China clone mini 7100 gsm hard reset
How to enter recovery mode
How can l flash and unbrik my china clone iPhone
There are different type of cheap iP{hone knock off. They all run Android. Depending on your model, maybe you could get to the recovery and hard reset your device, this will set it as factory default.
If possible Google "how to hard reset (your device model)".
Jul 12, 2016 | Apple Cell Phones
How do i fix?
This can happen for a number of reasons. You could have a virus on the device, the operating system could be crashed, there could be a hardware glitch.
I would start with attempting to boot the phone into recovery mode. You can follow the steps attached to do so. Once you get into recovery mode, try to select the option that says "Clean System Cache" and then reboot the phone.
If upon reboot it still gets stuck at the screen, boot back into recovery mode and do a factory wipe.
http://www.hard-reset.com/huawei-ascend-y530-hard-reset.html
Feb 23, 2016 | Huawei Ascend Y530 Y530-U051 Unlocked GSM...
How do I uninstall the new Android system update?
Factory reset the device but it will delete all photos,apps and data. You can backup them and then proceed,
Not Recommended for a Clone Mobile/China Mobile!
Jul 03, 2015 | New Android Apps
Android phone pattern locked
You can Easily Reset your Gmail Password For your Account all you have to do is Type in your username at Gmail.com and If you select Forgot Password, you can reset it to Something you will Remember.
Jan 04, 2014 | Samsung Galaxy Mini
Micromax master resetting code all
Hard Reset Micromax Canvas HD A116
  • Switch Off your phone.
  • Press and hold Power button together with 'volume +' and 'volume -' buttons on the side of phone until you get two options.
  • Now, press the 'volume +' button to enter into the recovery mode.
  • This will make a Android icon appears on screen, press power button.
  • This will get you the menu options, use the volume up and down button to choose the option.
  • To select the option, you needs to simultaneously press two touch sensitive buttons on the bottom of your device, left button which is for the Menu and right button which is for going into previous stage. You have to do this for about 3 seconds.
  • Choose the wipe data/factory reset then press the enter button (left button which is for the Menu and right button which is for going into previous stage). Now, phone will get switch off and brings to its initial stage.
Done! with this default way to factory reset you have successfully done with hard reset of your Micromax Canvas HD A116. The hard reset procedure is same for Micromax Canvas A110 also. If you have any questions regarding the procedure to hard reset Micromax Canvas HD A116.
OR
The Instructions
  • Turn Off your device
  • Press and hold the Volume up (+), volume down (-) and power keys at the same time until the screen show the two options
  • You will get the option Recovery mode and Factory mode , to select the Recovery mode press the volume up (+), for the Factory mode press the volume down (-).
  • If you want to hard reset your smartphone, you should select the recovery mode.
  • To navigate it, you can use volume up and down.
  • To select an option, you must press the Menu button.
  • After you hard reset the device, your smartphone will return to factory setting automatically.
OR
Hard Reset:
  • Press and Hold Volume Down + Power Key for 20-30 Seconds.
  • Now you See Warning Logo on screen.
  • Now Download Android Multi Tool
  • Download fastboot driver and install Drivers
  • now open tool and press "8" and enter to wipe data / factory reset.
  • after format remove battery and reinsert battery.
  • power on the handset.
  • Download Driver from Here
  • Download Android Multi Tool from Here
Nov 07, 2013 | Cell Phones
Computer wont start or boot up cursor line on top blinks please help ?
Your computer can't find the OS on your hard drive. Most likely the boot sector has been damaged (or someone reformatted the drive). The entire hard disc may have failed.
Since this is a netbook, you will either need an external optical drive (USB) and a copy of the OS to boot from or a USB flash drive that has been prepared as a boot version of the OS. HP offers the Mini 5101 with WinXP Home, SUSE Linux or FreeDos. There may be newer versions with other OS options. Make sure to get the correct OS, even if you upgraded it.
You will need to boot to the optical drive or the flash drive. On other computers, this may involve accessing the BIOS to change the boot order. Look for a splash screen with the key information. Then turn off the computer and turn it back on while repeatedly pressing the key. (F1, Esc, Del, and F10 are common keys.) If you miss the timing, turn off the computer and try again.
If you are using XP, you will need to enter the Recovery Console. Then enter the command line mode. If your command prompt starts with any character other than C. Type C: then press Enter. Next type CD WINDOWS. Then try the BOOTCFG /REBUILD and see if a Windows OS is found. (type the command in and then press enter). Then type in the command FIXBOOT. This repairs the boot sector. You will need to confirm the commands. Type CD .. and CHKDSK /R /F to check for and fix damaged hard drive areas
If this worked, type EXIT. Try rebooting the computer. Otherwise use the command FIXMBR and then exit. Enter the HP recovery program (on the original hard disc or on Recovery discs, if you made them). Restore the computer to the original configuration with that program. If you ever did anything to repartition the hard drive, the recovery partition may not be accessible. You will lose any stored files and need to reinstall any programs you added to the netbook.
I hope this helps. Please note: losing this part of the hard drive may indicate that you have a failing hard disc. You will need to decide if you want to replace the drive or the netbook. If you decide to replace the hard drive, match the original drive size and data/power specifications (2.5" drive and SATA cable, probably). Use a USB/SATA/IDE hard drive adapter and a cloning software either added to the hard drive or from an optical disc to transfer the OS to the new drive and then set it as the boot drive before installing it in the netbook.
Sep 22, 2012 | HP Mini 5101 Netbook - HEWLETT PACKARD...
Hi I bought a iphone 4 clone in china. I'm not sure about the model: the label inside states: Model F8+. It is a dual SIM, GSM/GPRS GSM quad band 850/900/1800/1900. The phine worked in china with my...
Ciao! Go to settings- SIM card settings and set both SIM cards as active, usually it helps. If not, reset the phone settings, the code is 1122. Spero che ti risolva la tua problema.
May 15, 2011 | Apple Cell Phones
How can i insert memory card into nokia 7100
Nokia 7100 Supernova is a low-to-mid-end phone in slider form factor work on Tri-band GSM network. It features TFT262k colors, FM radio, Bluetoothmag-glass_10x10.gif 2.0, USB 2.0, Opera Mini browser, Flash Lite 2.1.1, MicroSD card slot and 1.3 MP camera
yes, it has a micro SD card slot, u can see it ussually on d side of the phone it looks like a small thin square hole. then u can insert the SD card to the slot.
IF YOU THINK THIS ONE IS A HELP. VOTES ARE VERY MUCH APPRECIATED :))
Jul 26, 2009 | Nokia 7100 Supernova Cell Phone
Computers & Internet Logo
288 people viewed this question
David Payne
David Payne
