Question about Goodman Heating & Cooling
Installing a motherboard on a heater
I am replacing the motherboard on my blend air to Coleman heater im at mobile home and I'm wondering if I got the wire codes correct because it won't start up can someone please help here's a...
There is a lot of things that can go wrong when installing a control board. Check the fuse link. Its the purple fuse with a number 5 or 4 on it. Pull it out and check to see if its not open. On the door panel of the furnace there is a diagram of the board and is like a map to where every wire goes. Just follow each wire per wire.
Nov 17, 2012 | Heating & Cooling
My Takagi T-M1 water heater is not functioning. After less than a minute of operating it stops and the red light in the front is blinking.
I HAD THE SAME PROBLEM. I CONTACTED TAKAGI WHO SENT OUT THE REPLACEMENT PART. AFTER INSTALLING THAT PART, IT WORKED FOR A MINUTE AND STOPPED. I CONTACTED TAKAGI ONCE AGAIN AND WAS TOLD "OH, THAT MOTHERBOARD GOES OUT SOMETIMES IF THAT FIRST PART GOES BAD!" THEY THEN SENT OUT A NEW MOTHERBOARD WHICH FIXED THE PROBLEM.
Mar 18, 2011 | RTO Takagi T-M1 Mobius Gas Tankless Water...
After installing XP sound device not installed ...................can you help me
Hi
After installing XP you no longer have the drivers installed that are supported by XP.
Do you have the disk that came with your computer,or motherboard?
Bob
Aug 20, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
D865GBF Motherboard: sir for my intel d865gbf the ethernet driver is no...
Have you tried it from the "Device Manager"? well firstly download the drivers from this link Intel865Lan, and run the set up. If you still have problem, let me know. Good luck. Thanks for using FixYa.
May 17, 2010 | Intel D865GBF Motherboard
Video drivers not installing on windows 7
You use windows 7 but you must be need all hard ware support driver,windows 7 need 64 bit support driver.You upgrade your display driver from www.mercury .support.com
Nov 26, 2009 | Mercury P4VM800M7 Motherboard
Problem installing vista or xp, v2a-vm motherboard
I faced a similar situation on an Asus motherboard, but a different model. Check the motherboard's manual & make sure that the memory modules installed on the motherboard are one of the recommended in the manual. If they are not, replace them with compatible memory modules.
Jul 26, 2009 | ASUS Intel 5000P Chipset...
Shut down problem while installing realtek sound driver
Hi, this problame could be related to sound drivers..download proper driver form hare and then install...
http://downloadcenter.intel.com/default.aspx
Jun 22, 2009 | Intel 845GE Motherboard
Heating & Cooling Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
