Maranz M-CR603 displays 'unsupported' will not play cds
2 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: bose lifestyle 48 says format unsupported for audio cds
Hi Johnxxlt,
According to Bose, the message that you have is due to dust in the system ....
They have offered 3 ways :-
Try cleaning the CD or DVD, as follows:
  • Use a soft, dry, lint-free cloth to remove stains or fingerprints from the disc surface
  • Wipe in straight movements from the center of the disc to the outside
  • Do not use any chemical cleaning products. They can damage the disc.
If the above will not fix the problem, you need to call them to repair the system.
I know its frustrating, However, we cannot play more with Bose as it might void the warranty if any.
Thanks for using Fixya.
Do rate the solution as "Fixya" if 100% satisfied.
Posted on Apr 17, 2009
My Bose Lifestyle 28 is having trouble playing CDs everytime I put a cd it says format unsupported. How do I fix this?
Most likely you have a problem with your CD drive in the Lifestyle system. I suggest to contact Bose, to ask for a repair.
Feb 11, 2015 | Bose Lifestyle 28 System
Unsupported format message for normal CDs
Have you tried completely powering down the system, removing the power cord from the wall socket? If not, please try that. Wait two minutes. Then plug it in and power up the system. If this does not clear the problem, contact Bose, to get the latest firmware disk. The firmware disk will reprogram your Lifestyle sound system. Then, everything should work properly.
Jan 17, 2010 | Bose Lifestyle 48 System
DVD-RW PROBLEM
Your CD might be damaged. Have a closer look at the CD holding it against a light and you will find where it is scratched.If you are able to access it on a different PC drive. please back up the data on that PC and make a fresh copy of the data on a different CD. You may lose some information BTW.
Dec 28, 2009 | Acer TravelMate 4200 Notebook
My laptop dvd just stopped playing my data cds and dvds that it used to play just fine. I get the message ''unsupported format in Drive E''. The dvd plays audio cds and dvds just fine. I can burn new cds...
dear sir good day please test the cd on an other lab top so you will know the problem and i think it will come from the data cable of your cd thank you
Dec 27, 2009 | Computers & Internet
Bose lifestyle 48 says format unsupported for audio cds
Hi Johnxxlt,
Apr 17, 2009 | Bose Lifestyle 48 System
Everytime I want to play an audio cd, it says format unsupported. This is happening very often. And I have also cleaned the cds,but still there is no difference. What is the solution?
Apr 08, 2009 | Bose Lifestyle 48 System
Cowon A3 display 'unsupported codec' when VOB file is played.
The Problem is solved with the Firmware - Version 1.23 all newer Firmware can't play VOBs, because there is a License - Problem
Nov 07, 2008 | Cowon System Audio Players & Recorders
Format unsupported
Format unsupported simply means the unit can not read the disc. The problem is either the disc or the player.
Contact Bose technical support if you are sure the discs are good. 800-367-4008
Jul 31, 2008 | Bose 3 2 1 GSX System
Not an Audio CD/Format Unsupported
Clean the CD and try again. Also, if DVD displays "not supported", call Bose and ask to recieve an update disc. These updates are released every 6 months. Document your remote control settings before loading the update as they may be erased by the update and will require re-entering settings after the update.
Dec 24, 2007 | Bose Lifestyle 38 System
DVDs with pictures refuse to play. Get 'format unsupported'
the 321 does not support data cds or dvds read the manual. standard DVD or VCD format only.
Nov 23, 2007 | Bose 3 2 1 GSX System
Open Questions:
Mitsubishi WS-65511 Rear Projection Big Box TV resets with a green flashing light every 5 minutes, Then works fine for 5 more minutes (perfect picture). Acts up worse when cold. Warm it up Works hours It's NOT the DM board caps. I've already replaced the DM caps twice. Not the problem. No repairman will look at the set. Too Old. So am I. I could repair it with help. The power supply must have a safety circuit that will shut down & reset if too much draw. I DON'T have a diagram. I'm not sure how to trace it . Which board? If I unplug boards one at a time, Will it damage other boards ? I know it is NOT the 7 DM board caps everyone keeps telling me. I see no burn't parts, No bulging caps. Tapping on components doesn't reset. What kind of component would act up when cold , But not overdraw when warm? This set has the best beautiful picture when it runs. If you can get past the resetting every 5 minutes for the first hour, You can watch it sometimes for 20 hours. I've left it on at night & it is still on the next morning. Change the channel Or raise the volume, And off it goes. Once or 10 times, Keeps resetting. Then on for 4 or more hours, Maybe. I can't afford a new one. It works GREAT ! when it works. I've notice that even when the set is turned off, The green light starts flashing (resetting itself while it's off) , Then stops. Once in a hundred times it will kick off the breaker & you need to push reset with a pin on the front panel next to the green light. It's probably a 10 cent resistor OR a $ 1.00 cap. If I only had someone with more knowledge than me to help. I know how to use a meter & read a schematic. I built a Heathkit 25"TV in the 70's & all my novice ham gear. I'm 64 & not familiar with digital circuits. Can someone help PLEASE ?
Dec 16, 2017 | Mitsubishi Televison & Video
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
