Question about Galaxy Radios DX-2517 CB Radio
RCI 2990DX no receive...modulation shows on rt meter left meter no response
Was installing brand new earphones and the input area arched a tad. the receive slowly started going down for 2 mins then nothing at all. Any ideas? static electricity? Need help ..thanks
    Novelist:
  • 146 Answers
Yep it would stereo plug in a mono jack!!!!?
Posted on Jun 14, 2014
3 Suggested Answers
  • 181 Answers
SOURCE: Galaxy 949 Receive problem
this sounds as the osolator has moved of freq. to check this you need to put it on a scope
Posted on May 22, 2009
kb8dns
  • 494 Answers
SOURCE: RCI-2980 NO MODULATION
Microphones are the most handled object with a CB radio and this is where it is most likely to find the problems. Basically a Galaxy radio in a base station box, and 3 out of ten develop problems, mostly power supply problems.
I would suspect the mic first. Best way is to use a different mic and see if the problem goes away. Next try the radio on an external DC supply or battery. Let me know what happens from there..... poikaa@yahoo.com
Posted on Feb 20, 2010
What fails in a magnetron
Microwaves are not supposed to be worked on unless you are trained. They have security screws for a reason. And to have it running with the cover of is so dangerous. Microwave energy can make you blind in about 15 seconds. There is thousands of volts in the capacitor which can easily stop your heart and the core of the magnetron is a poisonous heavy metal.
Put it back together and give it to a trained technician.
Mar 14, 2018 | In Microwave Ovens
2006 lincoln navigator instrument cluster not working
The thing to would be to hook up a factory or up scale scan tool to see if it will communicate . Your probably unfamiliar with control module communication on automobiles ! There is a microprocessor inside the instrument cluster ! Your best bet is to take to a qualified repair shop ,there is nothing you can do . If it needs to be replaced (which is highly likely ) info in the cluster needs to be down loaded to the scan tool ,then loaded into new one .The it needs to be programmed .
When installing a new instrument cluster, it is necessary to upload the module configuration to the diagnostic tool. Following installation of the instrument cluster, download the module configuration from the diagnostic tool into the new instrument cluster. For additional information, refer to Section 418-01 . The following items are configurable:
The Expedition and Navigator instrument clusters are configurable, hybrid electronic clusters (HEC) that contain a microprocessor, gauges, indicator lamps, and internal circuitry. The instrument cluster is non-repairable with the exception of the warning indicator bulbs and the instrument cluster lens. The instrument cluster uses hardwired circuitry, and the controller area network (CAN) to transmit and receive data from the vehicles other modules. For additional information regarding the communication networks, refer to Section 418-00 .
It is very important to understand:
  • where the input originates.
  • all the information necessary in order for a feature to operate.
  • which module(s) receive(s) the input or command message.
  • does the module which received the input control the output of the feature, or does it output a message over the communication network to another module.
  • which module controls the output of the feature.
Jul 27, 2016 | Lincoln Cars & Trucks
Transmits and receives no modulation out
I am not an expert but I think there can be little or no modulation of the carrier wave unless there is an audio input to the modulator. Like any audio amplifier a transmitter modulator (amplitude modulation) is quiescent without an input.
If the modulation amplifier and audio pre-amp are working and modulating the carrier wave and the antenna is ok then audio modulated radio frequency must be being transmitted.
It would be an extremely good quality CB that had a modulation meter. Mostly all they have is a meter giving an indication of the rf power being sent to the antenna and that rf (radio frequency) power would be the same whether modulated or unmodulated.
The modulation envelope, incidentally, is traditionally viewed or measured with an oscilloscope.
The indicated rf power could be verified using a field strength meter but the only practical way to discover if a standard CB is transmitting modulated rf is to listen to the transmission on a suitable receiver. If the squelch is turned down it will be obvious if the rf carrier wave is being received as the hiss would be silenced. If no audio is received it can be assumed none is being transmitted.
I suggest you try another microphone and lead and if that doesn't work it is clearly a job for a repair shop.
