Question about Sole Fitness F63 Treadmill
Sole e 55 no power wont turn on but power is getting to machine
No power machine has no power
Sanyo 55" tv will not power down and channels will not work
Always the first thing is to completely turn all power off of the TV. Wait about 10 seconds before plugging back in.
This normally does the 'fix'.
If not, then check batteries in the controller.
Sep 11, 2015 | Sanyo Televison & Video
How long does the 55 degree normally run for
Depends on the water temp going into the machine. Dishwashers should be connected to cold water. Some people fit to hot water but the machine will go through the cycle too fast and you wont get a decent wash result. 55 isn't superhot for a machine (I assume this is 55 celcius?) Most machines will take about 45 mins to an hour.
Jan 03, 2015 | Dishwashers
After putting together my sole f60 treadmill the display wont turn on, it gets a clicking noice, connections are connected. any idea where to start
Hook up the main harness . Make sure you didn't plug one of the connections up backwards. Hooking them up backwards will cause the incline to go all the way up and the display will not come on.
Aug 10, 2014 | Sole Fitness Sole F60 Treadmill
The monitor is not turning on
You probably crushed the wiring during installation. You need on-site service call 877-805-1030
Dec 30, 2013 | Sole Fitness Sole E35 Elliptical
Sole treadmill displays LS1 error as soon as I press start.
follow this steps and fix it. God bless you
Power Supply An inadequate power supply limits a Sole treadmill's speed to 7 mph, even though the display may say it is going faster. Plug the treadmill directly into an outlet without using an extension cord for best performance. If this is not possible, Sole recommends using a short 16 gauge minimum cord.
Belt Too Tight A walking belt that is too loose will slip and one that is too tight runs slowly. Adjust the tension by inserting a 6 mm Allen wrench into the hole in the right end cap at the back of the deck. This gives you access to the tension bolt. Turn the wrench counterclockwise no more than a 1/4 turn at a time to decrease tension or the opposite way to increase tension. Do not tighten more than necessary to eliminate slippage of the belt on the front roller. You must also then adjust for tracking due to increased belt tension by turning both tracking bolts on each side of the end of the rail 1/4 at a time.
Belt Lubrication Sole treadmill belts come pre-lubricated, but after the first 50 hours of use you will need to lubricate the machine again. Use only lubricant sold by Sole. The treadmill can go for another 1,000 hours of use before another lubrication if it is cleaned regularly. If the belt is running slow and you have done everything else, it may be that your belt is ready ahead of schedule. Spread an entire tube width-wise across the center of the deck. The place where your feet hit when walking or running is the ideal location for the lubricant.
Oct 15, 2013 | Exercise & Fitness
Sole E55 console display flashing "Need Lube"
Got a Sole elliptical machine? Is it displaying a NEED LUBE error message when you turn it on? Tyler at Sole service told me this is a software bug. It appears every 180 miles of usage, and it was really only intended for treadmills, not ellipticals.
You can clean and lubricate the rails and wheels - and you should - but the error message won't go away. Instead, you can get rid of it by resetting the odometer. First, press and hold the Start, Enter, and Stop buttons for five seconds to enter engineering mode. Use the arrow keys to select FUNCTIONS, then select ODO RESET and press Enter. Turn the machine off and on again, and voila, no error message.
Thanks Tyler! Happy exercising!
Jul 06, 2013 | Sole Fitness Sole E55 Elliptical
The belt on my Sole F63 will not turn
It sounds like you have a blown motor controller. If your machine is older than 5 years then that's pretty normal for sole. Their belts don't last very long and they cause stress on the controller. You'll have to replace the motor controller and the walking belt.
Aug 05, 2017 | Sole Fitness F63 Treadmill
Belt wont start on a brand new Sole F80. Motor
It sound like the motor control board is the culprit. Unplug unit then remove shroud then find the 2 leads that connects the motor to the motor control board disconnect them then plug in unit and see if the display blackout after programing the display then hitting start.
Mar 12, 2010 | RTO Sole F80 Treadmill
I have the 55" phillps rear projection tv
Common problem with this model. Goto www.TvRepairKits.com to get their chirping TV repair kit.
Feb 24, 2009 | Philips 55PW9363 55" Rear Projection...
Sole Fitness F63 Treadmill Logo
23 people viewed this question
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
