Question about Kenmore 98702 Stacked Washer/Dryer
Kenmore 417.948.62301 Stacked Washer / Dryer Problem
I think my dryer timer is broken bcause stock on one cycle i try to take off the front panel but i dont know how to take tha washer button if you hlep me im so glad
  • 146 Answers
Pull the knob off the timer and you should see the screws that hold it in place. Access is from behind.
Posted on Nov 04, 2007
98702 Stacked Washer / Dryer Your question about 98702 Stacked Washer / Dryer has been posted. Mom has a Kenmore stackable washer. She ran water in for a load and the water ran out of the washer and onto...
Get the control panel off and remove the water pressure tubing. Blow it out and reconnect to pressure switch. Remove water so that pressure can once again build inside the tube. Retry>
Oct 22, 2011 | Kenmore 98702 Stacked Washer/Dryer
My kenmore stacked washer/dryer has a wash cycle that can last for 12 hours. it will ultimately finish and clothes will be cleaned properly but it takes long breaks during the cycle.
The time it takes to do a cycle is determined by the washing machine timer. That is driven by a clock motor. This is an older machine so what is happening is that the motor on the timer is stopping and starting. A replacement timer is sold only as a complete assembly. I'm fairly sure you washing machine does the best job in the world in cleaning cloths.
Hope this helps,
Dec 30, 2010 | Kenmore 98702 Stacked Washer/Dryer
Hi - My Kenmore top load stacked washer/dryer has a broken timer. The dryer just goes and goes until it's turned off. Can this be fixed?
you can order a replacement timer from either sears or they do sell a universal timer that can be installed by a service tech timer's run from $35-$90 depending on where you buy it
Jan 12, 2010 | Kenmore 80754 Top Load Stacked Washer /...
Kenmore stacked washer/dryer. Dryer runs fine but washer doesnt
push the knob in then turn it counter clockwise chek the lid switch it may be bad
Jul 09, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stacked washer / dryer 2002
hi thanks for the question so your saying your tub is full of water ,did it stop in the middle of the wash cycle or at the end of the wash if its at the end of wash and it doesn, drain then you have a lid switch problem . if thats the case reset your timer as if you want to start a new wash load if it starts to wash your timer is ok replace the lid switch
Aug 27, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Kenmore 98702 Stacked Washer/Dryer Logo
272 people viewed this question
Sal De
 Brian Main
Brian Main
