Question about Cooktops
Tc64c3 Lock on display Lock on display
BAUMATIC GECE6005Induction cooktop will not unlock so how do I get it off lock
Baumatic GECE6005 manual page 18
To disable the safety lock feature, you should press the safety lock button for a couple of seconds. The "L0" symbol will disappear from the timer display and you are then able to use the hob in normal operation.
Sep 08, 2016 | Baumatic Cooktops
Child lock turn off
For the Candy CH642B cooktop:
LOCKING BUTTON OPERATION
The locking function prevents the children from starting the hob. It is also used for cleaning the control strip as the controls can be locked without the hob being on.
To lock the hob :
- Press the on/off button
- Press simultaneously " - " button and " + " button of the front right zone (CH 633 front left zone), and then press again on the " + " button of this zone.
When the hob is locked, the locking indicator " L " is displayed on all zones for 20 seconds.
To unlock the hob :
- Press the on/off button. The locking indicator " L " is displayed on all zones.
- Press simultaneously the " - " button and the " + " button of the front right zone (CH 633 front left zone), and then press again on the " - " button of this zone. The hob is unlocked.
Dec 05, 2015 | Cooktops
What does F1 mean
The Fault Code/s will show up in the appliance Display
F0 - No Alarm Signal
Replace Main Electronic Control
F1 - Door will not Lock
Check door lock. Is Door Lock Getting Power
F2 - Door will not Un-Lock
Check door lock. Is Door Lock Getting Power Supply? Check Control Thermostat
F3 - Self Test Error
Disconnect Appliance from Mains Supply, Wait 5 Minutes and then Reconnect to Mains Supply
F4 - Shorted or Open Circuit Oven Temperature Sensor
Replace Oven Temperature Sensor, Check Sensor Harness Connection between Sensor and Control Unit
F5 - Relay Contacts Failed - Sticking
F6 - Power Board Temperature Too High
Check Correctly Installed, Check Cooling Fan Assembly, Ducting and Airways
F7 - Incorrect Polarity - Mains Supply
Check Mains Connection - Live & Neutral round the wrong way
F8 - Power Supply to Interface Problem
Check Wiring Harness, Replace Main Electronic Control
F9 - Procesor is Auto Resetting
Apr 05, 2015 | Electrolux White Westinghouse Stove Range...
After cleaning f1 appears on display
This means the oven lock is activated. The cook top touch panel is likely causing some problem.
Try to press the child lock button and see if F1 goes off. Otherwise the control panel will need to be replaced.
Oct 18, 2011 | Jenn-Air JED8430 Electric Cooktop
When I switch on, there is a pad lock symbol that gets displayed and I can't turn up the heating elements.
Thank you for using FixYa. The pad lock symbol is a child safety device to prevent accidental operation. Press or touch the area on or around the padlock symbol and the indicator will go out and thus allow you to use the hob
Mar 04, 2011 | Bosch 24 in. PIE675T01E Electric Cooktop
How do you unlock a kenmore elite cooktop?
You can do this by:
Check the oven display to see whether the screen says "LOC." When "LOC" is displayed, the oven lock is activated and the door cannot be opened. You need to make sure it is locked so you do not mistakenly lock the door.
  • 2 Press and hold the "Stop" button on the oven control panel until "LOC" disappears from the display. Some oven models have a button marked "Oven Lock," which should be used instead of the "Stop" button.
  • Lock the oven again by pressing and holding the "Stop" or "Oven Lock" button until "LOC" appears in the display
  • Feb 03, 2011 | Kenmore Elite 44173 30 in. Electric...
    The cook top display control lock ? i need to unlock the controls
    To Unlock Cooktop: Touch and hold CONTROL LOCK for
    5 seconds.
    Jan 11, 2009 | Jenn-Air JED8430 Electric Cooktop
    Have a baumatic ceramic hob displayin letter 'L'
    Got the same problem, and remembered I've kept the manual book
    L means locked. I dont know how Ive managed to do this as well
    Anyway it says:
    Cancelling the key lock
    After switching ON the control the child safety feature can be deactivated. Here it is necessary to simultaneously operate the front right cooking-zone-select-key and the MINUS-key and then operate the MINUS-key alone. If all steps hae been carried out in the right order within 10seconds the key lock gets cancelled and the control is OFF. Otherwise the input will be considered incomplete, the control remains locked and switches-OFF after 20 seconds.
    After a renewed switching-ON/OFF key all displays show 0", the display dots are blinking and the control is ready for ooking. If a cooking zone is "hot", "H" will be displayed instead of the static 0".
    Followed their instructions & still not worked. ,I am still confused and baffled after these instructions........................
    Mar 28, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
    Cooktops Logo
    139 people viewed this question
    Top Cooktops Experts
    Dan Webster
    Dan Webster
    paulcarew
    Are you a Cooktop Expert? Answer questions, earn points and help others
