Question about Frigidaire FEB30S5D Electric Single Oven
My friigedare oven is not working we checked the elemaents thay are ok
Looks like electronic problem please help
  • Official Brand Answer
  • 2,267 Answers
Hello Izhar, this is Z. I am happy to assist you!
I see that your question is listed under Frigidaire wall-oven (FEB30S5D). If both the broil and bake elements are not heating, I suggest resetting your wall-oven. This can be done by either unplugging it or flipping the household circuit breaker to the off position. I recommend waiting approximately ten minutes and then turn on your appliance. If this problem persists, then your wall-oven could possibly be experiencing a potential wring failure, or a communication problem with the EOC (Electronic Oven Control). It would be advisable to contact an experienced appliance repair tech to assist further.
Posted on Apr 03, 2014
Oven is not working its 5 years frigdare electronic elements are ok
Try setting clock before presuming board is faulty, ovens shouldn't work if clock is flashing or timer is counting down or bell symbol flashing. Consult your instructions
warmest regards
Richard The Repairman
Mar 29, 2014 | Frigidaire FEB30S5D Electric Single Oven
Rbd305pdb14,have error ( F5-E1) replaced controlled board, replaced touchpad, replaced sister board, replaced thermal fuse lower oven, replaced lower oven heat sensor, top oven works ok, lower oven still...
that's a bad door latch,if you use the self clean don't use it anymore,the oven gets up to 1000 degrees and damages the electronics in the oven,takes out the clock assy. the door latch things like that.part number WPW10195934 go here to see parts go here put model number in and look up parts,also you can check all the error codes down in bottom right hand side
https://www.searspartsdirect.com/model-number/RBD305PDB14/1198/0125300.html?searchType=modelSearch&q=Rbd305pdb14&searchTerm=Rbd305pdb14
go to upper oven and look at part number 22,you should have googled the error code before you changed out all those parts.
Feb 06, 2018 | GE JTP48SFSS Electric Double Oven
Upper oven will not heat up in any mode. "Pre Heat" and "On" come on for a few seconds, then go off. I checked the elements, all between 15 and 30 ohms. Every now and them it will...
Hi n664v,
This sounds to me like a Thermostat problem. If it is an electronic version Oven, then it will be the Sensor or PC Board Module controlling temperature. Please let me know what Make and Model your Oven is, so I can better assist you.
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Aug 17, 2011 | Ovens
Hob is tripping fuse box
If the hob is tripping the RCB or MCB on the consumer unit, there is a fault, usually in the elements or halogon heaters, you will need a multimeter to define but please ISOLATE FROM MAINS POWER BEFORE OPENING ANY PANEL
Some electrical knowledge would be helpful, check each element seperatly, you may have to carefuly disconect each heater on the hob, unless you know which blows the mcb, check all connectings to see thay are secure, work round the hab reostates, make sure there is no shorts to ground from elements, with temp control down at zero. Check wiring into mains as a loose connection will cause heat and mcb to trip.
If it is wired into the same outlet as an oven disconnect oven in case the other appliance is causing the problem. it is realy a question of eliminating causes one at a time, working round the affending appliance to define what is the cause.
Hope this is helpful
John
Jun 06, 2011 | Ovens
The top oven stopped working 1 year ago, electricity was there, oven lamp goes on, but won't get warm, so used lower over and now it quit and for the same reason
the elements have broken down you need to replace them go to part4us and put in your oven name and model number and thay will find them for you thay also do a video on how to change them your self
Oct 27, 2010 | GE Profile JKP56 Electric Double Oven
Error f7 oven wont turn off
Hello there:
The f-7 error code carries several different possiabities
here are several possiable reasons and the things to check
1. F5 or F6 or F7 EOC (Electronic Oven Control) failure Replace EOC(Electronic Oven Control)
2.
F7 Shorted touch panel Replace glass panel
3.
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace clock assembly (also called the ERC)
Please test each of these carefully ok and if you disconnect the board you may want toclean the contacts really good and then try to reconnect the wires and make sure that they are properly connected ok
Best regards Michael
Jan 12, 2010 | Ovens
Our relay board on ourdouble wall oven was replaced last Feb...now it needs to be replaced again.This is very expensive and we do not understand
please check you warrenty online with thermadore
i believe thay have a 10 year electgronics
some models only have a five year......
also check with your service company...
sometimes they will cover a elecrronic part for a year themselves
Oct 22, 2009 | Thermador SMW272 Electric Double Oven
Oven wont work but clock still works
First make sure you didn't trip a breaker. You could have power for the electronics on one side of the 220V and that is why the clock still works. Turn off the breaker and then back on even if it looks on. If it does this again you have a sever problem that will require a service call. If the breaker is tripping it could be other than the oven and if so a new one will work ok unless itsin your wiring.
If this helps you please ratre me accordingly Good luck.
Mar 12, 2009 | Belling XOU252 Electric Single Oven
Kenmore oven
Is this an electronic control oven...touch pads to set temp? May have a bad ERC. Electronic Range Control. Also check oven sensor. This is steel rod in oven in back wall near top on left or right. Check ohms from the rear where it connects to harness. Disconnect at harness and measure resistance of sensor. Most are around 1.1k.
Oct 07, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidaire FEB30S5D Electric Single Oven Logo
76 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
