Question about PrintCountry HP DeskJet 832C Inkjet Printer Ink Cartridges
Unable to install printer. the print processor does not exist
Cannot install printer to windows xp pc
Saying unable to install the print processor not exist
Please provide additional information. Description of Laptop and operating system. When does this message occur? Is it during boot-up?
Dec 27, 2014 | Computers & Internet
Will windows xp supported in amd sempron 145?
No it should not.
However your post does have one confusing detail - XP when installed does not reside on the motherboard but on a Hard Disk Drive. Parts of it will be loaded into memory when you boot up the PC.
If you mean that you are also installing a new Gigabyte MB under an existing installation of XP, you will probably still need the XP system disk for a reinstall of XP as it may not recognise the new MB.
If you are newly installing XP in an existing PC with the specs you mention, it should be ideal. It is best to have enough memory on board, at least 1 Gb.
Nov 20, 2011 | AMD Sempron 145, 2.8 GHz
Am trying to download the software on my laptop from the net but it dsnt work y? i dont have the cd
Problem : Unable install the drivers to the laptop
Environment :
Printer : HP DJ3325
Operating system - not mentioned
Solution :
Drivers for the DJ3325
Microsoft Windows 2000
Microsoft Windows XP
Support page from HP
Install the compatible print driver on the computer.
1. Make sure that the USB cable is not connected to the HP product.
2. From the Windows taskbar, click the Windows icon ( ), type control printers in the Start Search box, and then press Enter . The Printers window appears.
3. Click Add a printer and then click Add a local printer .
4. Click the Use an existing port check box.
5. In the Use an existing port drop-down list, select LPT1: (Printer Port) and then click Next .
6. Under Manufacturer on the Install the printer driver dialog box, select HP .
7. Under Printers , select the appropriate alternate print driver for the HP product and then click Next .
8. In the Printer name text box, type the HP product name and then click Next . The print driver starts to install.
Jan 03, 2010 | HP DeskJet 3325 InkJet Printer
Laptop powers on, but windows doesnt load
Boot PC from Windows XP installation CD you will be ask to instal fresh copy or repair existing installation - go for "fresh copy" software will analyze you PC and try to find your previous copy of Win XP you will be ask again to repair copy of your existing Windows Xp now go for "Repair" option so installation software restore all Windows files and will keep all your settings*.
This solution is only temporary because IE 7 and 8 will no longer work after restoring - backup all your data and instal fresh copy of Win XP after all and always keep Your Backup up to date!!
Sep 07, 2009 | Medion (40010998)
Unable to install HP All-In-One printer drivers on VIA Processor
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab41
Jul 04, 2009 | HP Officejet 5610 All-In-One InkJet...
HP OJ 5610 Drivers-? Can not install printer.
In this case, there's no mystery as to the cause of the problem. You will be unable to use this printer with your operating system because there are no existing print drivers that work with 64 bit Vista. Your printer will work with Windows 98, Windows 2000, and Windows XP, but not with Vista at all.
You have only two options...use a different HP printer that will work with Vista, or get a PC that has one of the supported operating systems on it and connect your current printer to that PC.
Sorry. I know this isn't the answer you were looking for, but that's the best I can do until the proper drivers become available.
Oct 05, 2008 | HP Officejet 5610 All-In-One InkJet...
1020 PRINTER DRIVER HP
There are no drivers for fixya but I have found a workaround by some anonymous poster
Xp software&drivers will work in Vista after a little tweaking in printer properties.
1)Install the CD-Rom HP Software/Drivers that came with your Printer at the time you purchased it. These Xp software&drivers are Vista Compatible after tweaking the Printer Properties. Reboot after installing.
2)Goto Start/Printers. Right click HPLaserJet1020 then Left click Properties. An HPLaserJet Properties window should have popped up.
3)Click the Advanced Tab. Click the Print Processor button located at bottom of window.
4)Select print processor as>>>IMFPrint. Then Select Default Data Type as>>>RAW. Click OK.
5)Now return to the Main HPLaserJet Properties window and click the General Tab. On the Bottom of that window; Click the Print Test Page Button. Finished! A test page should be printing out if you adjusted the printer properties correctly. Enjoy!
optionally you may have to disable print spooling
Quote "This did not work for me until I changed the option in that same window (advanced settings) to "print directly to the printer". Spooling does not work. "
Jul 14, 2008 | Office Equipment & Supplies
HP LaserJet 2600n Driver Installatoin
Delete from the registry and local drive every existance of all printers and then rebooting and resinstalling the printers from scratch
Nov 20, 2007 | HP Color LaserJet 2600n Printer
PrintCountry HP DeskJet 832C Inkjet Printer Ink Cartridges Logo
Top PrintCountry Office Equipment & Supplies Experts
Terry Hair
Igor Studennikoff
Igor Studennikoff
Mister Danger
Are you a PrintCountry Office Equipment and Supply Expert? Answer questions, earn points and help others