Oct 28, 2015 | Radio Communications
How do i put my pioneer receiver to my cable tv,dvd. vsx-917-v-k
For this purpose I am using headphone output of the TV set. I connect the headphone output to the AUXiliary input of the receiver. All you need is an interconnection cable, one end with 3,5 mm stereo male earphone jack, the other end with a pair of RCA jacks. This output of TV provides an additional output signal to your receiver but volume control behaviour (independent volume control for earphone output etc.) changes for different brands of TV sets.
Jan 04, 2015 | Pioneer Audio Players & Recorders
My F150 2005 truck will not show my millage/trip millage. This has been an intermittant problem in the recent past, but always came back after a short time. But now I have lost the millage indicato
Change the instrument cluster or have your's repaired .
The instrument cluster is a configurable, hybrid electronic cluster (HEC) that contains a microprocessor, gauges, indicator lamps, and internal circuitry. The instrument cluster is non-repairable with the exception of the instrument cluster lens and indicator bulbs. The instrument cluster uses hardwired circuitry, the controller area network (CAN) and the universal asynchronous receiver transmitter (UART)-based protocol (UBP) communication networks. Communication using the CAN transmits and receives data between the instrument cluster and the powertrain control module (PCM), and the anti-lock brake system (ABS) module. Communication using the UBP network uses data transmitted and received by the instrument cluster, and the electronic automatic temperature control (EATC), vehicle security module, and the driver seat module. The restraint control module (RCM) and the parking aid module communication is on the international standards organization (ISO) network. For additional information regarding the CAN, UBP and ISO communication networks, refer to Section 418-00 .
  • where the input originates from.
  • whether the module which received the input controls the output of the feature, or whether it outputs a message over the communication network to another module.
Instrument Cluster Module Configuration When installing a new instrument cluster, the instrument cluster must be configured. For additional information, refer to Section 418-01 . The instrument cluster is a configurable, hybrid electronic cluster (HEC) that contains a microprocessor, gauges, indicator lamps, and internal circuitry. The following items must be configured when installing a new instrument cluster:
  • vehicle security module
  • outside air temperature
  • outside air temperature settings (°C/°F)
  • compass
  • climate control (manual or electronic)
  • belt minder
  • speedometer
  • overspeed warning
  • your best bet , take it to a qualified repair shop. Dealer
Feb 08, 2018 | Cars & Trucks
Ranger rci 2970n2 radio need more modulation where is the audio limiter
AMC:
Mode to AM
Set generator for 30mV RMS, 1KHz sinewave.
With Mic gain at maximum VR14 Adjust for 100% modulation. Use modulation meter or oscilloscope with RF sampler.
Feb 26, 2011 | Radio Communications
I can not set my car stereo's clock
Pioneer stereos clock setting
1)turn car iginition "ON"
2)turn stereo ON and then OFF.
3)Press SRC or Joystick until blinking clock appears
4)Set clock by pressing rt,left &top,bottom keys around volume knob (joystick).
i hope this helps.
Mar 23, 2009 | Pioneer 50w x 4 CD/MP3/WMA/ receiver with...
The s-meter goes down scale when I am modulating. What causes this? THIS IS ON A RCI 2980 RADIO
the reason i saked is that if you turn the power all the way up it tends to reverse modulate. this happens because the power is using all the transmit voltage for the final and the modulation circuit is trying to use as much as it can so the radio is most likly out of alignment and needs to be realigned. its not that hard if you have the service manual and the correct equipment. i have a factory authorized shop and we do alot of realignments due to the cb shops tweaking the 10 meter radios.
Mar 12, 2009 | Ranger RCI-6900F-150 CB Radio
Analog output from digital input for Denon AVR 3803
On the Denon AVR-888 (and I presume others), you have to put the unit in "record" mode. This is covered under "Other Operations and Functions" in the manual. Here are the steps:
1. On the front of the unit, press the zone2/rec select button
2. Turn source select until "recout source" is displayed
3. Turn source select to choose the input source
Hope this helps.
Matt
Dec 20, 2008 | Denon AVR-3803 Receiver
Radio Communications Logo
81 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
