Question about Apple Mac OS X 10.4
I have an HD that Disk Utility can't repair. I was hoping to see if you could talk me through, or you access my computer on-line to possibly fix the disc before I reformat it.
  • Apple Master
  • 4,806 Answers
We cant connect to your computer while its not in the operating system.
If you need to check the drive for bad sectors and recover them download Hirens Boot CD >>>>>>>
http://www.9down.com/Hiren-s-BootCD-9-5-23765/
This boot CD comes down in an image and can burn directly to CD, use this CD to benchmark, test and repair your computer, remember you need to get the Mac to boot from CD first to use the hard drive tools section on the CD.
Good luck
Posted on Jun 15, 2009
    Problem Solver:
  • 6 Answers
You can use tune up software
Posted on Jul 15, 2009
I have a question mark sign on my screen please help
sounds like your hard drive has come unplugged, you will have to remove the battery and possibly the "L" shaped metal strip then you can push the hard drive back in
Feb 14, 2015 | Apple MacBook Pro Laptop Computer with...
Tip
Mac Repair Disk
Mac OS Repair
To run Disk Utility on apple macbook OS X 10.4.x, you must start the computer using an Apple Software Restore disc.
Insert the disc into the computer, restart.
After you hear the startup sound, press and hold the "C" key. Hold the key until you see the gray Apple logo.
Your computer will take longer to startup, be patient, this is completely normal. After the CD or DVD is loaded it will automatically start the OS installer, do not reinstall your OS system!
If you are requested to choose a language, just click the right arrow button (Next).
To open the Disk Utility Click on Utilities > Disk Utility.
Now the Disk Utility window should be open. Choose from the left side of the window the hard drive you wish to repair (in this case Macintosh HD).
Make sure that the First Aid tab is selected.
Click Repair Disk button (bottom right).
The tool will check your hard drive, if it encounters any problems it will list them in the middle of the window, otherwise you'll receive this message - "The volume Macintosh HD appears to be OK".
Once the scan is over if it found problems, click again on Repair Disk, this will try to repair the problems, if not successful you need a more advanced utility tool.
on Aug 17, 2008 | Apple Mac OS X 10.4
What does flashing globe on white screen on mac meanmacbook pro
If by flashing globe you mean spinning globe (often a colored beach ball), there are several possible reasons. The spinning beach ball happens when a operating system command cannot be completed. The computer is frozen/stuck in a process that it can't complete.
Most often the cause is faulty or missing information on the hard drive. Running Disk Utility will often fix it. You may need to start the computer from your OS install disk and rather than install find Disk Utility in the pull down menu and run it on your hard drive.
The spinning ball could also be caused by insufficient RAM memory to even run the operating system. It could also be caused by hardware problems which can be diagnosed with the Apple Hardware Test found on the disks sold with the machine.
If you truly mean a flashing round globe, I have never seen such a figure. Flashing question marks or flashing circle with a slash through it means the mac cannot find a bootable hard drive. Your hard drive may have died or become corrupted. To see if you hard drive is defective, again run Disk Utility by booting off an install CD or another hard drive with a compatible MacOSX operating system to diagnose.
Try running the repair disk program under the general tab of the Disk Utility program.
Aug 11, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Fix ya com
When you say you've used Disk Utility, have you done both Repair Permissions, and Repair Disk? For Repair Disk you need t boot from a different drive, the original install DVD if you have it?
Another thing to try is, remove and and then replace the RAM chips, sometimes the connections need to be re-seated.
Thanks,
John
Apr 13, 2014 | Apple iMac Computers & Internet
Samsung mmcre28g5mxp error
You could run the chkdsk disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive
or an easier way i have found to run the chkdsk utility
click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers operating system and hard drive
hope this helps
Nov 01, 2012 | Samsung Computers & Internet
Blinking folder with a question mark
This is often a sign of directory damage and sometimes disk damage.
You need to start up the mac from one of the supplied DVDs.Stick it into the slot and then try a restart. there will be a pause while the blicking goes on, but then after 20-30 seconds the mac should start up from the DVD.
You will get presented with a choice of languages. Choose english and then hit continue.
Now at the next page go up to the menu bar and choose UTILITIES.
From there choose DISK UTILITY.
Wait while it loads up and then look at what is presented in the window.On the left hand side you should see Toshiba, Fujitsu or Seagate or somethings similar, and underneath that it should say Macintosh HDBelow that it should show the DVD drive and the belkow that the DVD that is in the drive.
If you only get the DVD pair then your HD probably needs replacing.
If you see the 2 HD references, click on the Macintosh HD and then at the right hand side of the window, select REPAIR DISK.
If the disk can be repaired, the utility will fix it, if it can't, then it will tell you, and something more powerful is needed - it could still be a disk failure in the making.
