Question about B-Air Grizzly Dryer 1 HP Green
The motor is shaking
When it's turned on it started to shake and thump
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 123 Answers
That not the motor it is the guide wheels at the sides of the drum that need replacing
Posted on Jun 01, 2014
Why am i hearing a thump sound when i take off or turn my wheels left? I got new. Rack and pinion&mount bushings,lower&upper control arms sway bar link bushings,ball joints,cv axles. I have a 95 acura
The only thing that comes to mind is the wheel bearings. I noticed them missing from your list, and they will cause thumping and banging, especially when turning a corner or a highway on or off ramp. You also mentioned "while taking off and turning", but not when braking, another sign. The brake pads hold the wheel while braking, hiding the shake. The easiest ( and free ) way to test this is, jack up one wheel at a time, make sure the tire has completely left the ground. Grab the wheel with both hands and shake it around. Normally there will be some play, but not much. If it noticeably shakes and / or makes a thumping sound, you might have a problem. I also give one side a kick as well, just to be sure. If all is well, repeat with the next tire. Unfortunately you have to do this to each wheel separately to be sure, but at least you'll know, and not have to pay a mechanic to find out. Hope that helps you, Grim
Aug 18, 2015 | Acura Cars & Trucks
WILL THE TRANSAXLE MAKE LEFT WHEEL SHAKE AND MAKE THUMPING NOSIE 2001 LESABRE
Have you checked the CVJ? Does it make the noise in a turn or just going straight? You did not say if you had checked the tire for roundness or a bulge which would indicate ply or tread separation.
Mar 24, 2014 | 2001 Buick LeSabre
2001 caddilac deville dhs shakes when it goes over 60mph and makes thumping noise from rear passanger side when i brake
Check the U-joints this will give you a thumping sound by running
out of round. Banging on bottom of car.
The noise in the rear could be a bad wheel bearing, I had that
happen when the race of the bearing came apart.
Apr 21, 2013 | 2001 Cadillac DeVille
2002 olds intrigue shakes while idling with brake on in drive
The cause is too low an idle and engine is starving for fuel so it shakes like that.The thumping sound you hear is most likely just the exhaust being too close to the floor amd bumping against it when in drive with brake on.You said yourself that it stops when you put it in nuetral,well the engine speed goes up when there's no stress on it.With some one holding the brake and it's sitting there thumping,set the idle speed up just enough to make the engine stop rocking that way.
Sep 14, 2012 | 2002 Oldsmobile Intrigue
Car shaking and pop nosie from passenger side wheel
Why drive side bearing could be a bad other.balance yes, tie rod could be bad.
Mar 16, 2017 | 1996 Ford Windstar
My dryer is making a very loud thumping noise, what could it be..it also shakes
brum suport springs have broken or come off dont use it till ts fixed you will smash it up?
Oct 24, 2009 | Maytag LSE7806A Top Load Stacked...
1997 Mercury Sable thumping in front end
try to replace the wheel bearings.
Jun 17, 2009 | 1997 Mercury Sable
02 a4 shakes when accelerating
my geo prizm jus had the same problem its either the cvc joints are bad , the alignment is off track or one of your motor mounts are bad
Feb 03, 2009 | 2002 Audi A4
B-Air Grizzly Dryer 1 HP Green Logo
Top B-Air Dryers Experts
Dan Webster
Dan Webster
Are you a B-Air Dryer Expert? Answer questions, earn points and help others
