Question about Kenmore Elite HE4 Electric Dryer
Squeals while drying clothescould this be a bad belt ?
Recently started making a squealing noise at times while running
  • 1,162 Answers
It can come from two things, belt for sure when you over load the dryer or it is getting worn an second the rubber wheels the drum sets on can squeal.
Posted on Mar 29, 2014
  • 409 Answers
SOURCE: noisy dryer
hi there,
the rattling and squeeling noise usually comes from the drum shocks. they do wear out due to use. i would recomend replacing them.
Posted on Oct 11, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Kenmore gas dryer 97273100 was drying, but making a loud noise
You need a belt. Here's a link to a site with a good set of instructions if you want to try repairing it yourself. (You should DIY. You can save a bunch on the service call and the belt is only about $20.)
http://repair2000.com/wpoolbelt.htm
Posted on Dec 08, 2008
  • 401 Answers
SOURCE: My kenmore dryer is making a squealing noise. It
This sounds like it could be the tensioner pulley is worn or needs a drop of oil, or the drum rollers need the same. If they are worn too much they will need replaced. If the tensioner pulley is stiff, replace the belt as well.
Posted on Jan 03, 2010
heatman101
  • 43501 Answers
SOURCE: My kenmore elite he4 dryer just started making a
Check out this tip about your problem...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Posted on Mar 28, 2010
ftw1952
  • 10319 Answers
SOURCE: The dryer started a squealing and slamming noise
$30 repair for a DIY
Top and Front panels are removed
Replace the belt & tensioner pulley which SEARS sells in a KIT
Posted on Jun 15, 2010
Really Bad Squeeky Noise
It could be a squeal from the dryer belt. It could be from a belt that has gotten loose, like you hear on a car sometimes when it first starts up, but usually they don't get loose. They just break. Maybe something has gotten jammed between the dryer drum and the interior of the dryer making it hard for the belt to turn the drum and so it is squealing. Does the drum turn by hand without too much force and without squealing?
Feb 10, 2014 | Siemens WTXD5300US Electric Dryer
My 2007 avalon squeals every time I put the AC on? What should I do?
Make sure its simply not the A/C tensioner thats gone bad. You might just have to replace that one. There's absolutely no reason a belt should be the culprit unless it is tearing or ripped so you can look for wear and tear on the belts. Most likely a pulley is out of alignment or the pulley bearing is just starting to squeal when it gets wet. But it can still squeal if its dry outside.
Take the belt off and spin it with your hand, if it squeaks, its bad. I had to replace one years ago, they just go bad. Make sure the A/C compressor isn't whats squealing too, and the other top pulleys too. Sometimes you can be fooled on where the squeal is really coming from. Spin everything that can be spun, by hand.
Apr 17, 2013 | Cars & Trucks
1999 dodge durango 5.9 v8 loud squealing noise from under hood replaced tenison pulley, idler pulley, ac pulley/clutch assembley,and belt please help
You didn't mention the alternator, power steering pump, or water pump. In fact, any pulley other than the crankshaft one can have a bad bearing or dry seal. Remove the belt and spin each pulley while listening for any rough noise or squeal. If it was the crankshaft, it might be time to check the oil. Start the engine with the belt off to see if it does squeal. Make sure the noise isn't coming from the radiator fan(s).
Nov 17, 2009 | 1999 Dodge Durango
Engine makes a squealing noise when running. No
is it comming from the serp belt?look when the car is off to see if the belt looks brown and shiny and or cracked,,it could be the belt is loose or just old and worn and slipping on the pulleys,,may be your noise,or if you mean squealing while driving it could be the brake pads are low and the low indicator squealers are hitting the rotors to let you know the pads are low and need replacement
Oct 15, 2009 | 2001 Ford Taurus
Squealing/Screeching Noises
well hi,i think it sounds like the belt,it will do it when clothes are wet,but as they dry it don,t do as bad. or dose it get worse when it runs for a while. either way it sounds like the belt.
May 30, 2009 | Dryers
Maytag gas dryer squealing
Hi, this is a belt issue. make sure the tension on the belt/motor is sufficient. adjust to specs. if the belt is fine, this will be bad bearings in the roller assembly.
Replace the rollers in this case.
May 21, 2009 | Maytag Dryers
Just replaced belt and alternator. Engine squeals very loud when started. What should I check next? belt tension seems good.
Sounds like the new alternator was run without first fully charging the battery (12.3 - 12.8 volts)
This will destroy an alternator every time -- the classic symptom is a squealing belt.
May 05, 2009 | Infiniti G Cars & Trucks
Unexplained squealing noise.
That usually means that the belt is loose. If it is loose it will make noise on start up and go away, but while running normal, if u make the pullys work more such as A/C, or something, you'll cause it to slip again, thus making it squeal and make noise. Another idea is if you only have one belt (a serp. belt) then if the tensioner, which is not adjustable by hand, is going bad could maybe cause this noise if the belt is slipping from not enough tension. An experienced tech would be able to tell if a tensioner is bad just by pulling on a belt and seeing what tension the belt has at the time. Hope this helps, good luck
Nov 07, 2008 | 1995 Honda Passport
Kenmore Elite HE4 Electric Dryer Logo
127 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
