Question about Uniden Guardian Wireless Video Surveillance System
Uniden G766 Display unit doesn't connect to power . Cables, adapter, outlet , everything check , power is in outlet and other elektronics work but this display unit. Where is problem?
5 Suggested Answers
SOURCE: Display suddendly went "off " on Uniden TRU9488 base unit
unplug main base for a minute then put each phone back in main base
Posted on Jan 18, 2009
damneddle
  • 1607 Answers
SOURCE: following a power outage, cordless
Hello
Try re-registering the hand held to the base.
Posted on Sep 01, 2011
  • 3287 Answers
SOURCE: what adapter do i need to connect a uniden bearcat pc78 elite inside my home
Hi Ray,
This is a mobile CB radio. According to the manual, it requires 13.8VDC @ 2.2Amps. You will need to provide an AC (house or alternating current) to DC (direct current) power supply capable of providing 13.8V at 2.2 Amps. This means the supply would be working at 100%, so obtaining a supply that would provide 4, 5 or more amps would be much less stressful on it and significantly reduces the chances of a 60 cycle hum present in the receive and transmit audio.
A representation of 13.8VDC @ 4A power supplies can be found here for $40 and up. Of course, you can go to a local electronics store and find them too. Check eBay for these, too - here.
You should be looking for a power supply that will provide 12 - 13.8 volts DC, and provide 3, 4 or more amps. The amp capacity is what will change the price - the more amps the higher the cost. You may see small "switching" power supplies - they are smaller, lighter & cheaper than traditional linear or transformer based types - so if that is the type you want to get you might want to get one that is a little bigger (5 or 6 amps) than the transformer type to get the same performance.
I hope this helps & good luck!
Posted on May 08, 2012
  • 36311 Answers
SOURCE: uniden bearcat scanner 800 xlt comes on but screen will not display
This may require return to Uniden for replacement of the screen
Posted on Oct 29, 2012
The display screen is showing the word "SEARCHING" on the screen, can't get the phone to work, cannot pick up an incoming call, the display also displays "HANDSET OUT OF RANGE" WHEN ANY BUTTON IS...
From the Uniden support site.
You can first try a Basic Reset.
A reset is done by following the below steps:
1. Disconnect the battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect battery into handset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base
reference
Mar 13, 2015 | Uniden DECT 6.0 Cordless Phone ID
Inspiron 2305 power cord doesn't turn the desktop on
After connecting the AC adapter to a wall outlet and to the computer press the power button the right side of the inspiron. The button itself should then lite up white if the power adapter is good. If not, check the power outlet you are using. Plug in something else and see if it works on this wall outlet. Some outlets are connected to a wall switch. If its still a nogo you may need to replace the AC adapter.
Sep 18, 2011 | Dell Inspiron One 2305 Desktop Computer...
My sp will not charge, I am not sure if it is the battery or something else
Game Boy Advance SP - Charging Light Won't Display If the orange-colored charge light on your Game Boy Advance SP is no longer coming on when the A/C Adapter is connected to your system, please use the following troubleshooting steps.
    Troubleshooting Steps:
    1. Make Sure the Game Boy Advance SP Isn't Already Fully Charged
      If the battery is already fully charged, the light will not display when the system is plugged into the AC Adapter. Play a game without using the AC Adapter for at least 10-15 minutes, then plug the AC Adapter in, to see if the light comes on. If it does come on, the battery was fully charged. If the light still does not come on, see Step 2.
    2. Make Sure the Outlet You Are Using Works
      Plugging another electrical device into the outlet is a good way to check if the outlet works, or that the outlet you are using is not controlled by a nearby light switch. You may also want to try a different outlet.
    3. Try a Different Licensed AC Adapter
      If the charging light doesn't display, try a different AC Adapter, if possible, to determine if perhaps the problem is with the adapter.
      • If a different AC Adapter works, you will need to get a replacement AC Adapter from our Online Store, or by calling our Consumer Service Department at 1-800-255-3700.
      • If a different AC Adapter doesn't work, or if a replacement AC Adapter is not available and the lights will not display, we recommend having your Game Boy Advance SP repaired. Check out our convenient repair options.
    Note: Please be sure to include both the Game Boy Advance SP and the AC Adapter with any repair
Sep 02, 2011 | Nintendo Game Boy Advance SP Console
We have a five (5) phone on one line with Uniden. We have checked all the outlets and everything seems in order. We can not get a line on the system. Help
The following tips come fromUniden.com website, hope this helps you. Question: What are things that I can check or do to get myphone working properly?
