Question about Car Audio & Video
Parrot bluetooth manual
No signal
No signal being picked -up
the kit has had a software crash, you can try unplugging the parrot, then waiting 5 mins then plug back in. If this does not work you will need to have the software written into the parrot using a special update cable, you can buy these online but I would recomend you contact your local Parrot acredited installer, they will all carry one of these cables. Try Parrot.com for a list of engineers.
Dec 04, 2011 | Parrot Hands-Free Car Kit with LCD Display...
My parrot wont turn on and just displays no signal
The software has failed, this may be due to the Parrot being wired wrong, Did the kit have the word "goodbye" when switching off?. if not then you will need to make sure the wiring is correct or this may happen again. You can try removing power from the Blue brain box and this may work otherwise you will need to have new software put into the kit. If the kit still says no signal after a power reeboot you will need an engineer to write new software into the brain. The parrot web site has a list of all approved engineers.
Dan
Oct 15, 2011 | Parrot SA Parrot Ck3100 Lcd Handsfree...
My Parrot Handsfree, has just stopped working. It has a constant display of no signal. Can you please help?
You can try removing power from the Parrot and it may come back to life but it will probably need a software update. You will need a special cable to do this which you can but but it will be cheaper to take the car to your nearest Parrot dealer. Parrot web site has a list of certified engineers who all carry this special cable.
Feb 10, 2011 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Will not connect to my sonyericsson w995
i checked that your phone is compatible wd the parrot handsfree bluetooth.
turn-on your bluetooth of your phone
turn on bluetooth of your parrot handsfree see manual where the buton is located
From the phone:
* Go to MENU / SETTINGS / CONNECTIVITY / BLUETOOTH / MY DEVICES / NEW DEVICE
* Phone will search for available bluetooth devices
* Select Parrot Product from the list
* Enter Passcode "1234" and go to OK
* Accept the pop-up
* Devices are now paired and connected
fleche.gifSending contacts via Bluetooth
Jan 29, 2011 | Parrot Hands-Free Car Kit with LCD Display...
I have parrot installed in my car after change in battries it says no signal
no signal means the software inside the parrot has crashed, you will need to remove the main control box and update the software but you will need an update cable, this can not be done via bluetooth. try parrot.com and look for yor nearest engineer or dealer
May 13, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
No signal significate that you have a trouble on the screen. It has to be replaced.
Mar 22, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
Problem updating Parrot LS-GPS
The Parrot manual states that the software update can be conducted via bluetooth (BT). I've managed to get BT connectivity both the laptop recognising the Parrot as a headset, and indeed it cts a PC speaker in the mode, and also from the Parrot linking to the laptop. But wehn using the Parrot Software update tool, and attempting to connect via BT, non of the displayed COM channels work. Authentication fails. The laptopn connection also only stays up for about a minute. Confusingly the Parrot also offers an update item in one of its menues, and supplies a 4 digit passowrd, but I can't see how this can be used. Any ideas?
Sep 14, 2009 | Parrot Ck3400ls Bluetooth Lcd Car Kit With...
New phone needs to be connected to my Parrot
You will need to go to settings and paired devices, delete any old devices, then go to settings / advanced settings / pair with phone. this will then give you a pin code to enter. Now search from your phone for Bluetooth devices, select parrot and enter the code given.
you can find a manual at parrot.com
Dec 22, 2008 | Parrot Ck3400ls Bluetooth Lcd Car Kit With...
Can I receive and manage text messages on my parrot ck3200ls
Hi, no you cant receive and manage text from this handsfree, the signal strengh is displayed if the phone allows it, some phones will display battery and signal, some only battery etc.
Hope that helps
Oct 17, 2008 | Parrot Ck3200ls Lcd Color Display For...
Car Audio & Video Logo
74 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
