Question about Kenwood Vintage Kr 3400 Am/fm Receiver Cleaned & Serviced
KR3400 noise
Whirring noise on acceleration Jeep Compass 8 months out of warranty done 24,517 transmission fault. any goodwill?
we cant hear noise here.
unless REAL LOAD.
heheheheh
ok,, why not ask a real live person this, in a real shop.? in the flesh.
noise, keyon?
noise , running engine.?
noise only in drive or reverse?
noise only moving>?
we can see you either.?
where is the noise, the car big, noises first must be source locate
as car has like 4000 parts on it that can get loose. even a loose license plate.
only on acceleration>?
is the CEL lamp glowing. (cluster warning lamp)????? at noise time?>??
may be engine noise (misfire) or trans. on drive line, all of it.
get it serviced like 99.9% do today.
Nov 27, 2016 | Jeep Compass Cars & Trucks
Can cv joints cause noise when braking
No really because there is pressure both ways keeping them from making noise. Usually they make noise when turning(clicking type noise) or them hum at higher speeds. This also sounds like bearing noise. The way to tell the difference is bearing noise will get loader or softer when your are making turns. Axles will have a consistent noise to them. Now bearings will make a noise when stopping.
Mar 01, 2015 | Cars & Trucks
2c engine chucking noise like its out of timing.
When the fault diagnosis for engine noise is too big, should first eliminate noise caused by the attachment, such as produced by air compressor and the power device, don't put these mistaken for the noise of the engine noise. Remove the accessory drive belt to eliminate noise caused by these devices. Noise will spread to those who have no problem on metal parts. So use the stethoscope will help determine the position of the engine noise.help you diagnostic tool
Mar 15, 2013 | Cars & Trucks
Grinding noise when its in nuetral with engine running
There are many possibilities that can cause car to make noise.
It's actually from where the noise is coming from. Front end or rear end. From engine area or from inside the steering or from brakes.
There is N-number of possibilities for the car to make grinding noise or any other kind of noise.
For step by step troubleshooting this problem, I suggest you to refer the help links mentioned below. Its a complete solution with proper explanation to identify the cause of problem: ------
Click the link below: -----
ABS light comes on and Car makes Grinding noise?
http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html
Car makes clicking noise?
http://howtobyme.blogspot.com/2011/11/car-makes-clicking-noise.html
Car makes whining noise like driving on rough pavement?
http://howtobyme.blogspot.com/2011/12/car-makes-whining-noise-like-driving-on.html
Chirping Noise From Car?
http://technoanswers.blogspot.com/2011/11/chirping-noise-from-car.html
What are the possibilities for Clicking noise in car?
http://technoanswers.blogspot.com/2011/11/what-are-possibilities-for-clicking.html
Squealing at start up on car?
http://technoanswers.blogspot.com/2012/01/squealing-at-start-up-on-car.html
Chirping sound coming from engine?
http://technoanswers.blogspot.in/2012/01/chirping-sound-coming-from-engine.html
Vehicle making Clunk Thump Thud noise?
http://howtobyme.blogspot.in/2012/03/vehicle-making-clunk-thump-thud-noise.html
4X4 Truck makes roaring noise in the front end?
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
Heater makes clicking noise under dash on Ford Explorer?
http://technoanswers.blogspot.in/2012/01/heater-makes-clicking-noise-under-dash.html
Clicking noise under dash and front defroster not working?
http://technoanswers.blogspot.com/2012/01/clicking-noise-under-dash-and-front.html
Car Brakes Making Noise?
http://repairhelpcenter.blogspot.com/2011/12/car-brakes-making-noise.html
Car Alternator making noise?
http://repairhelpcenter.blogspot.com/2011/11/car-alternator-making-noise.html
Car Alternator Bearing Makes Grinding noise?
http://repairhelpcenter.blogspot.com/2011/12/car-alternator-bearing-makes-grinding.html
Engine makes noise and Cooling Fan belt Breaks?
http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html
Vehicle Makes Clicking Sound While Taking turns?
http://schematicsdiagram.blogspot.com/2011/12/vehicle-makes-clicking-sound-while.html
These will help.
Thanks.
Nov 28, 2012 | 1995 Isuzu Pickup
I have a 02 passat when I start If up it sound like a truck. What do you think it can be. Its not turbo it just started doing it
There is N-number of possibilities for the car to make loud truck noise or any other kind of noise.
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
My eclipse spyder 03 started making that noise like a week ago on the drivers side ? Anybody help plz!!!!
There is N-number of possibilities for the car to make whining noise or any other kind of noise.
These will help.
Thanks.
My 2004 t&c 3.8 is making a weird sound like a
There is N-number of possibilities for the car to make wierd noise or any other kind of noise.
These will help.
Thanks.
Thud in trunk at take off
There is N-number of possibilities for the car to make thud noise or any other kind of noise.
These will help.
Thanks.
Nov 28, 2012 | 2010 Toyota Camry
Chevrolet k1500 whining noise
Its actually from where the noise is coming from.Front end or rear end.From engine area or from inside from steering or from breaks.
There are N-number of possibilities for the car to make whining noise or any other kind of noise.
For step by step troubleshooting these problem,i suggest you to refer the help links mentioned below.Its a complete solution with proper explanation to identify the cause of problem:------
Click the link below:-----
These will help.
Thanks.
Nov 28, 2012 | Chevrolet Silverado 1500 Cars & Trucks
Kenwood Vintage Kr 3400 Am/fm Receiver Cleaned & Serviced Logo
11 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
