Question about Sewing Machines
How to use singer apricot swing machine
How to use my singer apricot 9700
  • 210 Answers
Carefully and slowly to begin with ,,,, then you can go mad and as fast you want in my expeirence
Posted on Mar 29, 2014
To adjust the singer 500 rocket sewing machine ....adjusting the width .... the swing of the zigzag.....
I am attaching two links for manuals in case you don't have them, an instructional manual and a service (repair manual). The Singer 500 and 500A are the same machine.
Singer 500 Owners manual
Singer 500 503 Service Manual
Jul 30, 2017 | Singer Sewing Machines
How do I time a Singer Swing Machine - 5808C?
My first question on this is WHY you think your machine needs to be retimed? What is it doing/not doing that makes you think so?
Dec 04, 2014 | Singer Sewing Machines
Singer apricot 9700
Find a manual or google the machine on line
Mar 29, 2014 | Sewing Machines
The needle moves from side to side
It should... this is a swing needle machine. Does it stitch patterns correctly?
Mar 04, 2014 | Singer Confidence 7469 Mechanical Sewing...
All of a sudden my Singer Inspiration 4206 stopped working. When I press the foot peddle it only makes a swinging sound like when you're only swing a motorcycle but not driving it. If I turn the hand weel...
If the swinging sound is from the motor, right side just below your hand wheel, possibility your motor belting is loose or broken. If you don't have mechanical skill / experience, suggest to get your local technician to fix it.
Nov 10, 2013 | Singer Inspiration 4206
Singer apricot 9700 manual
check with sewusa.com about a manual
Aug 06, 2012 | Sewing Machines
Singer 9700 manual
go to the website of sewusa.com & see if they have a manual
if not email them about one
I would like to know how to change the light bulb, it is not stated in the handbook?
Call Singer at 1-800-4singer and ask them, it is amazing that they do not have it listed in your manual and the front cover does not swing open.
Jan 17, 2011 | Singer 7426 Mechanical Sewing Machine
Singer machine 221(an old one made in 1935) worked perfectly. I decided to oil it. I took off the throat plate, took out the bobbin, cleaned and oiled..now the needle hits on the bobbin case and will not...
If you look at the bobbin area with the bobbin case out you will notice a finger that will be swinging around and will settle at bottom when the machine is setting on a table. This finger needs to be pointing straight up at the 12 o'clock position, in the slot in the bottom of the stitch plate. When you remove the plate, it swings down and you may not notice. Lift the plate and fit the finger into the slot between the two bumpers on the bottom of the plate and I'll bet it will sew again.
Dec 13, 2010 | Singer Sewing Machines
Singer futura ce-200 problem, pattern mis-alignment
I have had similar problems in the past.
Do you hear a noise from the embroidery unit when the misalignment occurs ? If so, I suspect that your issue may be that you have some resistance under the hoop. Is there extra material that may be rubbing on the machine or catching somewhere. I have found that if I use some masking tape to keep all of the extra material from hitting any other parts of the machine or dragging under the edge of the hoop this error does not occur. FYI: I also stopped using the "optimize stitch speed" option at the same time. I believe that material dragging was causing the problem, but I still wonder about the stitch speed optimization feature.
Jun 03, 2008 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
70 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
