Question about Smartboard Smart Board UF55 Projector Lamp
Smartboard projector solid red light
Have replaced lamp but projector will not stay on green light after a few mins changes to solid red
Blinking green power light on ux60 projector
I would refer to this page to determine if you ahve an internal problem or if your lamp is bad. Make sure you buy a lamp that has an original bulb inside and not a compatible. Original bulbs cost less than OEM but more than OEM-Compatible(knock off) but they last as long as OEM bulbs. Your SMART Hub Doesnt Turn your UX60 Projector On or Off 146535 SMART...
This link goes to a highly reputable company. They have the same Osram bulb as the OEM. SmartBoard Lamp
Mar 04, 2014 | Smartboard Smart Board 685ix, UX60...
Red and amber solid light showing on projector
I get this occasionally, with the crazy wiring we have in our building it seems to be a surge. We have had it go on for weeks, then stop. One last year eventually had to be replaced for a fan fail, not sure if it was related.
Dec 16, 2013 | Smartboard Smart Board UF65 Projector Lamp
Epson 460 powerlite hooked to smartboard green light blinking and no image.
Yes this is most likely the lamp. Does it eventually go back to just a red light?
Dec 06, 2012 | Epson PowerLite 410W LCD Projector
Mitsubishi projection T.V
check the lamp first to see if intact or shattered.
Mar 31, 2012 | Mitsubishi Televison & Video
Optoma HD66 replaced lamp, LAMP WARNING light keeps flashing, still won't turn on?
i just had the same problem i took the top of the projector off and cleaned the color wheel and sensor seemed to have fixed the problem that is for now. seems to happen to me once a year on the dot but last time it was warranty. good luck hope it helps.
Mar 17, 2012 | Optoma Office Equipment & Supplies
Replaced lamd power and lamp light are green for
Yes you need to replace lamp,so you buy a new lamp.
Dec 14, 2009 | Sharp Notevision PG-A10X Multimedia...
Two solid red lights on
This will most probably cost you replacement of the lamp
Mar 04, 2008 | Sharp XR-10X Multimedia Projector
Smartboard Smart Board UF55 Projector Lamp Logo
112 people viewed this question
Top Smartboard Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Smartboard Office Equipment and Supply Expert? Answer questions, earn points and help others
