Question about Nesco TM-1 Tea Maker
No power on nesco tea maker
Plugged in but has no power
  • 210 Answers
Change the fuse in the plug
Posted on Mar 29, 2014
Plugged in ana exxternal water heater and none of the breakers flipped but now our plugg ins are not working what coud be the problem
There may be a ground fault interrupter duplex plug in unit that has tripped. They are often placed as the first plug in in a circuit and therefore they protect plug ins "downstream" from the breaker box. It may be located some distance away from your recognized problem plug in. Some of them still work themselves, but still shut off power beyond. There should be a reset button on the unit.
Dec 21, 2015 | Water Water Heaters
Whirlpool French door not making ice, but can get water. I had the water valve replaced and it still does not make ice help
Okay, here's a bunch of info in the order I would troubleshoot since the one year warranty expired.
1) The water filter might be clogged. Try just removing it to see if it makes ice. If it does change the water filter.
2) The water inlet valve might (still) be defective. The water inlet valve is an electro-mechanical valve. The coil can show good for continuity and still not let the water thru although you didn't say if it worked when he left. if recently replaced it should be under his warranty.
3) The water pressure in the house might be too low. The water inlet valve which supplies water to the ice maker is designed to work with a minimum of 20 psi of water pressure.
4) The door switch might be defective. When the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice maker and dispenser. If the door switch fails the dispenser will not turn on. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.
5) It could be that the ice maker assembly itself is defective. The freezer temp should be between 0-5 degrees for the ice maker to cycle properly. There are several components in the control module of the ice maker that can fail and most are not sold separately. Also, ice makers have a relatively short lifespan and so it might not be worth fixing. If other, simpler parts like the water inlet valve or shut off arm have been ruled out, and the only thing left is the ice maker itself, replace it as a unit. Not as expensive as you may think...Under $100
6) The icemaker module at the front might also be defective. The module has a motor that cycles the ice ejector arms around to push the ice cubes out when the ice maker thermostat closes. It also has contacts in it for the mold heater and water inlet valve. The motor or contacts of the module can fail. Usually there are test points in the module that a service person can use to determine if there is a problem with it or one of the related ice maker components.
7) The icemaker mold thermostat might be defective. Inside the control module of the ice maker is a thermostat which monitors the temperature of the ice mold (ice tray). Once the mold reaches the proper temperature the ice maker starts a harvest cycle by ejecting the ice cubes and refilling with water. If the mold thermostat is defective the ice maker doesn't advance. The thermostat can be checked for continuity. Replace it as needed.The freezer temp should be between 0-5 degrees for optimum performance.
Sep 17, 2014 | Whirlpool Gold GI6FARXXY 25.5 cu. ft....
Why doesn't Krups FME214/86B coffee maker turn on?
sounds like a loose internal connection, best left to pro but if you can remove the bottom panel you should be able to id the culpret. If its in the top portion (depends on where you tap it) it's a lot of work to get into that area.
Sep 15, 2014 | Krups Fme214 Programmable 12-cup Coffee...
Ice maker not working just changed the filter water works but ice maker not working
Check the plastic lever on the door. It usually moves closed when the door is shut to turn ice maker on. The lever can freeze and stop the ice maker.
Sep 23, 2013 | Whirlpool Gold GI6FARXXF 25.5 cu. ft....
Ice maker not getting water
try changing your water filter for your ice maker thats located in the fridge part in the back
Apr 11, 2013 | Emerson InSinkErator W-152 Point-Of-Use...
Brand new whirlpool dishwasher starts on own
Because you cheated and filled it manually, it may be that the second running was actually resetting the programme. Do a normal wash, and if it does it again, contact the maker for advice.
May 10, 2017 | Whirlpool WDF750SAYB Gold Series...
Unit loses power randomly. I have to play with the power cord and eventually it powers ups and stays up for a while a Noritz 0635 insalled in January 06
It sounds like the plug may be loose disconnect it and look at the ends and make sure they are straight and no burn marks on them then plug it in firmly and see if that helps
Dec 16, 2010 | Noritz 6.9 Gallon Residential Direct Vent...
We have a Power Star Bosch water heater it find for two years but now it take longer to get the warm water and it turn back to cold very fast. Model #45-557701
Call BOSCH 800-798-8161 tech support. If it is not too old even out of warranty they will help diagnose. You can get parts for free in warranty and buy parts at www.houseneeds.com out of warranty. If it gets hot fast and then stops, one of the "Thermal cutout switches" is cutting out. The water flow it probably blocked. (Just a guess) On many models they have a "Screen" and or a "Gromet" that you can clean out. If your water is really hard the whole unit may be clogged. I believe the "SAFE" thing to do is replace it but again I say CALL BOSCH TECH SUPPORT. I have also heard of people "Cleaning the whole units with vinigar, like cleaning a coffee maker. TURN OFF POWER! TURN OFF H20! REMOVE UNIT, then clean.
May 19, 2010 | Bosch PowerStar AE115 Tankless Water...
Nesco TM-1 Tea Maker Logo
21 people viewed this question
Top Nesco Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Nesco Water Heater Expert? Answer questions, earn points and help others
