Question about Yahoo Messenger
Log in error 81003005 - Yahoo Messenger
    Problem Solver:
  • 7 Answers
Either your user name or password is wrong
Posted on Jun 15, 2009
4 Suggested Answers
g_aqua31
  • 47 Answers
SOURCE: Yahoo messenger 81003005 error
Here's how I solve it:
1. Open your Internet Explorer
2. Go to Tools > Internet Options then click the Connections tab
3.Click the LAN Settings button and a new dialog box will open
4. At the new dialog box, look for the Proxy server checkbox, if this is checked, uncheck it.
5. Then your done, click OK button for the dialog boxes.
6. Try logging in to your Yahoo Messenger account.
Posted on Nov 28, 2008
  • 98 Answers
SOURCE: log in error 81003005
use this,the problem is due to trouble between internet explore settings and linked to yahoo
or
this problem may cause due to dsn server. you may unset the DNS Servers (Go to Network Properties >> General Tab >> TCP/IP Properties >> General Tab > Obtain DNS Server address automatically) and try logging in again.
Posted on Jun 16, 2009
taran_2005
  • 10515 Answers
SOURCE: messenger error 81003005
here are some causes: Firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Let's says for example, if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren?t grayed out. Click OK and login again using the new settings. If this option doesn?t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Secondly; if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code?81003005? when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version. Hope it was helpful!
Thanks.
Why i see error number 81003005 in yahoo messenger?
This message appear probably because of your computer proxy software by default change your connection properties.
Solution is
Open you internet explorer
  • click tools>>>Internet option>>>connection tap
  • Under Dial-up and Virtual Private Network setting
  • Double click your current internet connection that you are using now
  • Make sure that under Proxy Server, the ‘Use a proxy server for this connection’ isUNCHECKED
  • Now back to connection tab
  • Click LAN setting
  • Click OK>>OK
  • Try to logging to your Yahoo messsenger again.
Jul 25, 2009 | Yahoo Messenger
I cant log in to yahoo messenger. theres a sign-in problem.... 81003005. What is this and how can I solve this. Please help.
hi,
try the solution posted on this site:
http://stephenhaim.com/resources/yahoo-messenger-81003005-error
please give me a good rating if solution works for u.
Thanks for using FixYa.
Jan 05, 2009 | Yahoo Messenger
Error 81003005
I solved the problem by logging into the web yahoo messenger (http://webmessenger.yahoo.com).  Then I was able to log in with the normal messenger client.  I was having the error 81003005 on multiple computers.  After logging into the web messenger, the yahoo client worked on all my computers
Dec 31, 2008 | Yahoo Messenger
Errror 81003005 wont let me sign in to yahoomessneger
ok, in my case i remembered I tried using a proxy on internet explorer and forgot to put it off, so the proxy connection was still on even though the proxy was dead.
It now a proven fact to me that internet explore settings are linked to yahoo mess!
so make sure your internet explorer is working ok without proxy:
good luck =)
Dec 07, 2008 | Yahoo Messenger
Yahoo 81003005 error
hi u
i had (or maybe have) this problem
but a solution that i found is :
you set a proxy in internet explorer ,
clear that with this steps:
and for this time , i solved problem, hope it works for you
Dec 01, 2008 | Yahoo Messenger
Please try again a little bit later (81003005)
hi,try the solution posted on this site:
Nov 22, 2008 | Yahoo YHT-630 System
Error 81003005
pls do fast ok.
regards,
noorulhassan.
Nov 06, 2008 | Yahoo YHT-630 System
Error 81003005
hi,try the solution posted on this site: http://stephenhaim.com/resources/yahoo-messenger-81003005-error
Oct 19, 2008 | Yahoo YHT-630 System
Oct 18, 2008 | Computers & Internet
81003005
my yahoo messenger cannt singn in . due to error code 81003005.plz help me. how my messenger open.plzzzzzz
Sep 16, 2008 | Yahoo YHT-630 System
Yahoo Messenger Logo
188 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
Sunday Ojelabi
Sunday Ojelabi
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
