Question about Ovens
Oven wiring diagram
Is it possible to get a wiring diagram for a Malleys Viceroy VE233DD built-in oven?
Fitted new mainoven thermostat to Stoves Newhome built-in oven & grill Model No. 444445062 Serial No.41209452 other data on plate EFa900h need a wiring diagram,couple wires can adrift. Every thing...
I can only speak for the 720. If you want a circuit/wiring diagram for this one, then I need an email address. I will then register this on my BT Digital Vault and you can the download the whole manual.
Looking at the diagrams, the neon for the main oven has white and black wires.
The white wire from the main oven neon goes onto the same connector on the thermostat block as the white wire to the oven element. The black wire from the neon goes to a common terminal on the top oven neon, which then goes onto P6 of the top oven switch (still black wire).
If you need any more info, then let me know.
Apr 01, 2010 | Stoves 720EF Electric Double Oven
PURCHASED NEW GE WB27T10327 OVEN CONTROL TORISAN ERCB3 DID NOT HAVE INSTRUCTIONS FOR A NON SELF CLEANING OVEN. CAN YOU HELP? JERRY
Hi.
I do not have wiring diagram for this ERC. They had never been made available online by GE.
Here GE contact contact 1-800-626-2005.
All I can give you is the oven diagram below:
Nov 06, 2009 | GE 24" Built-In Single Gas Wall Oven
GE Gas built in oven Model JRS14 will not heat up
The bake ignitor has failed.Turn off the gas supply. Remove the racks. Then remove the bottom pan cover in the oven to access the ignitor. Place a amp meter on one wire of the ignitor.Turn the BAKE switch on. If it reads less than 3 amps,replace the ignitor.
Oct 30, 2009 | GE 24" Built-In Single Gas Wall Oven
What is blue wire on ge built in oven for
The blue wire goes to a seperate 15 Amp circuit breaker or fuse.
This breaker should be powered by the L1 (black) supply feed in the breaker box. The circuit supplies power to the display and control buttons. The red and black wires go to a double ganged 20 Amp breaker. Check inside the oven back cover for a wiring diagram.
Sep 07, 2009 | GE Profile 30" Built-In Single Electric...
Maytag wall over MEW5530BCB
Usually this turns out to be a problem with the main clock/electronic control but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
TheRepairGuru ----- www.repairclinic.com
http://www.repairclinic.com/Maytag-Range-Stove-Oven-Parts
Jan 26, 2009 | Maytag 30" Built-In Single Electric Wall...
Ovens Logo
18 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