It the fix works, quit the utility and quit the installation program and restart holding down the ALT key while you do it. You should get presented with your HD icon and then after a short while the DVD icon. Select the HD, press continue and one the sgtart-up has completed, eject the disk.
If you only get the DVD, then it's workshop time.
Post back if it works.
Jan 05, 2012 | Apple MacBook Laptop Computer Mac...
Computer is recognizing the HD. But when I try to access it it tells me that it needs to be formated before I can enter it. Whe I hit properties, it tells me that it is completely full. Last time I used...
you could run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive there are many ways of running the chkdsk utility
click start righy click on my computer you should see your drive select properties click tools check now tick both boxes automatically fix files and scan for and attempt repair on any bad sectors or you could tick one box and wait until its finished then return and tick the other box
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
(it will only schedule on restart if there is an operating system on the drive)
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
hope this helps
Jul 03, 2011 | Buffalo Technology (HD-HB250U2) 250 GB...
I have no problem turning on my laptop but it gets stuck in the loading screen. The wheel under the Mac Book symbol is turning and everything seems to be running just fine but the system itself is stuck...
Hi This could be one of three things. 1. a corrupted file on your HD, or 2. the directory on the HD is corrupted, or 3 a failing HD
Try starting up from your installation DVD and then running disk utility. (Insert your DVD then shut down the Mac. Restart the Mac and hold down the C key until you see the Apple logo. Once you reach the screen that asks which language you want to use, select English and then from the menu bar chose disk utility and repair HD)
If you get a message to the effect that disk Utility cannot repair the disk, run it one more time. If you still get the message then you had better locate a service centre.
Sometimes letting the installation run its course and overwriting the existing system will fix it. In this instance, you select the archive and install option, otherwise you will erase your files as the HD will be wiped.
I hope you have your files backed up.
May 02, 2011 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
I've been getting pop-up windows that say I am prevented from opening or changing documents/files due to lack of authorization or permission. I am the owner of and only person using this computer. How can...
I am not sure if the documents or files that you are opening or changing are from attachments sent to you via email or not, but I can suggest that you can try this step:
Right click on one of the affected files and select Get Info.
This will open a long narrow box providing detailed information of the document.
Now look at the bottom of the window under Sharing & Permissions
Click the padlock and enter your User Admin password when the pop up window appears.
This will allow you access to changing the current permissions of this document.
Make sure you see permissions for "Read and Write" attached to your user name.
If you do, then go ahead and close this window. However, if you see only Read permissions attached to your user, then change that to Read and Write.
Once you have done this, close this Get Info window.
Try to launch that affect document to see if it opens now. If it does then this may be a permissions issue that is affecting your documents and files.
Whether you can or not, I would still recommend you still run this procedure below in order to try and fix this permissions issue.
Now run Disk Utility to repair all permissions on your Mac OS X volume.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} -RUN DISK UTILITY-
Go to Finder Menu bar
• Click Go > Utilities > Disk Utility and open up Disk Utility app.
• Click on Macintosh HD volume (or on the name you have changed this volume to.)
• Select "Repair Disk Permissions"
**Let Disk Utilities run this repair permissions until completion
Once Disk Utility is complete and there are no errors in red in the completion summary (if there are errors listed in red, re-run Disk Utility to see if those error will clear- if they don't reply back to this post right away and let me know what the exact error message is), quit Disk Utility.
• Now attempt once again to access the affected documents and files and see if you are able to access these items now.
I hope this helps.
Regards,
-Mactechtrainer
Feb 06, 2010 | Apple MacBook Pro with 17" Display
Hd hard error
  • HI
  • TO TEST THE HARD DRIVE ON THE COMPUTER
  • Run the Windows Check Disk utility. This utility will check and repair system file errors (logical structure), and examine the physical structure (the integrity of the disk surface) as well. Close all applications, browsers, and utilities.Open My ComputerRight-click your hard drive (C:)Click Properties, then click Tools TabUnder Error-Checking, click Check NowClick check box for "Automatically fix file system errors"Click check box for "Scan for and attempt recovery of bad sectors"Click Start to run the utility
  • Download and run the freeware diagnostic tool "HD Tune". This terrific tool will run a complete benchmark analysis of your hard drive, check for structural errors, examine overall health issues item by item, and more.
  • Download and run the freeware diagnostic scanning tool "Emsa DiskCheck". This tool is a dual purpose utility for disk checking (pre-scan and full disk reading) and benchmarking.
  • THANK YOU
  • Sep 13, 2009 | Dell Latitude D600 Notebook
    Apple Mac OS X 10.4 Logo
    116 people viewed this question
    Top Apple Computers & Internet Experts
    marty morrison
    marty morrison
    Paul Carew
    Martin Buck
    Martin Buck
    Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
