I am getting crackling and popping noises coming through my amplifier when my foot is actively engaged in pedaling.
I have an older Ernie Ball mono volume pedal, maybe built in the '80's. I am getting intermittant popping and crackling noises coming through my guitar amp while playing my stratocaster--seemingly most often after a bit of pedaling activity. It seems that if I keep my foot in constant contact with the pedal, the popping noise disappears. I have checked all electrical connections, and they seem sound. Because this passive pedal has a twine-on-rotary knob mechanism, it seems to me it could be static electrical buildup and discharge that is the cause.
Using a common lead pencil, gently tap on the smaller tubes in the unit, listening for noises and crackling to change and the drive channel changes.
It is normal to get a slight twang when doing this from the microphonics of the tubes, however, the crackling and up and down volume points to a bad tube.
With everything switched off. I will surmise that you are using the onboard battery with the foot pedal and not a power supply.
1. Plug lead from guitar/instrument into INPUT side of pedal
2. Plug lead from OUTPUT side of pedal into amplifier INPUT.
3. Turn amplifier volume to about 10 o'clock - to stop blowing your ears out.
4. Turn volume up on guitar to acceptable level.
5. press foot switch on pedal and adjust pedal controls to suit your type of distortion.
6. Play like Hendrix.
Good Luck
ps Just as an after thought rechargeable 9volt batteries are the way to go. I've been using them for years as I always get caught up in the power cable.
If you're going to add another pedal like a Phaser, Compressor, Flanger or what just use small connect leads between each pedal but always, always put the compressor pedal last in the line.
Good strings. Ernie Ball has been around for years. Not only strings but teach yourself books, scores, guitar accessories. The late Jeff Healey only used Ernie Ball Slinky Electric guitar strings. If you haven't listened to Jeff Healey and you thought Jimi Hendrix was good have a listen to this guy and remember he's blind.
Good Luck
Ah yes, the Fender Hot Rod Deluxe. I have seen more of these in my shop than any other amplifier!! I have even sent recomendations for design changes to Fender about this amplifier.
Sadly, your amp tech may be correct: while the amp is within working specs, you can still have an issue with a bad socket. The cheapest thing to try is to replace the preamp tube(s) you think may be causing the problem. If the problem persists, it may need to be serviced on this issue (by a different 'certified Fender tech'). In defense of the last tech you had work on this amp, these amplifiers have a brittle design and do not gig or travel well (there are a minority of these amps made that do perform). Fender tried to do too much for the price on this model: best advice is to fix it, sell it and get your tone with a more stable model made by Fender (like the new vintage re-issues). Fender, like Marshall, has for years been having problems when they get too far from thier 'working reciepe' of what made them great companies.
You likely have a socket that needs re-tensioned, or a preamp tube not behaving. If it is not these, then a tech had to dive in the house of cards that is this circuit. Sorry for the bad news on this, but it is the truth. I only take on Hot Rods that 'appear' to be fixable. I am a development engineer, build amps from scratch and fix them for the local music shops, and my success rate is a dismal 60%-ish percent on these...
Thanks,-mike
Run a jack from your guitar to Input R Mono on the pedal.
Run a jack from Output R Mono on the pedal to the input of your amplifier.
There is a switch for guitar or Bass. Put the swich on guitar
You do not need a preamp to use this pedal.
Hope this helps,
Maxx.
