Question about Haier Dryers
Where is the reset button and how do I get to it
Dryer don't star
  • 1,162 Answers
On some appliances the reset is to cut off your breaker an then turn it back on. Loss of power will reset unit. Repairman told me to try it before he came out. It worked.
Posted on Mar 29, 2014
I don't not how I star my new dryer can you please help me
If you just bought it new, instructions should guide you. sometimes attached to the back or inside.
Usually, by the look at the video, open the door and then close firmly, select the time or dryness on the round knob, then twist the knob in the center to start or clockwise.
If all else fails, there should be a phone number next to the manufactures name plate when the door is open
Apr 16, 2013 | Dryers
What is recommended load size for Bosch Nexxt dryer
The Bosch Company is probably known best for its high-end dishwashers, but the company also produces other home appliances including refrigerators, stoves, washers and dryers. Bosch dryers carry the Energy Star rating. A Bosch dryer has a structured drum that provides more thorough drying and condensation drying for faster cycle completion. If mechanical problems occur with the dryer and troubleshooting efforts fail, performing a reset may return the dryer to normal functioning.
Instructions
1Unplug the Bosch dryer from the power supply and then reconnect to the power supply.
2Replace the local fuse or reset the circuit breaker if a fuse or circuit breaker has tripped.
3Place items to be dried into the dryer and select a program. Close the door firmly.
4Press "Start/Pause."
5Press "Stop/Cancel" if the above steps do not resolve the problem.
6Pull the dryer out from the wall and use a standard screwdriver to remove the central metal plate on the back of the dryer.
7Locate the small red reset button above the heating element and press and hold the button for a few seconds. Release the button.
8Place the back access panel back on the driver and move the dryer back against the wall. Repeat steps 3 and 4. If the problem continues, press "Stop/Cancel," turn off power to the dryer and contact an authorized service technician for assistance.
Jan 09, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
Roper dryer wont start, do it have a reset button
Check the door switch. With the door open, press the button in and the light should go off. If you don't have a light, listen for a click form the switch as you push and release it. If you don't hear a click, you will need to replace the switch. If the switch is good, then problem will be with the thermal fuse located on the rear of the unit.
Sep 28, 2012 | Dryers
Nokia e61i contacts recovery
Here's how to reset a Nokia E61i to it's factory settingsTurn off the phoneHold these three buttons simultaneouslyCall Button (the green one)The letter "Y" (the number 3)The letter U (the star key)Turn on phone (don't let go of the three buttons!)Only release the buttons when the phone is really on (when you see a bright Nokia logo).
That's it. Weird, but true. Don't know if you can do it through the menus, which should be easier...
Jun 21, 2012 | Nokia E61i Cellular Phone
(2007) Frigidaire Affinity Gas Dryer won't shut off
mybe the star button stay stuck and the dryer tinks some one is puching the star button and it will continio to run. try to open the door and it will stop and then clouse the door if the dryer star whitout pushing the star then you now the star switch is stuck. goo lock
Feb 21, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Where is the the reset button on roper dyer
There is no reset button on any dryer. Your Roper is a Whirlpool with a different nametag. Depending on how old it is there may be 1 or 2 non resetable fuses. They are in the back behind the rear cover. They blow when there is another problem. Such as a clogged exhaust or a bad cycling thermostat. Don't do any work on it without double checking that the machine is unplugged
Nov 20, 2011 | Roper REX3614KW Electric Dryer
I dont know my lock code sir please tell me sir imei no 353777005895079
1 - Switch on your Nokia 6600 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6600.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6600 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6600 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6600
Nov 15, 2011 | Nokia 6600
My master code wont work on my e63 please someone help
call the service provider and Unlock it using they provided Master reset code,ask code from them.
-monchi
Oct 17, 2011 | Nokia E63 Cell Phone
I have a nokia n96 and whenever i plug it to the charger with the wall it says warning bad contact charger ?wat shud i do?
try a hard reset after backing it up .press and hold green, 3 and star then switch it on do not let go of any button till you are asked for your region
Feb 13, 2010 | Maytag HYG3658AW Gas Dryer
Kenmore 80 serirs dryer wont start..
hi..check your circuit breaker,may be the power cord
is tripping it.If this is not the problem,check and see if
there is a reset button on the outlet where you plug in
the dryer.
try this out..
thank u..
kindly rate my response..
May 15, 2009 | Kenmore 44832 Front Load Washer
Dryers Logo
152 people viewed this question
Top Haier Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Haier Dryer Expert? Answer questions, earn points and help others
