Question about Fire Magic FireMagic Grill
Miami gas fire will not ignite
Hi this fire starts with the remote and goes thru the stages of starting but then as it should ignite nothing happens I have disconnected the cable and reconnected to the ignite but nothing, have you any ideas please, regards Andy
Had transmission rebuilt on my 2003 honda odyssey car drove back to naples fl from miami its the next day and the car wont start hit gas and nothing
If it isnt turning over you may just have a bad battery connection or ground.They may have taken your starter out when they rebuilt the trans and maybe a wire is loose or came off.
Mar 20, 2013 | 2003 Honda Odyssey
My Ruud achhiever 90 starts to fire but as soon as the blower fires the burner goew out. I also noticed that the "igniter" on the end isnt firing. Could that cause the burner to not stay lit when the
There is an ignitor and a flame sensor. If the ignitor does not ignite the gas after a time, it goes out. If the flame sensor does not detect ignition the gas valve closes. When you start it you should see the ignitor come on like a light bulb and glow, then the gas valve opens and you get ignition. Then the flame detector turns on when the ignitor goes out. Flame detectors are like a chrome wire that has one connection to it and it sits part of the way in a burner. They get dirty and corroded. When that happens it shuts down. You can clean the flame detector with steel wool of scotch brite pads. Dont get too carried away doing that though.
Dec 25, 2012 | Heating & Cooling
1988 F-150 5.0 has fire and gas. will not start.
Check your starter solenoid, its located on the fenderwell, easy way to do it is put ignition switch in start position use a jumper wire and connect the two large terminals, if it starts quickly remove the jumper, then replace the starter solenoid, if nothing happens replace the ignition module.
Mar 18, 2011 | 1988 Ford F 150
Sometimes when my gas plaque infrared gas space heater comes on a ball of loud flame bursts out in front of one of the plaques instead of lighting up the plaque. What causes this only occasionally? How can...
It sounds like a delayed ignition- and YES!-- that could be dangerous if something flammable was nearby, and no one was around to make sure the fire did not start something int he room on fire!
Trouble shooting delayed ignition:
Does this heater use a glowing ignitor to ight?
Or a standing pilot?
Or a spark?
I suspect that whatever is supposed to light the gas burner, is not in the path of the first gas release, (when the gas valve Opens) and so it takes a bit for the gas to build up, and finally get around to the source of ignition-- and then WHOOSH!!-- all that extra gas ignites!
Can you see the ignitor as it goes thru its first firing cycle-- what do you notice about the ignitor?
Something to consider:
What prevents it from filing the room with gas, before it ignites!
Sounds mighty dangerous to me!
Let us know what happens, and what you find-
Mack B
Jan 23, 2011 | Procom 10K BTU, Vent Free, 2 Plaque...
Husqvarna Ride Lawn Mower does not want to start, which theres about 1/2-tank of gas. My Husqvarna Ride Lawn Mower is only a few years old which I have done some routine maintenace. The lawnmower has set...
I've discovered that if you leave key on battery will be drained to dead. Checking battery with meter shows +12v. When key is turned to start position nothing happens. When you connect meter to battery terminals and put key to start position the meter reads about .250 VDC. Even after taking battery to Advance Auto and have it checked it still does same thing. Eventually I jumped my mower with another battery that was being used in my scooter. Bingo! all worked well with jump. You would probably be able to jump with car battery with no problem.
Mar 25, 2009 | Husqvarna Garden
Electronic ignition
Most likely you got water (or some other liquid) into the control knobs. Unplug, go to bed and try it again in the morning. If you continue to futz with it, you run the chance of burning out the electronics in the control knob, like I did. :(
Oct 22, 2007 | Miele 35 in. KM326G Gas Cooktop
Fire Magic FireMagic Grill Logo
32 people viewed this question
Top Fire Magic Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
john h
Are you a Fire Magic Grilling Expert? Answer questions, earn points and help others
