Question about Mitsubishi WD-73738 Medallion 73 3D DLP HDTV
MITSUBISHI wd 73738 remote control doesn't work
Kid was praying with remote know it dosn't work
3 Suggested Answers
chesterpendi
  • 195 Answers
SOURCE: My 73'' mitsubishi model #wd-73738. Is flickering.
Hi!
That's a clear indication that you have a bad power supply in your TV.
If you know how to DiY...I suggest you open your TV. Locate the power supply section, it is where the end of the power plug is connected. Replace all blown or bulge or leaked capacitors with same value. That will fix your TV problem.
The hardest part is to disassembling your TV cover, cause you will need to pry off the snap in lock at the edge of your TV.
Power supply board should look like this. Examine the capacitors in the board
After replacing blown capacitors...it should work again.
Things you will need.
1. A plastic flat end screw or any object with flat ends....to fry off the cover
2. Soldering iron.
3. Soldering lead
4. Soldering pump.
5. Flat and Philip Screw
6. Replacement capacitors (of same value with the blown one) that you can buy to any electronics store.
Or try replace light engine..if the above solution won't work..
Posted on Feb 23, 2012
wolfz839
  • 7 Answers
SOURCE: mitsubishi 73 inch wd-73738 no picture
Take a flashlight and at a angled view see if you can see the picture, if you can the lights burned out in the back
Posted on Oct 22, 2012
Mitsubishi wd-73738 turns itself back on
It sound like the remote is powering off the cable box but not the TV. The remote control may need to be reprogrammed to the TV. When you press power it may only power off the Cable box. At that point, try pressing the TV button on your remote and then Power. If it does not power off the tV after pressing the tV button, the remote may need to be reprogrammed to the tv. Cable companies usually have the codes needed to program their remotes to the TVs.
Jul 09, 2016 | Mitsubishi WD-73738 73" 3D Ready DLP HDTV...
Replaced bulb in mitsubishi WD-73738 tv now it works for about 20 minutes and then flickers and smells hot
Cooling fan gone and cutting out on overheat? These projections televisions are so old tech :>)
Oct 14, 2015 | Mitsubishi WD Televison & Video
4red and 8 yellow code flash
I cannot post URLs here. Please try go googling this: "WD-73738 error codes"
The first result looks promising
Aug 18, 2014 | Mitsubishi WD-73738 73 inch DLP 1080p...
I have a mitsubishi 73 inch tv model WD-73738. No picture with sound - why is this ?
sounds like the psu. power supply unit. check the caps are not bulged
May 17, 2014 | Mitsubishi Televison & Video
Remote control not working on the tv. Factory remote and cable remote
Hi, first try camera test (video below). If it is not transmitting a signal then it is defective. You should purchase a new one (link below.) MITSUBISHI 290P187020 TV Remote Control
Jan 04, 2014 | Mitsubishi WD-73738 Medallion 73 3D DLP...
Mitubishi wd-73738 turns off after 1 min
Weird noise is high pitched or even grinding sound? Sounds like a fan but is not?
Dec 14, 2012 | Mitsubishi WD-57833 57" HDTV
Mitsubishi 73 inch wd-73738 no picture
Oct 21, 2012 | Mitsubishi WD-73827 73" HDTV DLP TV
Hi!
2. Soldering iron.
3. Soldering lead
4. Soldering pump.
Feb 23, 2012 | Mitsubishi Televison & Video
Mitsubishi WD-73738 Medallion 73 3D DLP HDTV Logo
16 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
