Question about KWIKTOOL Multi - krafter Set
Power switch has loose contact and won't stay running
You have to shake the kwik tool to get it to run. It is very hard to get to run. It ran fine when I first bought it and I havent used it but 4-5 times.
I Have a 1996 Toyota Tacoma pickup with 2.7liter 4 cylinder 4 wheel drive. truck ran great on freeway came to a stop at light and started to hesitate and lack of power like the cat was clogged. cat, is...
Please Run the Scanner/Computer and get the diagnostic complete.However you must make a Major TUNE-UP for fix it. See the picture attached for to see how many component can be faulty.
Nov 05, 2013 | Toyota Tacoma Cars & Trucks
Craftsman 5600 watt generator won't stay on and white smoke pours out when started.
try running it with nothing hooked up if it runs fine, then the power draw is to much for it that would cause it to hunt !!!
Jan 30, 2013 | Craftsman 5600 watt Generator
My asb light comes on when starting and stays on. Lights won't come on , power locks won't work, power windows won't work, radio won't work. All fuses are good and car runs fine.
Those are all really common symptoms of the alternator going bad on those cars. I would have it checked to make sure it's charging properly.
Dec 15, 2012 | 1996 Oldsmobile Cutlass Ciera
2000 gmc jimmy starts in AM fine won't start after sitting in sun all day
Can you jumper the fuel pump and make it start and continue to run ?
Have you checked to see if you are getting spark when it won't start ?
Could be a relay or coil, ignition module, or other component.
Aug 08, 2012 | 2000 GMC Jimmy
My rear break lights wont work when my truck is running, but when the truck is off they work fine. The bulbs and break light switch are good still. How do I fix them?
check the grounds. there might be a loose ground that is just barely contacting and when the truck is running it vibrates enough to shake it loose.
Mar 14, 2011 | 1994 GMC Sierra
My contactor switch will not remain engaged. I
Something,is drawing too many amps,most likely the compressor.
Jul 08, 2010 | Frigidaire FAA065M7A Air Conditioner
My Benq pb6100 projector needs a ''shake'' on switching on to run
Hi I am Vortash possibly a loose plug or the bulb housing is not secure and the cut off switch is not contacting .. loose fuse .. dry joints o loose component .. one thing is for sure keep shaking it
and your going to kill your bulb ?. During the arc on the lamp it builds up carbon deposits if they break loose they get hot in the bulb under working conditions against the glass and sometimes fracture it ?. don't shake your your unit unless you can afford to replace this at between $400 and $800 i bet that repair would be a more economic solution hope this helps Regards Vortash
Apr 10, 2009 | BenQ PB6100 Multimedia Projector
KWIKTOOL Multi - krafter Set Logo
488 people viewed this question
Top KWIKTOOL Home Experts
Donni Steen
Tom Chichester
Are you a KWIKTOOL Home Expert? Answer questions, earn points and help others
