Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
2nd light will not stop blinking and allow us to make coffee
Can anyone help solve the problem?
  • 515 Answers
Try to open the steam knob and make a cup of water, you have to fill upp the boiler with water.
Posted on Jul 11, 2008
Blinking blue light on water reservoir won't stop blinking
Needle port is plugged. Clean with paperclip end and run it up 1/4 into the tank to clear the debris.
Apr 10, 2013 | Keurig B60 Coffee Maker
Red light flashing
If you mean a slow blinking (1 for second) this means that a tray (water, coffee, ...) is not properly set or closed; but if it blinks quickly (about 2 flashes per second) this means a generic "problem" and you'll have to take the machine to an assistance center. I've regurlarly (every 2-3 months) the 2nd type of blinking and I'm looking for a solution because it costs me about 80$ each time.
Mar 21, 2013 | Saeco Odea Go
On light will not stop blinking on my Senseo coffee machine
my senseo did the same. i read on hear to clean magnet/float mechanism inside the water resevoir. i did this with a tooth-brush and soapy water. as you invert the empty water container you will see/hear the float slide up and down when clean. work a treat for me.
Nov 20, 2012 | Philips Senseo HD-7810 Coffee Maker
Saeco Eclipse stopped functioning
Have you solve your problem with Odea. Mine is new out of the box and not working at all. Red light blinking, manually prime it and so far only tree cups of coffee. After priming it the green light was solid and could make 3 cups then stopped. Any advise greatly appreciated.
Dec 12, 2011 | Saeco Odea Go
I own a saeco Vienna 'limited edition'. When making coffee, the cycle stops when the water pump starts. Coffee light blinks and the red light turns on. It started when i tried to use the steam...
Hi. Sounds like a blocked or jammed brew unit. Remove brew unit and clean. To properly do this, you need to disassemble the brew unit. Canbe quite hard to do. The brew units are usually held together with plastic tabs, and may have to remove some screws to allow these tabs to release units assembly. Dazza REPAIRER
Sep 24, 2011 | Saeco Vienna SuperAutomatica Coffee...
Cleaning light will not quit blinking after cleaning
The same thing happened to our Mr. Coffee this week! I followed the instructions about running vinegar through, then rinsing several times with water. However, the light would not stop blinking. We did by-pass the light by setting the timer for delayed brewing and it worked. However, that blinking light came on again. Then, my husband tired the vinegar wash again but instead of doing it one time, he ran the same vinegar through 6 times until the light went out! Then he proceeded with the water rinse. Our Mr. Coffee is working again!
Nov 16, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Hard shift and blinking overdrive
The blinking overdrive button is telling u that a serious fault has occurred in the electronic controls or a mechanical fault such as excess slippage is occurring.
Jul 16, 2008 | 2000 Ford Ranger SuperCab
Can't get the coffee light to stop blinking
Try to take out the degdraw box and make sure it is off the machine 10-20 sec then put it back again.
Dec 30, 2007 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
95 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
