Cannot get to you tube is it blocked
Why want it log in now
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 197 Answers
Change your preferred dns server ip to 8.8.8.8.on your ipv4 ip adress settings
Posted on Mar 29, 2014
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
Explorer Dipstick Tube Broke
There is a bracket that holds the tube to the block. There is no clips or retainers that hold it in the block. With the bracket loose you can twist and remove from the block. There is a oil ring on the end of the tube.
Sometimes the old tube is hard to remove...due to rust and corrosion. Spray the tube with a good penetrating oil before you start. Try to wiggle and twist the tube to brake it free....be careful, the tube is thin. If the tube breaks off flush with the block..the piece that in the block will need to get extracted out or remove the oil pan and remove it that way.
Nov 25, 2012 | 2006 Ford Explorer
I cant access my youtube on my laptop how can i fix it?? please help me. i thought my youtube is block on my laptop. please help me
If this is not the only website that you find is blocked and especially if you are being redirected to different sites when you try to log in to You Tube, you can try downloading and running eset scanner (for free) at go<dot>eset<dot>com.
In the meantime, if you want to make sure you arrive at your chosen site, click on the History tab and reclick on the site that you would like to go to. This should get you to the right place.
OR, if you have parents, ask them to change the permissions for what sites you can visit (?).
Aug 31, 2011 | Computers & Internet
My car is idoling at a very low rpm and sometimes cutting off when the car is at a stop light......... how do i make it idol at a higher rpm
ford focus are well known for the pcv tube going to intake manifold get soft and collaspe and well soon crack and log a check engine lite for bank one lean, due to vacuum leak, pcv valve is driver side front corner of the engine block just below the head.
Aug 07, 2011 | 2003 Ford Focus
Pilot flame curves upward missing thermcoupler copreci style 1 in gas logs by Desa Int, can I fix?
pilot is blocked needs cleaning orfice is blocked try blowing pilot with can of air , when off , or tube and just blow .
Jan 06, 2011 | Desa International CCL3924PTA 24" LP Gas...
How do you remove broken oil dipstick from a 1999 ford escort?
The dip stick tube is pressed into the engine block. Put a bolt into the top of the tube so that the body of the bolt goes into the tube and the bolt head rests on the tube (so it does not fall down the tube). Use a wrench (such as a Vise grip) to hold onto the tube at the bolt and gently work it back and forth, being sure not to deform the tube. Remove the tube and old dip stick. Replace the tube by forcing it back into the eng. block. Replace the dip stick - done :)! Some dip stick tubes have a gasket at the engine - others just **** up to a shoulder that is built into the tube. Let me know if this works. Thanks.
Dec 19, 2010 | 1999 Ford Escort
How to block website using this model cuz i enter the site in a firewall no effect
I don't know what brand this is but typically you have to log into the router to set up website blocking. If you have access to the web go to the manufacturers web site and look up the default log-in. Most routers use a default log-in may be "admin" but i do not know the password.
Once you do have the login information you will need to log into the router and add blocked site info.
Oct 24, 2009 | Linksys WRH54G Wireless Router
I CAN'T LOG ON TO YOU TUBE
Hai Dud,
You can log in my Friend.Its not necessary to register a new account,if you have an gmail ID you can sign in as it.In the page it asks for Sign in using Gmail account so ur account hac been created....Tada! If you want an fresh account in You Tube,Register it first....It reports error has username exit!-if you are unlucky...if so just keep on trying never give up...Trust me you will have an Fresh account!
Hope it Helped You,If so give an "High Five!" [;)]
Aug 03, 2009 | YouTube Computers & Internet
Youtube block me out
you may log in to you tube select sign in.enter your pass word and username.hope it is help full
Mar 21, 2009 | YouTube Videos
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
