Question about Metrik Car Audio & Video
No video on screen
Everything is plug in and running good, dvd player plays the dvd but no sound or video on the screen
techman
  • 3130 Answers
SOURCE: Sony shows a split screen when DVD plays
If the new player you hooked up is causing the spit screen then you have to go into the set up menu in the DVD player and take it out of prograssive scan.. Its in the wrong fornmat for your TV set. good Luck PS please dont forget to rate this.
Posted on Oct 16, 2006
SOURCE: LG V8824w DVD/VCR no video
rtfm.
Once the setting for progressive scan output is entered,
an image will only be visible on a progressive scan
compatible TV or monitor. If you set Progressive Scan
to On in error, you must reset the unit.
1) Remove any disc from the unit and close the disc
tray. See that "NO DISC" is displayed on the display
window.
2) Press STOP and hold it for five seconds before
releasing it. The video output will be restored to the
standard setting and a picture will once again be visi-
ble on a conventional analog TV or monitor.
Posted on Feb 02, 2008
  • 15 Answers
SOURCE: DVD plays but nothing is displayed on screen.
1.make sure that the video input/output are plugged in.
2.make sure ur tv is programmed to vieo 1 2 3 etc.
Posted on May 07, 2008
SOURCE: My Toshiba SD-3960 sound does not work.
My Toshiba DVD Player does not work. I can not watch online movies. What I ca do? Please send me if you have any suggestion.
Thank you.
Posted on Aug 30, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Sony CD/DVD Player DVP-NS50P not playing my avi files DVD+RW
You need to convert avi files to dvd format before burning, otherwise the player won't recognize them. Google "avi to dvd" and you'll find a number of free or pay programs that will do the conversion for you.
Posted on Nov 19, 2008
Hi.. I bought a used vehicle(2010 Ford F 150) which has a farenheit dvd-36 system I tried to play the dvd and the monitor, wire, remote....everything is working good. but, the only problem is that the
OK....Pull the dvd player out. Look to see if it has speaker wires coming off the back. If not, does it have rca plugs???? (red and white). if so then you are gonna need an amplifier to get sound. If it DOES hve speaker wires, chec to see if they are hooked up to the speakers in the vehicle.
Mar 13, 2012 | Farenheit DVD-36 Car DVD Player
My jensen dvd player mvb85
It still plays but no sound... probably the line going to the screen, but check the settings and try a CD that worked before....
Keep me posted...
Feb 06, 2008 | Jensen 8.5" Overhead DVD Player Package...
No Sound when playing a video game on Coby Pertable DVD player
Do you have the audio plugs in the proper spot? The red & white audio plugs from the PS 2 need to be plugged into the audio in jacks on the portable dvd player in order to get sound. Should match up red to red; white to white for sound, yellow to yellow for video. Hope this helps.
Feb 03, 2009 | Coby TF-DVD1023 Player
Car DVD player will only play sound through wireless headphones, not through speakers
We have a GMC Envoy which also does not allow us to play the sound from the dvd player through the car's speakers. Although we purchased the vehicle new with the dvd player already installed, it was installed by the dealer, making it after-market. I assume those that were installed in the factory work differently. Maybe this is the case with your's as well. Good luck!!
Aug 01, 2008 | Nesa Vision Car Audio & Video
May 07, 2008 | Delphi MV10015 Car DVD Player
Cannot play VHS
Combo DVD/VCR players don't output the VHS with Component Video. Most of the time, it won't output over the S-Video either. The high end outputs are ONLY for DVD output. You must run a yellow wire, or use coax cable to get the video. Same goes for the optical digital sound out. It's only for DVD use.
Feb 28, 2008 | Samsung DVD-V6700 DVD Player/VCR
Goodmans Tv wont show dvds
Usually with DVD players, picture & no sound, or sound & no picture is caused by the scart lead not being plugged in properly.
Sound pins are at one end of the connector and audio pins at the other.
If you are using scart make sure that the plugs at both ends are pushed in all the way. The plastic part of the plug should just touch the socket.
If you are using S-Video (Round connector with 4 pins) you also need to connect a twin phono-phono (Red & Black or White) lead to carry the audio, as S-Video only carries video.
Feb 09, 2008 | Goodmans 1475TS 14" TV
My Panasonic dvd/video player says that the dvds are scratched even when they are new.
for sound may be you are using above 96khz frequency which your reciever is unable to adjust and always try to play original dvds in players if you want your player's life long.
Nov 20, 2007 | Panasonic DVD-S52 DVD Player
Screen won't play movie
sound like the wire to the parking brake may not be getting a ground.if it not get a ground it will no show a picture on the screen. it so you cant watch the dvd while driving.
Feb 11, 2007 | Concept DVD-168C Car Video Player
No picture
How is the player plugged into the TV set? Are you using the S-video or RCA type plugs? Have you tryed a differant input on a differant TV? It could also be your cables. If you tryed differant cables and a differant input then your problem is a broken connection on the video jack or in the video output processor IC inside the unit and thats not a user fixable problem, Sorry. Good luck
Jul 23, 2006 | Sanyo DWM400 DVD Player
Car Audio & Video Logo
29 people viewed this question
Top Metrik Car Audio & Video Experts
xxxxxx xxx
Are you a Metrik Car Audio and Video Expert? Answer questions, earn points and help others