Answer:
1.Make sure phone is not sharing an ac outlet with any other types of electronicequipment. 2. Make sure base ac adapter is not sharing a multi outlet plug. 3. Make sure phone cord is not plugged into a splitter, fax, computer or remoteanswering machine. 4. Check to see if the phone cord is plugged in properly. 5. Check to see if the AC Adapter has been properly plugged in, the outlet is onand working. 6. Make sure phone jack is working. 7. Phone cord needs to be plugged directly into phone jack to insure optimalperformance. 8. Make sure you are using the original ac adapter that came with the unit. (Itshould say Uniden on it) 9. Make sure proper battery is being used .(It should be the one that camewith the unit, or a new Uniden battery) 10. Make sure battery is installed and plugged in all the way.( It shouldclick in) 11. Move phone to a different location in the home. (Different phone jack) 12. Disconnect AC Adapter and reconnect it After 25 seconds. 13. Reset the Digital Security Code if applicable - instructions can be found inowner's manual if applicable 14. If nothing else has worked. You can see if a basic reset will work on thephone. A reset is done by following the below steps:
a. Disconnect Battery from handset(s)
b. Disconnect Phone Cord from wall jack
c. Disconnect Phone cord from base unit
d. Disconnect AC adapter from wall outlet
e. Allow to sit for 30 min
f. Reconnect Phone Cord to base
g. Reconnect Phone cord to wall jack
h. Reconnect AC Adapter to wall outlet
i. Reconnect Battery to handset until you click or feel the plug snap intoplace
j. Re-Register Handset by placing on main base (Resetting security code -manually) 15. Check to see if you are on tone dialing or pulse dialing. 16. If you are still experiencing problems please call USAcustomer service at 1-800-297-1023, please tell them that a basic systemreset has already been completed and what the issues are still.
If you are in Australiaplease call: 1300 366 895 for all Service queries including producttroubleshooting.
Contact details for Uniden in other countries can be found at:
http://www.uniden.com/about/locations.cfm
Mar 14, 2011 | Uniden Cell Phones
I have 2 Epson V500 Scanners, 1 of them I just have on standby. The one I use daily does not turn on. I tried using the cables of the standby unit already. I checked the fuses on the plugs of both...
  1. Check that the power socket switch is on Make sure your scanner's power cord is securely connected to the scanner and a working electrical outlet.
  2. If your scanner is supplied with a power adapter, make sure your scanner's AC adapter is securely connected to the scanner and a working electrical outlet.
  3. Make sure that the power outlet works. (If necessary, test it by plugging in another electrical device and turning it on.)
  4. Check that the power switch is on at the mains socket. If this is on, carefully check the power cable to ensure it is not damaged and remove then reseat it before attempting to turn the scanner on again. If your scanner has a power button, make sure that the button is depressed so it is turned on. Also, make sure that your outlet works and is not controlled by a wall switch or timer.
  5. Power off the scanner at the mains socket. Unplug the power cable from the socket, then remove and reseat the power cable from the scanner's power cable port. Plug the scanner back in at the mains and ensure the socket is switched on.
  6. If your scanner has a power button, does the power button depress when pressed? Press down firmly on the power button, if it is stiff and does not depress then there may be a problem with the button.
  7. Connect the scanner directly to the mains - not via a surge protector or extension lead. If your unit is connected via a surge protector or a power strip/extension lead, connect the unit directly to the mains socket.
  8. Try another suitable power cable. Check that other electronic devices connected to same power socket have power and try another mains socket and another power cable if necessary. Failing this try another suitable and known-working power cable. Depending on your scanner, a standard "kettle lead" or "figure of eight" power cable is used. If there is power to the scanner (indicated by an illuminated Start light), when a different power cable is used, then the fault is with the original power cable.
If the unit does not power on after following the checks above, contact Epson for support. If your scanner uses an AC adapter, then this may need to be replaced. If your scanner is over 12 months old, you can purchase a replacement AC adapter directly from Epson.
Nov 13, 2010 | Epson Perfection V500 Flatbed Scanner
Wii console isnt working
Have you tired resetting the AC adapter? If not, then try this:
  1. Unplug/remove all accessories from the system (including game discs, SD Cards, memory cards, Nintendo GameCube controllers, hookup cables, the AC Adapter, and Sensor Bar) from the outlet and Wii.
  2. Let the system rest for about 90 seconds. While you're waiting, check to see that controller cords, AC Adapter, and Stereo AV cables/Component Video cables are not frayed or have exposed wires (this can cause the system to shut off); if so, you should replace those parts.
  3. After the 90 seconds, Plug the AC Adapter into the system and directly into a wall outlet, not a surge protector or power strip. Check to see if the power light on the Power button comes on.
Jul 02, 2009 | Nintendo Wii Console
Uniden base display does not work after chargin for 1st time.
Reset Procedure for Cordless Phones
Question:
What is the general reset procedure for cordless phones?
Answer:
1. Disconnect Battery from handset(s)
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances
May 05, 2009 | Uniden DECT 6.0 Cordless Phone ID
After charging a Uniden 2180-2 DECT 6.0, the base stope showing anything on its display. As for the other handset, their display report " searching" since they can' t connect to the base. What is goin
Question:
Answer:
May 05, 2009 | Lands Phones
Uniden Power Max 5.8 - (TRU8880-2)
10. Re-Register Handset by placing on main base in most instances.
please rate this post
Aug 04, 2008 | Uniden 5.8GHz Dual Cordless Phone
Uniden Guardian Wireless Video Surveillance System Logo
49 people viewed this question
Top Uniden Home Security Experts
D. E. Hev
Coss
Lawrence Oravetz
Are you an Uniden Home Security Expert? Answer questions, earn points and help others
