Question about DIGILOCK Ats-619-01-21-gr01 Shared Use Keypad Locks,standard Keypad 4ggy3
How do I open my digilock if I forgot my combination
I have a locker room locker with a digilock and forgot my combination. How can I open or reset my combination on the lock?
Our suitcase is locked, and we forgot the combination. how can we reset the combination for our TSA approved luggage?
resetting the combination is only practical if the suitcase is open as the reset tab is located inside where it cannot be tampered with when locked.
if it is a set of dials lock a locksmith could help you.
regards,
Mar 25, 2018 | Luggage & Travel
Change code
If it is locked and the person you got it from didn't give you the existing code, you can't. We see this all the time. If there was a way to bypass the code to the safe, anyone could do it. They are called a 'safe' for a reason, the contents are safe once the door is closed and locked :-) The only way to get in is to take to a locksmith who will drill the door, open it and put a new door on it. This is not usually a cost effective open with a small locker type safe.
Nov 23, 2015 | Home Security
Forgot my Presto Lock combination!
You cannot reset the lock unless you know the combination. You would need someone to pick the lock, like a locksmith and then once it's open you can reset the lock with a new combination.
Jan 25, 2013 | Locks & Locksmithing
My disk D says me when I try to open it do you want to format? how Ican solve this
u have to install window 7 again in ur pc , If u install window 7 than bit locker again give u option to unlock the disk using password but if u forget ur password of bit locker then it give u another option to open it, and this opition is to fill the recovery key into bit locker if u saved it and it is different to all driver ,if u also do'nt have this than there i s no method to open the hard drive without formatting it
Jan 15, 2013 | Computers & Internet
I forgot my mobile password from onida mobile? please give the solution to open my mobile my model no is v140
you can have a password reset at from your costumer care center. but some times they will choose for a software update, which will loose all your data s.so better specify them to have only the password reset.
Aug 23, 2012 | LG Cell Phones
I dont have the keys for godrej taurus safe locker and i forgot the lock code
i dont have the keys for godrej taurus safe locker and i forgot the lock code
Feb 20, 2012 | Safe International Safelock Front Loading...
I hv a safewell safe. i locked the emergency key before setting my personal key inside the safe. how to open the safe now?
You'll most likely need help from a locksmith. Basically, the lock can be picked, to get the safe open. There might also be a factory pre-set code.
Aug 16, 2011 | Locks & Locksmithing
HOW TO CHANGE LOCK COMBINATION IN A SAMSONITE LUGGAGE OYSTER GL
I forgot my locker combination and my luggage is locked.How can I open it??
Nov 13, 2010 | Samsonite Silhouette 11 Hardside Spinner
I forgot my locker combination to a lock and and i cant open it.
how do i get the box open . the box is 5400D portable key storage i'm a realtor
Sep 17, 2008 | Master Lock 5400d: Portable Select Access...
DIGILOCK Ats-619-01-21-gr01 Shared Use Keypad Locks,standard Keypad 4ggy3 Logo
126 people viewed this question
Top DIGILOCK Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a DIGILOCK Retail Supply Expert? Answer questions, earn points and help others
