Question about Motorola Mobility ATRIX HD MB886 Android Smartphone Black
Manual data settings step by step please
NO SETTINGS ARE PLACED DIRECTLY ON WHAT TO ENTER FOR INTERNET SETTINGS
Settings for apn are blank. what is my apn code
Hi Edward,
Here are the steps..
Internet Setup
Step 1: Enter Settings
Step 2: Select Wireless & Networks
Step 3: Select More...
Step 4: Select Mobile Networks
Step 5: Ensure Data Enabled is checked (enabled).
Step 6: Select Access Point Names
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND Data as the name for the new APN. Under the headings APN enter internet.windmobile.ca (leave all other fields blank).
Step 8: Save the APN settings by selecting menu and then save.
Picture Messaging (MMS)
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • APN: mms.windmobile.ca
  • MMSC:http://mms.windmobile.ca
  • MMS Proxy: 74.115.197.70
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
  • Leave all other fields blank.
Android 2.1 to 2.3
Internet setup
Step 3: Select Mobile Networks
Step 4: Ensure Data Enabled is checked (enabled).
Step 5: Select Access Point Names
Step 6: Create a new APN (Access Point). Enter any name you would like to call your internet connection and the access point as internet.windmobile.ca (leave all other fields blank).
Picture Messaging (MMS) setup
Step 6: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • MMSC: http://mms.windmobile.ca
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
May 10, 2016 | HTC 7 Surround T8788 Windows 7 Wm 3.8"...
Tip
Restore WAP, 3G, MMS Settings | Sony Ericsson Phones
Many people are having problems configuring their phones after de-branding or after flashing it. Usually after de-branding your phone you lose all the WAP, Internet, MMS settings from the phone. And you won't be able to send MMS or browse Internet.
For MMS and WAP to function properly, you should first create Data Accounts in Phone Settings and Then create Internet Profile and MMS profiles which make use of the Data Account. For manually creating these accounts and profiles you will need a lot of technical information from your CellPhone Service Provider. You will need to know the APN, Proxy Address if any, Username and password settings. Hence the idea of manually setting up is not recommended, unless you have spare time to figure out things.
You can directly download WAP and MMS settings for your phone from local Sony Ericsson Website. Visit SonyEricsson.com. In support section specific to your country, you will find links on how to configure Internet and MMS. Visit those links, You will be asked about phone model and operator name ( like Vodafone, Airtel in list), Select your operator and provide your cell phone number. You will be given a authorization code, and in a few minutes Sony Ericsson will send you the Internet/MMS settings directly to your phone. Enter the authorization code in your phone. And MMS, WAP, 3G and Internet settings will be installed correctly. All operator based services should then work fine.
Thank you for using FixYa!, Keep visiting..
Concerned, Nooh.
on Jan 23, 2011 | Cell Phones
I cant get the internet on 983
you need to contact your service provider for internet settings.If you have received them but still its not working,consult with them if your sim card is provisioned. If it all fails,then try the manual settings below:
Nokia 5800 Xpress Music Internet manual configuration
  • You can also configure your phone manually for mobile internet. Follow the step-by-step instructions below.
  • Start screen.
  • Go to the Main menu.
  • Choose Settings.
  • Choose Connectivity.
  • Choose Destinations.
  • Choose Internet.
  • Choose Options, New Access point, and then Select.
  • Choose No.
  • Choose Packet data, and then Select.
  • Enter Yo profile name and choose OK.
  • Choose Options, Organise, Select, and go to the next step.
  • Choose Change priority, Select, choose the highest position, and choose OK.
  • Choose* the profile , *Options, and then Edit.
  • Choose Connection name, enter your profile name, and choose OK.
  • Choose Access point name, enter YO APN (be aware of the dots), and choose OK.
  • Choose Prompt password, No, and then OK.
  • Scroll down.
  • Choose Authentication, Normal, and then OK.
  • Choose Homepage, enter YO HOME PAGE, and choose OK.
  • Choose Use access point, Automatically, and then OK.
  • Return to the Main menu.
  • Choose Internet.
  • Choose Web.
  • Choose Options.
  • Choose Settings.
  • Choose General.
  • Choose Access point.
  • Choose Internet, Options, and then Select.
  • Choose Homepage.
  • Choose Default, and then OK.
  • Return to the Start screen.
  • Start screen
  • DONE
Nokia5800 Xpress MusicInternetmanual configuration
Apr 05, 2014 | Nokia 5800 XpressMusic Smartphone
Nokia model c5 c6
Internet: manual configuration
Nokia C5
*Menu
·Settings.
·Choose Connectivity.
·Choose Destinations.
·Choose Internet.
·Choose Options,and then New access point.
·Choose No
·Choose Packet data.
·Enter Proximus Internet, and choose OK.
·If Proximus Internet has Priority 1, skip the next step.
·If not, go to the next step.
Previous
·Choose Proximus Internet for a second, until a popup window is displayed.
·Choose Change priority, and choose the highest position.
Previous
·Choose Proximus Internet.
·Choose Connection name, enter Proximus Internet, and choose OK.
