Question about T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3 i have a phone and when i put the charger in the light dosent turn on and its not charging but the phone turn on and every ting works on the phone its just that problem.
  • Anonymous Nov 02, 2007
    I have exactly the same problem. I am looking for a sidekick3 service manual.
  • 4 Answers
I have had in all 5 sk3s. All w/ problems. 3 of them have the charger port problem. One had the white screen problem. Another had the backlight problem. I have been able to make two completely good sks from this mess. The charger port thing is a big deal, but I found a MUCH CHEAPER solution /workaround then the $30-40 cradle. It is a China made external Universal Cell phone charger. They go for less then $5 on ebay. They are ugly and clumsy, but cheap, simple and super compact. They can be kind of confusing to figure out at first because they don't come with instructions. I finally figured mine out and it's charging up one of my good SK3 batteries right now. I didn't think it was charging because the battery was cold, but when I put it in the SK, it fired right up, even though it wasn't full. They have little adjustable electrode contacts that you can put on just about ANY cell phone battery including ALL the SK series. The Cradle for the SK3 is only good for the SK3, these cheap universal chargers are good on ANY PHONE.
Posted on Dec 01, 2008
  • 625 Answers
Sad to say, this is a common problem with the sidekick 3.
The charging port probably has gone bad. If it is under warranty call t-mobile.
If not, you can have it repaired but it can be pricey.
A workaround is to buy a sidekick charging cradel with a spare battery charging slot. An extra battery makes this easier. This will allow you to charge your battery outside the phone.
Both will cost you about 40 dollars total on eBay.
Sidekick 3 Charging Problem
Posted on Dec 05, 2007
The light comes on but it dosent charge
your battery is probably worn out, so it will no longer charge-find info about your battery online then buy a new rechargeable battery for your device
Jul 23, 2009 | T-Mobile Sidekick
Sidekick not charging
do you mean like the orange light is not light up when
it were charging, correct? if so, then you need to get a new charger.
your charger is probably dead and no longer working.
if you want ,i have a brand new charger that i do not need(bec, i have
few of them laid around and need to get rid of it) and will selling
it for pretty cheap.
so let me know.
Jul 19, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick id charger light comes on but phone wont the screen wont turn on but charger light is on
Sounds like you unit is not charging. The Sidekick ID's are notorious forthat. If you have a friend that has a sidekick ID or Sidekick 3, see ifyou can try their battery to make sure you phone is working ok.
If so, your best option is to get an external charger that has a sparebattery slot That way you can charge the battery outside the phone!They run about 25-30 dollars on ebay. an extra battery is a good idea so you can have one charger at all times.
Sidekick ID and Sidekick 3 External Battery Charger
Jun 29, 2009 | T-Mobile Sidekick ID Cellular Phone
Sidekick 3 Charging Question
I can tell you the sidekick 3 will not operate properly with out a back cover. In fact, if you remove the rear cover while powered on, it will post a warning message on the screen.
Because you tested and successfully operated the phone with out complication with a back installed I fell confident you should have have any problem with the phone when your back cover arrives.
Good Luck
sponsored by Cell Phone Technicians
Dec 20, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3
If the orange light is coming on, but not charging the sidekick then the charger port is probably bad.
It's about 80 dollars to fix at cellulardr or you can do a work around and charge the battery seperate from the phone.
check out the charging cradle here:
Sidekick 3 spare battery charging cradle
Dec 13, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Phone wont charge
The sidekick ID charging port can go bad like the sidekick 3's. An easy workaround is to get an external cradle that has a spare battery charging slot.
The trick is that the sidekick 3 and sidekick ID batteries are the same so the sidekick ID battery can be charged by the external cradle. An extra battery is a good idea as well so you can have ine charging at all times.
Check the cradles out here.
Sidekick ID external Battery Charger
Sep 10, 2008 | T-Mobile Sidekick ID Cellular Phone
Sidekick 3 wont turn on
if the light indicates but its not charging. one other thing you can do is a soft reset.take out your SIM card and batter for 30 seconds then replace the SIM card, and hold on to the R button and at the same time replace your battery, your phone should turn on and restart twice. but it will come on.
Apr 06, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick ID
The sidekick ID has the same type of charging port as the sidekick 3, which are notorious for going bad. The easiset thing to do is get a charging cradle that has a spare battery slot.
Mar 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick 3 wont turn on
heres what i would say. let it charge for more than hr, and this bring it up to speed..if not i believe the battery may be defective, i just experienced this problem last night..the battery happen to be defective, then put another battery after awhile i went to sleep woke up, and it wouldn start...i let it charge for a while and it was good as new
Feb 11, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My side kick 3
The sidekick threes have an issue with the charging port going bad.
If under warranty still, call t-mobile to get it fixed.
If out of warranty, you can get it fixed or buy an external battery charger and a spare battery. This will run you about 40 bucks on eBay.
Sidekick 3 external battery charger
Nov 22, 2007 | T-Mobile Sidekick® 3 Cellular Phone
T-Mobile Sidekick® 3 Cellular Phone Logo
61 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
