Question about Xerox WorkCentre M-24 Color Copier
Zerox workcentre 24
How to solve ROS problem
Error 061-321 xerox workcentre 5024 - Xerox Office Equipment & Supplies
061-321 ROS Motor Fail
BSD-ON: CH6.5
The number of rotation of the ROS Motor did not come within the standard range within the specified time (5 s) after the ROS Motor On.
Cause/Action
1. Turn the power OFF and ON.
2. Check whether the Drum Cartridge is installed.
3. Check the ROS Motor (Output Check [061-001]) for operation failure.
4. Check the LD +5VDC power supply of the LD PWB J140 pin-8.
5. If no problem is found, replace the following parts in sequence:
• ROS Assembly (PL 2.1)
• ESS/MCU PWB (PL 18.3)
http://turbobit.net/upqkewkg8xjt.html
Feb 18, 2017 | Xerox Office Equipment & Supplies
CODE 006-382 XEROX...
The error means that the interval of the ROS (C) signals exceeds the specified value. The normal problem is a bad mcu board. Measure the value between PJ401 on the MCU board and and ground for +5vdc. If you get +5 then replace the MCU board. Part number 960k31352. http://www.iteminconline.com/itemdesc.asp?ic=960K31355&eq=&Tp=
Aug 25, 2014 | Xerox WorkCentre 7328 Multifunction laser...
What is a ROS system Failure
ROS stands for Raster Optical Scanner which is the scanner head/lense. This will need some cleaning from time to time depending on how much it is used. consult the printer manual on how to clean it.
Aug 06, 2014 | Xerox Office Equipment & Supplies
Meaning of u3-3 in 428
http://www.omkarmin.com/pdf/workcentre-pro-423-428-printertec-23924.pdf
U3-3
(4133)
ROS failure
Abnormal power adjustment
value to the laser diode
when the diode is forced to
go on
POWER
OFF/ON
Jun 07, 2014 | Xerox WorkCentre Pro 428 Copier
Horizontal lines. Xerox 6505DN
clean the print heads and align them
Sep 10, 2012 | Xerox 6505N AllInOne Printer
Fault code 006-381 on a xerox workecentre 24
That is a ROS ( laser ) fault.Either the ROS unit or the MCU ( main processor board) have failed.
Honestly, its a tossup as to which is the problem.
Mar 30, 2010 | Xerox WorkCentre M-24 Color Copier
Workcentre 24
Esta problema debe estar en la caletador, o el "fuser".
Si peude cambiar la Thermister, la cosa que cala la temutura, esa cosa puede leller la tempatura mala. Cambia la.
Si el papel se para antes que se sale, checa las manitas en el switches. Se callen o se torra y no bajan. Debem esta fojas todo tiempo.
Ojala que esta ajuda trabaja.
Nov 17, 2009 | Xerox WorkCentre M-24 Color Copier
Dc 12 docucolor fery x12
hi first u check the immage wher its missing? in drum, ibt belt and 2nt btr(paper)... if its not appear in drum pls check drum unit and ros assembly. if its not appear in ibt belt pls chck bios and tranfer rollers... all the best.
Aug 23, 2008 | Xerox DocuColor 12 Color Copier
Error Code Call For Service
Most likely the laser has failed and needs replaced. Here is the documentation.
CA1 Indicates that the polygon motor in the ROS has failed.
arrwup.gifProcedure Enter output test, code 103, GP 10.
The polygon motor runs. Yes No Unanswered
Perform the following:
  • Check the connector CN26 on the Interface PWB. Refer to Wiring Diagram 4.
  • Check the harness and the pin connectors.
  • Check the Interface PWB for damage.
  • Install a new ROS, PL 9.10 Item 15.
  • Install a new Interface PWB, PL 9.30 Item 5.
Check at connector CN26 pin 4 on the Interface PWB for a low signal. Refer to Wiring Diagram 4.
The signal is low. Yes No Unanswered
  • Check all the connectors to the interface PWB are pushed fully home.
  • Check the interface PWB for damage.
  • Install a new interface PWB, PL 9.30 Item 5.
May 13, 2008 | Xerox WorkCentre Pro 416 All-In-One Laser...
Xerox WorkCentre M-24 Color Copier Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
