Question about Vehicle Parts & Accessories
Almera wobbly gearstick
Gearstick very loose
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 189 Answers
Check linkage
Posted on Sep 09, 2014
Gearstick disengaged from gearbox
go to www.automecanico.com translate the website with your browser , get the topic and fix it.
God bless you
Nov 27, 2013 | Hyundai Excel Cars & Trucks
Nissan almera loose clutch pedal
It sounds like the hydraulic clutch is failing or the car just has a light clutch feel. I suggest you have a local shop push the clutch and see what they think.
Sep 07, 2012 | Nissan Cars & Trucks
I have a 1984 Ford Ranger 4 Speed manual shift. Shifter seems loose, is hard to find gears, when you get it in 1st, it does well going into other gears, except, now is stuck in reverse. When the shifter is...
You have the same problem as a previous guy, its the ball and socket at the end of the gearstick, its worn out, or just popping out of it's socket so the bolts holding it down or the large nut the is holding the gearstick in needs tightening. So best to remove it, check for wear and if it is ok then use a loctite glue to refit the main nut over the gear lever.
Hope this helps, let me know how you get on.
Jason
Oct 19, 2009 | 1984 Ford Ranger
I can shift into any gear but only first is engaged.
One of the gearstick joints has disconnected - hopefully not actually inside the gearbox. Gearstick connects to gearbox via a few rods & joints or a pair of cables in sheaths. Check something visibly moves near the gearbox no matter what movement the gearstick makes.
Sep 09, 2009 | 1999 Volkswagen Beetle
Loose gearstick in ford escort finesse 1999
Remove boot, then shifter handle, you will see a plastic anti-tizz bushing that will need to be replaced
Aug 27, 2009 | 1999 Ford Escort
Very loose gearstick first gear doesn't engage
Could be loose cables and out of adjustment or the syncros in the trans about had it.
May 27, 2009 | 1992 Volkswagen Golf
Bushes missing from gear stick and transfer stick
If it's a later model (post 98), then I have an idea what's happened. On the rounded ball end of the gear stick that goes in the box, there is meant to be a plastic bush that is only a very loose fit on the end of the stick. If it has dropped while either removing or replacing the gearstick, and fallen into the area at the back of where the gearstick actuates the shift rail, then apart from having a very sloppy gearstick, you won't be able to move the shift rail backwards - which is what happens when you move the gearstick forward (1st,3rd,5th). This should be fixable from in the cab. Of course, if you have an earlier model, none of the above applies, as you have the gearstick moving only one of a choice of three shift rails with no bush in that area. The only thing that happens to those is the spring on the gearstick breaks (that can't be replaced on its own!)
Mar 30, 2009 | Suzuki Vitara Cars & Trucks
Vehicle Parts & Accessories Logo
32 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
