Question about HTC touch Computers & Internet
Htc T3232 phone problem
I have HTC T3232 phone and it was used in Singapore (Starhub sim used). It was brought to India when I changed the sim card it stopped working. Without the sim the phone works fine. But the moment I put the sim it goes off. What could be the problem? I have hard set the phone several times but in vein.
SOURCE: HTC
Try this link:
http://forums.wireless.att.com/cng/board/message?board.id=cingular&thread.id=84238&page=1
Posted on Jan 11, 2009
zohail
  • 1223 Answers
SOURCE: sim card missing for htc touch p3450
its a hard ware issue try putting a piece of paper over ur sim card to press it against the pins on the phone sometimes it gets loosen and does not detect sim cards or try restting the device as follows else go for service centre help but try these solutions first
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
Posted on Feb 20, 2009
neogil22
  • 36 Answers
SOURCE: I need internet and mms settings for htc s620
Hi...
Why don't you call or sms the customer-service of your provider?
they will send you an sms with the settings for the phone.
friendly greetings, Gilbert.
Posted on Mar 10, 2009
Craiglloyd
  • 33 Answers
SOURCE: HTC Touch - NO SIM
Straighten and lift the pins on the SIM card reader in your phone. (There are four pins under the silver metal back plate of the SIM card reader and all should be the same) Reinsert your SIM card and it should work.
Posted on Apr 02, 2009
SOURCE: HTC Tilt (Trouble Reading SIM Card)
I posted a little too early. There was one other trick I've used and I guess I should have started with that. The problem is indeed related to the SIM not getting enough downward pressure on the contacts to be recognized.
So I took a small strip of paper, about 3/8" by 1 1/4". I folded it three times. When you fold it one end will be closed and the other end will have the two edges of the paper that can open up. Using the open end will make it harder to slide under the bracket. So you will want to take the closed end and gently side it above the SIM card underneath the silver metal bracket that holds the SIM in place.
I used a post-it note as the paper but anything will do. It was working with just a double thickness but I wanted to be sure so I moved up to three layers. Depending on the tolerances of your phone you might be able to only do double layer and still be able to slide it in. Or you might need to go to four layers.
I hope this solves it for you.
/text for Google's indexes so others can find this: HTC Kaiser 8925, Cingular 8925, AT&T Tilt 8925, SIM Card is missing,
Posted on May 15, 2009
My htc jade t3232 the simcard cant ditect
IT MUST BE PROBLEM OF SIMDRIVER HARDWARE PROBLEM
Jan 14, 2013 | Cell Phones
Htc jade t3232 simcard not ditected
Try different sim card. If still problem remains then your phone network may be locked.
Consult: http://www.guaranteedunlock.com/HTC_Jade?filter_name=jade
or contact their support e-mail.Goodluck!!
They are reliable and professional.
Jan 14, 2013 | HTC Touch 3G T3232 Jade 160 T3238 T4242...
Music not play in HTC t3232
Hope SD card had been corrupted.
Please try it with other SD card and see whether it happen again.
Thanks for using FixYa!
Sep 15, 2012 | HTC Cell Phones
Music its not open that time error alarm comes
Change new SD card and see.
Sep 15, 2012 | HTC Touchâ„¢ 3G Cell Phone
Hi there,i had purchased htc thunder bolt a month ago from Miami US and since it was a lock piece i also bought unlock code online.Now the biggest challenge i am facing is when i put my local active sim...
Hi, i think your step not correct when entering HTC Thunderbolt unlock code. You must use your old sim card to unlock your phone, don't use new sim card before that phones completely unlocked. That's why your sim card not recognized. If this method not working maybe you get wrong HTC unlock code, since it's little rare for me. Usually if you bought unlock code reputable online store, they usually send unlock code with complete instruction how to insert that unlock code in your phones. The bottom line try my method and if not working get new code. Thanks.
NB: don't enter your wrong code to many times in your phones, it will caused your HTC to hard locked state and you can't use that phone even you put your old sim card.
Jun 03, 2011 | HTC Thunderbolt (8 GB) Smartphone
Facing peculiar problme with my HTC Cruise Phone
Hi Nitin,
Select the network manually and try if other parties are able to reach you without any trouble.
Jan 08, 2010 | HTC Touch Cruise Smartphone
I bought a UTC Touch 3G in Singapore fot use in Australia. I can see it has an option to connect to the 850 MHz band used by Telstra in rural areas but it does not connect via that frequency. Any...
Do you have the latest ROM installed? If it is a non-branded HTC you can look on the HTC website, otherwise you will need to check with the phone provider's website. There is a newish Radio rom which may help, I use xda-developers.com a lot, their forums have the latest and most up to date radios which may help.
Dec 13, 2009 | HTC Touch Pro2 Smartphone
Htc gprs connections problem
hi i would call htc to let them know that you are in india and as for there unsupported phone department
Jan 11, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Browser/Data plan in Unlocked At&t tilt (htc mobile phone) not working in India
just change the wap setting to airtel & your good to go..
Apr 09, 2008 | Cell Phones
Computers & Internet Logo
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
