Question about Ubiquiti PowerBridgeM5 Networks PowerBridge M5: Carrier Class 5GHz MIMO Bridging Solution
Powerbridge m5 wont reset when reset button is pressed. when ping the LAN interface it says destination unreachable
My motorola canopy cannot detect LAN Destination Host Unreachable?
Sir raymond, how can i access my Motorola canopy? when i upgrade the firmware to the latest version and didn't specify the correct IP address of canopy instead of example: 10.223.41.42 i used the 169.254.1.1 in CNUT after upgrading the version my PC LAN card cannot detect anymore the canopy. canopy lights still blinking inside but in PC LAN card not blinking and its says network unplugged. how to fix the problem.. please send me the step on how to fix it.. here's my email add: amanics007@hotmail.com waiting for your response. thanks!
Apr 20, 2013 | Computers & Internet
I lost my software disk for my wireless printer. I download drivers on line and still can not work wireless. It works fine when its hard wired. But when i unplug it, it goes offline. I have tried alot of...
For that first make sure your wireless network adapter driver is working fine.Try to uninstall and then reinstall . Then check the ping of your wireless printer ip address you can check it in "run " for that press windows key + R key then you can see run type in run "ping 192.168.1.1" without where 192.168.1.1 assumes ad your printer ip. Then press enter then if you get "reply from..." then printer is in network but if you get "request time out or destination host unreachable then it is not in network then check your printer ip address and your computer ip address. Also reinstall printer driver from below link. Click here Let me know if you need further assistance. Thanks for using FixYa.
Aug 27, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Staus led not blinking after a fw update
You are going to have to find a software that helps you force reinstall the Firmware. Something went wrong somewhere, I know the software exists, i used it to install a 3rd Party Firmware on my linksys to gain Access Point Functionality
Apr 14, 2010 | D-Link AirPlus DI-524 Wireless Router
Cicso router 1841 not connecting to the internet
When using Public IP addresses on one interface, usually facing your ISP, and using Private IP addresses (AKA RFC 1918) on another interface, usually facing your LAN, one needs to utilize network address translation (NAT) in order to connect LAN computing resources to the Internet.
Cisco has a fantastic article on how to perform the necessary procedures on their web site.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080093f8e.shtml
Sep 06, 2008 | Cisco (1841) Router (cisco1841)
WAP54G bricked power led blinking LAN connection shows as not connected
you did not specify where the wap is connected when you pinged it. Try this, connect the wap54g to your pc. Assign static ip 192.168.1.5 on the lan of the pc, then ping 192.168.1.245. if you can ping you should be able to access the configuration page. if the power is still blinking you can upgrade the firmware
Mar 10, 2008 | Linksys Wireless-G WAP54G 802.11g/b...
Sonicwall tele2
Hello ask4jon, I gave this advice at an earlier time and I think it applies here to. What I want you to do is to reset your router by locating the Reset button on the back of the SOHO TZW next to the LAN connection. Using a pointed object, press and hold the Reset button for 5-10 seconds. All settings are returned to the factory default settings including the password and the default LAN IP address of 192.168.168.168. The I want you to reenter your ISP information and configuration settings. Once this is done try to ping your gateway (ISP gateway router) address. Then try to ping the internet try to ping this address: www.dslreports.com This is the quickest way to get back to where you want to be without trying to redo a lot of configurations.
May 29, 2007 | SonicWALL TELE2 Firewall
Routing problem
I don't know if this will help because I don't see what you and seeing but here is an idea: In every routing scenario I have experienced, you must specify a default gateway with a specific IP address. 0.0.0.0 only points to the device itself, not the other WANS. The gateway IP addresses should be statically assigned. If there is DHCP involved, insure that the gateway address is not part of the DHCP scope but in an excluded range of reserved addresses. For SMTP to work the gateways (and you should have 2 or 3) must be properly configured and TCP port 25 enabled.
Dec 09, 2006 | Zyxel ZYWALL 35 Firewall
Destination host unreachable
Hi you should check your network settings ie IP ADDRESS, DNS etc, and also check to see that your proxy settings are unticked. John
Oct 23, 2006 | D-Link DFE-538TX Network Adapter
Ubiquiti PowerBridgeM5 Networks PowerBridge M5: Carrier Class 5GHz MIMO Bridging Solution Logo
Top Ubiquiti Computers & Internet Experts
David Payne
David Payne
Are you an Ubiquiti Computer and Internet Expert? Answer questions, earn points and help others
