Question about KitchenAid 27 in. Built-in Microwave/Convection Oven
Superba owners manual how to change power settings?
How do you change the power settings
HOW DO I SET THE CLOCK ON MY NEW BOSCHE BUILT-IN OVEN MODEL HBE5451UC?
Read the owner's manual.
After connecting the oven or after a power failure, 1. Hold the TIMERS button down until the colon blinks on the display.
2. Set the current time with the @ and A buttons. Hold the @ or A button down to change the value faster. The time set is taken over after 5 seconds.
Jul 24, 2016 | Ovens
How to unlock the door on kitchenaid superba stove thank you
http://www.manualslib.com/manual/87576/Kitchenaid-Kbhs109.html#product-SUPERBA KEMS308
Jul 21, 2015 | KitchenAid Ovens
Kitchenaid superba built in oven thermometer probe symbol appeared after cleaning
The last digit is a 0 not an O go to Whirlpool,com scan over service and support click manuals and literature enter your model Number for owners manual as a tech have never seen the symptom you describe do me a favor hold the 0 button for 5-7 seconds to get into diagnostics we are looking for any F error codes hopes this helps
Feb 14, 2015 | KitchenAid Ovens
Kitchenaid superba oven manual
Power failure. Usually comes on when the power to the oven has been interrupted Setting the clock or turning on the bake or broil will clear it..
Nov 11, 2013 | Ovens
We're having trouble setting the clock on our Kitchen Aid Superba double covenction oven. When we push "clock set/start" and enter the time, and then push the "clock set/start" again,...
go to www.searspartsdirect.com. You can get a manual from them or you can go to www.whirlpool.com and possibly download one from there, make sure you have your model number with you.
Mar 13, 2011 | Ovens
Kitchenaid Superba walloven/microwave - problem with big oven.
I lost power and had the same problem. 177 degrees and ERR whenever I tried to change it. Reading the manual, I noticed that it was showing the degree symbol instead of F. When you hold down the broil/maxi/econo button for five seconds, it changes to F and then it worked perfectly. Makes no sense, but worked without any repairs needed.
May 12, 2010 | KitchenAid Ovens
Can we light a gas oven manually, it is a kitchenaid superba
No, You have to replace it. When the ignitor grows weak, it does not allow enough voltage through it to open the gas valve. Very common problem. Good Luck, Appliance Specialists
Jan 31, 2010 | Ovens
MY KITCHEN SUPERBA MICROWAVE/CONVECTION OVEN BEEPING IS ANNOYING
Sorry, I have the same oven and the same complaint. The manual doesn't indicate anything. BTW- the service manual is inside the oven frame, between oven "lining" and the outside sheet metal.
Jan 03, 2010 | KitchenAid 27 in. Built-in...
Kitchenaid Superba 27 KEMS376WHO
Go to manualsonline.com. They will ask for make and model of your appliance. Most manuals are free. Give it a try.
Jul 08, 2009 | KitchenAid KEBC107 Electric Single Oven
KitchenAid Superba Microwave/Oven, Microway Door message
"I get a "Door" message when I try to start it. The Message only shows when I try to set the time with one of the function buttons, like and dosent work
Dec 20, 2008 | Ovens
KitchenAid 27 in. Built-in Microwave/Convection Oven Logo
22 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
