Question about Power Health Scooter Wheelchair Programmer Ds100 Dynamic Rhino Power
Push the lever but no drive
Got no drive when I push the lever forward or reverse was charged up I just parked it and now it wont move?
My Lt155 ride on wont engage in forward or reverse
(Simple answer)Hydrostatic drive machines have a setting that allows you to push them. machine won`t move if this is engaged.
Also If park brake is on. Otherwise check drive belt has not snapped is loose or broken. Jack machine up and see if wheels will drive without weight of machine.
Jul 26, 2014 | John Deere Garden
Scooter won't move when forward/reverse engaged.
http://mobility123.com/help-fix-mobility-scooter-powerchair/
Engage the freewheel lever
- allows you to operate the mobility equipment with the standard controls.
Disengage the freewheel lever - This unlocks the unit and allows the wheels to spin freely. You can easy push the equipment without power. This is especially helpful if you run out of battery power and need assistance.
Apr 21, 2017 | Health & Beauty
Brand new Troy-Bilt XP Horse, model 13bx79kt011 - Won't Move
Confirm the park brake is off. If a hydro-static drive tractor starts but engagement of the operator controls for the transmission drive results in neither a forward or reverse drive of the mower itself, the operator should check that the manual bypass controls have not been left in the activated (bypass) position.
Look in to where the lever connects and confirm the movement. You should be able to hear the hydraulic oil with a slight whine as you activate the drive forward pedal!
See page 18 for bypass setting?
Cut and paste link
http://www.troybilt.com/wcsstore/TroyBiltUS-CAS/Attachment/ownersManuals/riders/HorseXP_2012_769-07569[1].pdf
Jun 27, 2017 | Garden
Mower starts and runs but won't move forward or reverse and brakes don't work.
If your transmission is automatic on the drive axle, look for a small lever inside the frame and below the seat. It can be hard to find the first time. This lever disengages the drive inside the auto gearbox so the mower can be pushed by hand. If the lever is not not moved, pushing the mower also tries to turn over the engine making it impossible to move. With the lever moved accidentally the drive is disengaged and the mower won't move in either direction. The lever operates a flexible cable that comes out from the auto transmission.
Dec 12, 2012 | Craftsman 24 Hp 48" Deck Yard Tractor
Shifter is erratic. wont start in park. drives forward when shifted to reverse, sometimes drives forward when in park. sometimes reverse is neutral (which is good so it will start!!!) what is going on???
It sounds like the linkage at the transmission has come loose. Have someone get inside and move the shift lever from gear to gear so you can see where the linkage is on your transmission. You'll have to climb under ypou truck to see this, on the drivers side. check to see that all the bolts are tight. Your switch that allows you truck to start in Park or Neutral is located there.
Oct 25, 2012 | Dodge Ram Pickup 1500 Cars & Trucks
My 2000 ford explora wont shift into park, i have to leave it in reverse to get the key out and put the Ebrake on and shut it off. when i put the car in drive it goes all the way to the number 1, can you...
The shift linkage is out of adjustment.
The cable bolt may be loose up at the column, the column itself may be loose enough to allow it to shift position as well.
Make sure column is securely mounted, If not- tighten the 4 bolts that hold it to the dash support so it is. if it is, crawl under driver's side and on the transmission is a bracket where the cable assembly comes into it, and from there a rod that attaches on the lever on the side of the transmission. Make sure the bracket is not damaged or cracked first- if it is, replace it. There is a captive clip to release on the wide part of the piece that the bracket holds, it does not come out fully, but it will release the cable housing so you can slide it to adjust it. With the column shift in Park position, note where the rod is at the transmission. Also make note if the bracket is in line with transmission. If bracket is in line, pull the lever rearward one notch/detent that you will feel engage the lever- this moves the transmission lever to neutral, then with firm pressure push lever forward so you feel 2 distinct notches/detents forward, the lever is now in park. Push locking clip back into position once you confirm the cable outer housing is squarely seated into bracket opening and is soundly clipped into the square opening of the bracket.
If the lever will not move to that second detent or you did not feel it, you will need to check by putting the column shift to first gear position, release the connection to the lever on the transmission just to verify location of lever, and verify the lever is indeed in first gear- the lever on the transmission will move no further- then count detents forward from the rear stop. you should end up in park, and you may hear the parking pawl engage the output shaft of transmission. move lever back to the rear to the stop, reattach the connection to the cable, put column in park, release the clip again and verify the lever is as far forward as it is going to move. Push clip into lock position.
Start Explorer, with foot on brake pedal, release the emergency/parking brake and see if the vehicle moves, or if it is truly in park. It should be in park.
If you encounter some dificulty with getting the column shift lever itself moved over to park- apply brake pedal to release the park interlock mechanism.
Jan 30, 2012 | 2000 Ford Explorer
John deere x340 wont move
there is a release usually behind the seat that has to be pulled in order to push it physically. make sure that the release is pushed in for the forward/reverse to work.
May 26, 2009 | Garden
1994 Toyota Camry automatic. All forward no reverse
are you sure it is first gear it is making when in 1. In park does the car lock up if you try to push it with the handbrake off. If not your problem is adjustment of the cable i.e. although the lever is in reverse the gearbox isn't.
Cheers John
Dec 12, 2008 | 1994 Toyota Camry
Gear shift lever wont go into park; there's no problem with transmission or fluid vehicle works fine but i cannot get the shift lever to go into park, also i can remove the key while its in the reverse...
I have a Dodge Charger 06 model and the gear wont move from Park to reverse. everything else works as far as gas, brake light, etc but my gear wont shift can i get soem help
Nov 05, 2008 | 1996 GMC Jimmy
Transmission wont shift into park
need to adjust the shift linkage
Sep 12, 2008 | 2001 Dodge Intrepid
Power Health Scooter Wheelchair Programmer Ds100 Dynamic Rhino Power Logo
37 people viewed this question
Top Power Health Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Power Health Health and Beauty Expert? Answer questions, earn points and help others
