scanner continuously tries to feed after paper has fed through.
if the paper is crumpling during the scan, make sure the inside of the scanner is clear of any obstructions. use the paper guides in the ADF tray to keep the paper straight when feeding in.
if the paper is multifeeding while scanning, fan out the pages before inserting them into the scanner. if problem persists, try cleaning the rollers with rubbing alcohol and a lint free cloth.
if scanner tries to continually feed after the paper feeds through, the ADF tray will need to be reseated. open the scanner and remove the ADF tray at the top. line up the 4 keys at the bottom of the tray with the 4 corresponding key slots inside the scanner. push the tray back until it clicks into place.
We also have an extensive support site and knowledgebase at
http://www.xeroxscanners.com/en/en/support/
If you continue to experience trouble, please feel free to contact us by calling 800-648-0410.
Regards,
Xerox Scanners Support
Jan 28, 2013 | Xerox DocuMate 162 Pass-Through Scanner
Want to use my scanner
First in Windows Explorer make sure the scanner can be seen.
If it is there right click on the properties of the scanner. Under the events tab, select the application to open after for scan capture (ScandallPRO, Photoshop, Adobe, etc.).
Just place the page in the paper chute and press the scan button.
It will scan the page and open the Application. Then you can do what you wish.
Jun 01, 2008 | Office Equipment & Supplies
Why does the scanner hesitate when feeding the paper through the scanner and gives a scanned double image at the top of the page?
Is there a gear grinding noise associated with this? If so, call your local dealer for service. If not:Clean all the rollers you can reach with a cloth dampened with alcohol. Check for any obstructions in the paper path like torn paper, heavy toner buildup on guide plates or the edges of the scanning glass, or any paper guides obviously loose or out of place.
Nov 20, 2007 | Canon DR-3080CII Path-Through Flatbed...
Fujitsu fi-6230 Flatbed Scanner Logo
112 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
