Question about Belling XOU174 Electric Single Oven
How to find the serial number in built in oven
Need to order element.
  • Belling Master
  • 5,323 Answers
Usually located in the lower drawer or the door when u open it should see a sticker with number
Posted on May 03, 2015
Non fan oven faulty
The ring element around the fan is probably gone. You should be able to pick up a new one easily enough. You will need the serial number of the oven when ordering . There are numerous spurious spares available.
Dec 27, 2015 | Ovens
Maytag Model MEW6530 Baking Element
Theck the thermostate, the thermostat is the circuit that activates the heating, and power the baking element , when this is faulty there is no heat or low it, give it a check.
If you need to buy the replacement part, or to locate the thermostat, check on this website, they provide exploded view, so that you can locate the part.
Oct 29, 2008 | Maytag 30" Built-In Single Electric Wall...
How do I check to see if the oven is working properly?
You need to
A/ FIRST TURN THE OVEN OFF COMPLETELY.
B/ Get access to the terminals ( usually at the back of the cooker)
C/ Disconnect the wiring from the terminals, there will be 2, 1 on each terminal.
D/ Obtain a multimeter and set it to ohms
E/ Place 1 lead on each of the terminals and check the reading in ohms on the scale.
F/ No reading on the meter indicates the heating element has gone open circuit or blown.
G/ Obtain make/serial number/type. Order a replacement from a supplier of heating elements.
Sep 15, 2014 | Whirlpool GMC305PDS Electric Double Oven
Can't find model number for old Hotpoint custom oven
Hi Marcia,
It's going to be difficult to locate parts based on a catalog number - as you have learned, parts are based on model numbers.
You may want to do a little bit of testing before you embark on finding a replacement element. I would remove the element from the plug in socket and measure resistance of the element itself (20 to 40 ohms is typical), or voltage at the socket with the oven set to turn on the bottom element. Assuming a 240 volt oven, you should see this same voltage present at the socket. If you do have the voltage, locate a replacement element. If you do NOT have this voltage, you need to locate the source of the failure and have it repaired or replaced. You should inspect the metal plate on the element to see if a part number is present on it - as that will solve your parts identification issue.
There's not a huge difference in a lot of these elements besides physical dimensions of the element and between the connections for the socket. Have a look at these Hotpoint parts & GE parts and see if any of them looks like yours and then go from there. Some of the appliance repair parts sites might even be able to help you with the catalog number issue, too.
I hope this helps & good luck!
Oct 17, 2012 | Ovens
Ge electric oven will not turn on
Hi Shane I need a little more info , like dose the broiler work ? dose the burners work , most times if the lower element isent working it has burn out , this is a cheep easy fix, look at the element with a flash light for damage it will have bump's on it or could be broken right off , this is the first thing to check , If it is the element I can locate you one to order and tell you how to change it but i will need the model and serial number and also is it the top or the bottom element , get back to me, and please always remember to rate this question: thanks Frank
Dec 13, 2011 | Ovens
Hotpoint BD 42 Oven, main oven fan turning slowly and oven is not heating up to temperature
Hi you will to have a tester , start off by checking power at the outlet , if you have the 220 volts then we need to check the elements inside the oven, you may a have a bad element and a bad fan , after checking power get bacl to me , also need model number and serial number
Dec 01, 2011 | Ovens
The bracket which holds the ceiling heating element up in the microwave broke so now the heating element is hanging down into the microwave cavity. How do I get a replacement part and is it easy to...
The brackets are usually made of heat resistant plastic, or bakalite, you can search for parts at www.whitegoods.co.uk but you will need model and serial number, a word of caution, the microwave oven may have to be dismanteled to fix new element holders, you can still get shocks from them even though the mains power has been disconnected, depending on the age of the appliance and availability of parts, it may be a replacement is required.
Hope this has been helpful
john
May 19, 2011 | KitchenAid 27 in. Built-in...
Have built in oven PBS305PRS00 what would cause broiler element to melt in several different places. It is now is several pieces.
The element needs replacing. That's wat they look like, when they need replacing. Make sure you have the model number and serial number when you Call, or go to repair shop
Mar 30, 2011 | Whirlpool RBS305PDS Electric Single Oven
Inherited uncle's house that has an old electri-clean cookmaster oven. the element is not working but the fan comes on when you turn in on...can't find the serial number to get the look for correct part or...
Sorry to read about your problem, I hope this helps you out.
without the model number, you will need to have a service company, come and look at the unit,
tell them on the phone, that you dont have a number, and to send their most experienced person. then they can match a coil up....
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 01, 2011 | Frigidaire 24" Built-in Single Electric...
Belling XOU174 Electric Single Oven Logo
46 people viewed this question
Top Belling Ovens Experts
ashburton
Lawrence Oravetz
Are you a Belling Oven Expert? Answer questions, earn points and help others