·Choose Access point name, enterinternet.proximus.be, and choose OK.
·Choose User name, enter nothing, and choose OK.
·Under Prompt password, choose No.
Previous
Next
·Choose Password, enter nothing, and choose OK.
·Under Authentication, choose Normal.
·Choose Homepage, enter http://m.skynet.be, and choose OK.
·Under Use access point, choose Automatically.
·Return to the Main menu.
Previous
·Choose Web.
·Choose Options, and then Settings.
·Choose General.
·Choose Access point.
·Choose Internet, Options, and then Select access
·Choose Homepage, and then User defined.
Previous
Next
Step 22 of 24
·Enter http://m.skynet.be, and choose OK.
·Return to the Start screen.
Previous
·Start screen.
·Switch off the C5-03 and restart it in order to activate the settings.
·You can now start using the internet.
Previous
Jan 06, 2014 | Dual Cell Phones
W580i gprs setting vodafone postpade
Settings - GPRS WAP
Sony Ericsson W580i GPRS WAP Pay & Go settings
Please note all steps must be completed to ensure the settings are correctly configured.
Please ensure that when entering 'O2' into the settings that the letter 'O' is selected not a zero.
The W580i has a central navigation button (Navi key) and two soft keys slightly above this.
1. Press 'Menu' (right softkey).
2. Highlight 'Settings' and press 'Select' (left softkey).
3. Scroll to the 'Connectivity' tab by pressing the Navi key to the right.
4. Scroll to 'Data communication' and press 'Select' (left softkey).
5. Highlight 'Data accounts' and press 'Select' (left softkey).
6. Highlight 'New account' and press 'Add' (left softkey).
7. On the 'Account type' screen, highlight 'PS data' and press 'Select' (left softkey).
8. On the 'Account Name' screen, enter 'O2 WAP GPRS', press 'Continue' (left softkey).
9. On the 'New PS data' screen, highlight 'APN' press 'Edit' (left softkey), enter 'payandgo.o2.co.uk' and press 'OK' (left softkey).
10. Highlight 'Username' press 'Edit' (left softkey), enter 'payandgo' and press 'OK' (left softkey).
11. Highlight 'Password' press 'Edit' (left softkey), enter 'password' and press 'OK' (left softkey).
12. Press 'Save' (right softkey).
13. Press the 'back' arrow key (key directly below left softkey) 2 times.
Activate GPRS settings:
14. Highlight 'Internet settings' and press 'Select' (left softkey).
15. Highlight 'Internet profiles' and press 'Select' (left softkey).
16. Highlight 'New profile' and press 'Add' (left softkey).
17. Highlight 'Name:' press 'Add' (left softkey), enter 'O2 WAP GPRS' and press 'OK' (left softkey).
18. Highlight 'Connect using' press 'Select' (left softkey), highlight 'O2 WAP GPRS' and press 'Select' (left softkey).
19. Press 'Save' (right softkey).
Change GPRS settings:
20. Highlight 'O2 WAP GPRS' and press 'More' (right softkey).
21. Highlight 'Settings' and press 'Select' (left softkey).
22. Ignore 'Connect using'
23. Highlight 'Use proxy:' press 'Select' (left softkey), highlight 'Yes' and 'Select' (left softkey).
24. Highlight 'Proxy address:' press 'Edit' (left softkey), enter '193.113.200.195' (to bring up the number press the number until it appears. Add the dots with the '1' key) and 'OK' (left softkey).
25. Highlight 'Port number:' press 'Edit' (left softkey), enter '8080' and press 'OK' (left softkey).
26. Highlight 'Username' press 'Edit' (left softkey), enter 'payandgo' and press OK (left softkey).
27. Highlight 'Password' press 'Edit' (left softkey), enter 'password' and press OK (left softkey).
28. Press 'Save' (right softkey).
Change Homepage:
29. Highlight 'O2 WAP GPRS' and press 'More' (right softkey).
30. Highlight 'Advanced' and press 'Select' (left softkey).
31. Highlight 'Change homepage' and press 'Select' (left softkey).
32. Highlight 'Name:' and press 'Edit' (left softkey). Hold the 'c' button (to the right of the Navikey) to clear any text in the field. Enter 'O2 ACTIVE' and press 'OK' (left softkey).
33. Highlight 'Address:' and press 'Edit' (left softkey). Hold the 'c' button (to the right of the Navikey) to clear any text in the field. Enter 'http://wap.o2.co.uk' and press 'OK' (left softkey).
34. Press 'Save' (right softkey).
35. Press the backward arrow key (key directly below left hand soft key).
36. Highlight 'O2 WAP GPRS' and press 'Select' (left softkey).
37. Press the 'back' button (to left of Navi key) 3 times to return to the standby screen.
Feb 19, 2013 | AT&T Sony Ericsson W580i Cell Phone -...
Error code 52130, trying to hook up to the wireless internet. Any Suggestions?
Error Code: 52130 The Wii is unable to connect to the Internet
Likely cause: The wireless router is incorrectly connected, or the Wii console will need a DNS manually entered.
How to fix: Check the way your router is connected; manually assign a DNS to the Wii.
