Question about Basement Watchdog 24EP6 - Emergency Sump Pump Battery
Adding water to a 24ep6 battery
Add water to battery
Adding water to my iron?
You tip it up and pour water slowly in the little funnel at the tip end.
Feb 29, 2016 | Black & Decker Quick N Easy X470 Iron
93 LeBaron low on coolant...is there a problem with adding water?
no there is no problem topping up with water but do not add to much as then the anti freeze stops working as well. and if you are adding coolant or water often then you have another problem
Sep 18, 2013 | 1991 Chevrolet S-10 Blazer
Can I just fill a car battery with battery acid or do I have to add water too?
Under normal operating conditions you should not need to add any acid at all. If the battery still has a charge then you should be only using distilled or deionized water. This should be added back up to the levels indicated.
If you must add electrolyte (for example the battery has tipped and the fluid loss is substantial) you should go to auto parts store to purchase proper electrolytic solution. Of course if you have some and you want to top off the battery thee is no harm in it. The battery should never have been empty in any case and after adding fluid an equilization charge should be given (This is an increased voltage charge,usually 14.4 volts, for about 15 minutes reverting to 13.6volts which is an average chargers rating. A smart charger usually has a setting on it for conditioning or similar that does the same thing. Regardless the battery should be charged even if in the vehicle running for a while it should be done right away for a little while to ensure chemical leveling.
Hope any of that rambling helps..
Sep 07, 2012 | Cars & Trucks
Radiator and adding water.
If you are adding coolant/water every week and there are no external leaks, you are probably burning the coolant thru the engine.
You can burn a large amount and not see any smoke from the exhaust pipe. Possible head gasket or cracked head.
Jul 27, 2012 | 2001 Dodge Dakota
I have a 2001 sonoma got hot steam came out driver side wont hold water now runs out somewhere on drivers side cant see where can u help
It could be a corroded core plug, it could be a corroded head gasket, it could a split radiator hose. It could be a cracked radiator or the end tank. or it could also be worse- a cracked engine block.
You or someone will need to crawl under with a light source and look at what they can see- no need to add water while under initially. Use a battery powered light if it is wet under vehicle or while adding water and keep electric cords well away from anywhere wet to avoid electrocution. Only add water if no problem are spotted initially.
Jan 04, 2012 | GMC Sonoma Cars & Trucks
I have a high efficiency top loading washer. After I add bleach to the top bleach place, should I rinse it down with a cup of water? Or will that cause problems by adding too much water or something?
Adding water to rinse should not cause any problems the machine does measure the water coming in by a different means but 1 cup of water will make no difference, a small variable water amount is built in to the water level measuring system.
Gene
Aug 15, 2011 | Washing Machines
Have misplaced instructions - do you add water before plugging in, if so how much and where do you add the water?
> problems with the Web Site
Usually, water is BAD for computers, and for web sites.
Anyway, it's always most SAFE to add water _BEFORE_ adding electrical power.
May 09, 2011 | Computers & Internet
Battery died, tried to jump it, battery completely dry, would that prevent all electrical response at all ? even with a charger hooked up to it ? All fuses are good.
Yes, if the battery is completely dry, usually it's shot. You can try adding distilled water. Do not add electrolyte. Put a charger on it and see if it will take and hold a charge. Usually they won't but it's worth a try. Good Luck
Apr 19, 2010 | 2000 Honda VT 1100 C Shadow Spirit
Jaguar 2002 s-type battery keeps losing power
You can add some life to your battery by opening it and adding some water. it gives the battery some short term life, but not very reliable, the best way is to install a new battery.
Feb 10, 2010 | 2002 Jaguar S-Type
Basement Watchdog 24EP6 - Emergency Sump Pump Battery Logo
Top Basement Watchdog Plumbing Experts
Donni Steen
Tom Chichester
Are you a Basement Watchdog Plumbing Expert? Answer questions, earn points and help others