  1. Check the connections to your wireless router:
      Even if you are able to get a working Internet connection to your computer through the wireless router, if it is not properly connected to the modem, the Wii and other devices may not be able to use it.
    • Most routers have five (5) ports on the back. Typically there is a set of four, with a single port either farther away from the rest, or separated with a different color border or line. This single port is often labeled "Internet" or "INT." Make sure the cable coming out of your modem is plugged directly into this "Internet" port, and not into one of the other four that are grouped together.
  2. Manually change your Wii console's DNS settings. To do this, follow these steps:
    1. Access the Wii system settings (how to), and use the right arrow twice and select "Internet."
    2. Select "Connection Settings," and choose the connection file (1, 2, or 3) that are you are currently using.
    3. Select "Change settings" and click the right arrow 3 times to reach "Auto-Obtain DNS."
    4. Select "No," and choose "Advanced Settings."
    5. Click into the "Primary DNS" field and enter: 8.8.8.8
    6. Click into the "Secondary DNS" field and enter: 8.8.4.4 Select "Confirm," and then "Save."
    7. Select "OK" to start the connection test. Once the test finishes, try to download the update again.
  3. If you are still getting this error code after trying the steps above, please call 1-800-255-3700 for further assistance.
Nov 26, 2011 | Nintendo Wii Console
How to subscribe packet data?for nokia classic 2700
To subscribe to packet data you need to contact your service provider through phone or go directly to their office.
They will send you the settings for your model. Please save the settings to your phone and set it has a default settings.Then you can start using the internet in your phone.
Thank You
Aug 07, 2010 | Nokia Classic 2700 Cell Phone
I need manual setting for tata docomo
GPRS Settings for mobile phone
To get Internet settings SMS "INTERNET" to 52270 (toll free on TATA DOCOMO HOME & CHARGED Rs.3 at non DOCOMO Network) and save them as default settings.
Connection Name : Tata Docomo internet [any name]
Data Bearer : GPRS
Access Point Name : TATA.DOCOMO.INTERNET
Username :
Password :
Homepage :
Connection Security : Off
Session Mode : Permanent
Manually configuring Docomo GPRS settings with pictures step by step is on link below:--
http://www.renjusblog.com/2009/09/free-tata-docomo-gprs-settings-for.html
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Dec 21, 2009 | Motorola Mobility ROKR E6 Smartphone
Linksys WRT160N PROBLEM... PLEASE HELP...
Some time what happer router will start blocking the data , in that case what you have to do is that you need to reconfigure the linksys router . First press the reset button for 30 sec , then remove the power for 30 sec and now your router is ready to reconfigure with your setup disk .
if you dont have the setup disk , i am pasting some router reconfiguration steps and i am sure that will help you out .
Please Double Click on the Internet Explorer and on the Address bar,
type in 192.168.1.1 and Press Enter.
Leave the Username blank and type "admin" in the password.
Step 04:
Configure Wireless Settings:
1. Please click on Wireless tab on the router's setup page.
2. Make sure that the Wireless Network Mode is set to Mixed.
3. Change the Wireless Network Name or the SSID from Linksys into your name.
4. For the Wireless Channel, please change it from 6 to 11.
5. Enable the Wireless SSID Broadcast
6. After that, please click on the Save Settings button.
Apply Security Encryption
1. When the router's setup page appears, please click on the "Wireless" tab.
2. When the Wireless area appears, click on the "Wireless Security" sub tab.
3. When the Wireless Security area appears, Change the Mode to WPA personal.
4. Enter the password of your choice in the WPA shared key (it should be minimum 8 characters) and then save the settings.
Step 05:
1. Under Basic Setup tab and set the "Internet Connection Type" to
Automatic-DHCP. After that, please save the settings.
2. Click on the the MAC Address Clone sub tab.
3. In the “MAC Clone” section, set the option to Enable.
4. Click on the Clone Your PC’s MAC button.
5. After that, please save the settings.
Step 06:
Power Cycle:
1. Unplug the router’s power cable.
2. Unplug the Broadband modem’s power cable.
3. Wait for 30 seconds.
4. Plug in the Broadband modem’s power cable and wait for its
lights to stop blinking.
5. Plug in the router's power cable once the modem’s lights stop
blinking.
6. Finally, Test the Internet connection.
Apr 11, 2009 | Linksys WRT160N Wireless Router
Unable to get internet on i9 phone im with fido
Go to Main menu> Services>Data Account>GPRS
Select a profile and select "Edit profile"
Enter the following settings
APN: internet.fido.ca
user: fido
password: fido
Go to Main menu>Services>WAP>Settings>Edit profile
Select a profile and select "edit profile"
Enter in the following settings
Homepage: www.google.com
Data account: GPRS>FidoINT
Connection type: HTTP
user: fido
password: fido
Then to browse, Go to main menu>Services>wap>homepage
You may get an error "Unsupported scripts in content" Just click ok.
Feb 22, 2009 | Dual Electronics CECT P168 Cellular Phone
Motorola Mobility ATRIX HD MB886 Android Smartphone Black Logo
13 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
